Hi Torben,
The exe 2.11-beta seems to work fine on Windows 8.1.
Jonathan
Hi Torben,
Jonathan
trying the bin package. Starts up fine, noticed this warning:
22 feb 20:38:27 INFO [config.XMLFileResourceProvider] - Found configuration file in gwc
22 feb 20:38:27 WARN [config.XMLConfiguration] - ********************************************************************************
22 feb 20:38:27 WARN [config.XMLConfiguration] - *** GWC configuration validation error: cvc-elt.1: impossibile trovare la dichiarazione dell’elemento “gwcConfiguration”.
22 feb 20:38:27 WARN [config.XMLConfiguration] - *** Will try to use configuration anyway. Please check the order of declared elements against the schema.
Hum… oh well, it starts anyways, but it might be something to look into after.
Besides that, it looks good to me (very light testing done while writing the blog post)
On Wed, Feb 22, 2017 at 4:03 PM, Jonathan Moules <jonathan-lists@anonymised.com> wrote:
Hi Torben,
Jonathan
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Just took a look at the YSLD plugin, and the zipfile is 22 bytes - looks like it is empty. I will look into why this is occurring… Most likely an error in the ext-ysld.xml.
Torben
On Wed, Feb 22, 2017 at 11:59 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
trying the bin package. Starts up fine, noticed this warning:22 feb 20:38:27 INFO [config.XMLFileResourceProvider] - Found configuration file in gwc
22 feb 20:38:27 WARN [config.XMLConfiguration] - ********************************************************************************Hum… oh well, it starts anyways, but it might be something to look into after.
Besides that, it looks good to me (very light testing done while writing the blog post)Cheers
Hi Torben,
Jonathan
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea/Torben,
I get that in my console on the Windows exe too.
23 Feb 09:50:17 WARN [config.XMLConfiguration] - ********************************************************************************
23 Feb 09:50:17 WARN [config.XMLConfiguration] - *** GWC configuration validation error: cvc-elt.1: Cannot find the declaration of element ‘gwcConfiguration’.
23 Feb 09:50:17 WARN [config.XMLConfiguration] - *** Will try to use configuration anyway. Please check the order of declared elements against the schema.
But it works, so I figured that was that.
Jonathan
---- On Wed, 22 Feb 2017 19:59:16 +0000 Andrea Aime andrea.aime@anonymised.com wrote ----
AndreaOn Wed, Feb 22, 2017 at 4:03 PM, Jonathan Moules <jonathan-lists@anonymised.com> wrote:
Hi Torben,
Jonathan
https://lists.sourceforge.net/lists/listinfo/geoserver-devel–
http://goo.gl/it488V for more information.Ing. Andrea Aime
@geowolf
Technical LeadGeoSolutions S.A.S.
phone: +39 0584 962313fax: +39 0584 1660272
mob: +39 339 8844549http://www.geo-solutions.it
http://twitter.com/geosolutions_itAVVERTENZE AI SENSI DEL D.Lgs. 196/2003
YSLD issue has been fixed on master, turns out I missed adding the ysld dependency to the “release” pom.
Torben
On Thu, Feb 23, 2017 at 1:53 AM, Jonathan Moules <jonathan-lists@anonymised.com> wrote:
Hi Andrea/Torben,
I get that in my console on the Windows exe too.23 Feb 09:50:17 WARN [config.XMLConfiguration] - ********************************************************************************
23 Feb 09:50:17 WARN [config.XMLConfiguration] - ********************************************************************************But it works, so I figured that was that.
Jonathan---- On Wed, 22 Feb 2017 19:59:16 +0000 Andrea Aime <andrea.aime@anonymised.com> wrote ----
Hi Torben,
Jonathan
Geoserver-devel@anonymised.comsourceforge.net
@geowolf
