[Geoserver-devel] GeoServer 2.11.4 artifacts available for testing
https://build.geoserver.org/geoserver/release/2.11.4/
There is no Windows EXE.
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <https://transient.nz/&gt;
New Zealand
Artifact sizes and contents normal (I checked several but not all plugins). No SNAPSHOTS present.
Documentation buglets:
- PDF manual has 2.11.x on the front page and headers
- htmldoc user manual has 2.11.x in the HTML title (2.11.3 had the same problem); developer manual has the correct version 2.11.4
Testing the bin-zip, layer demos and demo requests worked as expected:
- Every OpenLayers test worked but caused an exception to be logged (attached) similar to that reported for https://osgeo-org.atlassian.net/browse/GEOS-8178
- WFS transaction demos failed with:
org.geoserver.wfs.WFSTransactionException: {http://www.openplans.org/topp\}tasmania_roads is read-only
  at org.geoserver.wfs.Transaction.execute(Transaction.java:269)
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:106)
  at org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:172)
apollo-slave-win-01 is offline. We have no EXE or DMG.
Jenkins geoserver-release-publish underway.
Kind regards,
Ben.
Director
New Zealand
(attachments)
layer-preview-openlayers.txt (15.7 KB)
The 2.11.4 dmg has been uploaded to sourceforge. I can confirm that it installs and starts up fine.
Torben
On Mon, Dec 18, 2017 at 3:29 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
  • PDF manual has 2.11.x on the front page and headers
  • htmldoc user manual has 2.11.x in the HTML title (2.11.3 had the same problem); developer manual has the correct version 2.11.4
  • Every OpenLayers test worked but caused an exception to be logged (attached) similar to that reported for https://osgeo-org.atlassian.net/browse/GEOS-8178
  • WFS transaction demos failed with:
    org.geoserver.wfs.WFSTransactionException: {http://www.openplans.org/topp}tasmania_roads is read-only
Kind regards,
Ben.
Director
Transient Software Limited <https://transient.nz/>
New Zealand
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Thanks, Torben. Much appreciated.
All the 2.11.4 links are published on the download page. I will wait until tomorrow morning (my time) before publishing the blogs to give bloggers a chance to edit.
Kind regards,
Ben.
Torben
t/browse/GEOS-8178
Kind regards,
Ben.
Director
New Zealand
Check out the vibrant tech community on one of the world's most
Director
New Zealand
On Tue, Dec 19, 2017 at 12:29 AM, Ben Caradoc-Davies <ben@anonymised.com>
t/browse/GEOS-8178
Yes, that happens since we switched the data dir to read-only mode for non
authenticated users.
To fix it I believe the following is necessary:
- Add a comment in capital case that login is required
- Make username/password support in demo work again (afaik it's currently
broken)
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
t/browse/GEOS-8178
I see this even if logged in as admin. The shapefiles tasmania_roads.* are writeable on the filesystem.
broken)
Yes, if I supply username+password in the form, I get:
<servlet-exception>
HTTP response: 401
No AuthenticationProvider found for org.springframework.security.authentication.UsernamePasswordAuthenticationToken
</servlet-exception>
Kind regards,
Director
New Zealand
t/browse/GEOS-8178
And I see the same behaviour on master.
Kind regards,
Director
New Zealand
Torben,
one tiny buglet is that the Jenkins geoserver-release job still prints an ares URL for the location of the release artifacts at the end of its log. For example:
https://build.geoserver.org/view/geoserver/job/geoserver-release/194/consoleText
"build complete, artifacts available at http://ares.boundlessgeo.com/geoserver/release/2.11.4&quot;
DIST_HOST=ares.boundlessgeo.com is set in build/properties, and I considered changing it, but this is also used for things like an ssh private key filename. As you were the last person seen fixing the build infrastructure (according to git), I was wondering if you had an opinion on whether it is safe to change this? Perhaps we could try just before the next GeoServer release, and see if it still works.
Kind regards,
Ben.
Director
New Zealand
On Tue, Dec 19, 2017 at 10:48 PM, Ben Caradoc-Davies <ben@anonymised.com>
Yes, known, the demo request does not "cascade" your authentication.
broken)
<servlet-exception>
HTTP response: 401
Right
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Dec 19, 2017 at 5:28 PM, Ben Caradoc-Davies <ben@anonymised.com>
wrote:
Torben,
For example:
eoserver/release/2.11.4"
Looking in the build scripts, the only place besides that message where
DIST_HOST is used is by upload_installer, which in turn is only used by the
mac and windows build scripts.
The current windows build manually sets DIST_HOST, and the mac build can't
upload to the proper location anyways due to auth issues.
So, yes, changing DIST_HOST to build.geoserver.org should be fine, and I
don't anticipate it to cause any issues.
Torben
Kind regards,
Ben.
Director
New Zealand
wrote:
Torben,
For example:
Thanks. I have changed DIST_HOST to build.geoserver.org and DIST_URL to use HTTPS. This only affects the defaults.
Kind regards,
Director
New Zealand
And I fixed this one too: 2.11.x had "release = '2.12-SNAPSHOT'" in doc/en/user/source/conf.py, causing build_release.sh to ignore it because it did not match 2.11-SNAPSHOT, causing the SNAPSHOT removal logic to use '2.11.x' for the label. Not tested, but should be fixed on 2.11.x for future releases on this branch:
https://github.com/geoserver/geoserver/commit/53005543d50fa7034f2e1b0ed9aa4002627420a6
2.12.x and master were not affected.
Kind regards,
Director
New Zealand
