[Geoserver-devel] geoserver 2.11-RC1 preflight
Preflight artifacts available for testing:
I will go work on blog next.
Jody Garnett
The windows exe was not generated; I am not quite sure why. I would like to go ahead with a release announcement tomorrow (and we can always add the exe when time permits).
General strategy for the blog, repeat of the beta blog with a note about the label position point alignment change, and the flag to restore prior behaviour. Anything else we want to highlight for RC1 testing?
Jody Garnett
Jody Garnett
exe generated; please test.
Jody Garnett
Jody Garnett
Jody Garnett
Initial testing in a VM - we need to update dates for 2017
GeoServer, open geospatial information server
Copyright (C) 2014-2016 Open Source Geospatial Foundation.
Copyright (C) 2001-2014 OpenPlans
I also note that the memory settings seem to be off when run as a service:
Memory Usage 72 MB / 123 MB
So I suspect start up parameters may be off (kind of which we had a status endpoint that reported the startup parameters).
Jody Garnett
Jody Garnett
Jody Garnett
Jody Garnett
I was testing a few options with Window 10 and 32-bit jre:
  • with bin-zip to run on port 8060 - OK
  • with exe-installer to run stand-alone on port 8060 - OK
  • with exe-installer to run as a service on port 8060 - OK
GetCapabilities of the services and layer previews look good.
-Jukka Rahkonen-
Jody Garnett wrote:
Re: [Geoserver-devel] geoserver 2.11-RC1 preflight
Jody Garnett
Jody Garnett
Jody Garnett
Blog post is ready for review, please publish when ready.
Jody Garnett
Jody Garnett
