[Geoserver-devel] GeoServer 2.12.5... or not?
I’m getting a bit confused about our release schedule for the maintenance series.
The release schedule seems to have a slot for 2.12.5:
https://github.com/geoserver/geoserver/wiki/Release-Schedule
however the GeoTools announcement states 18.4 is the last:
http://geotoolsnews.blogspot.com/2018/06/geotools-184-released.html
So… which one is right? :slight_smile:
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I think this is a mistake due to the changes in the release process we
did a while ago.
I would go for 2.12.5.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
On Tue, Jul 3, 2018 at 5:37 PM Andrea Aime <andrea.aime@anonymised.com> wrote:
I'm getting a bit confused about our release schedule for the maintenance series.
So... which one is right? :slight_smile:
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! http://sdm.link/slashdot_______________________________________________
Geoserver-devel mailing list
I saw that too today, I thought I was right but who knows. I don’t think we’ve had any 2.x.5 releases before
Ian
Ian Turton
A 2.x.5 has happened but not always, see the “archived” tab here:
http://geoserver.org/download/
Ian
On Tue, 3 Jul 2018 at 16:37, Andrea Aime <andrea.aime@anonymised.com> wrote:
Geoserver-devel@anonymised.comsourceforge.net
Ian Turton
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I had forgotten the changes to the release structure so I guess can do a 2.12.5 now
Ian
Ian
Ian Turton
Ian Turton
2.12.5 now
Hem... now? It's scheduled for Aug 18th, in parallel with the 2.14-RC
------------------------------------------------------- *Con riferimento
telephone or e-mail.*
That seems to be how we did it in February, can anyone recall that far back? is that what we actually did?
Ian
Hem… now? It’s scheduled for Aug 18th, in parallel with the 2.14-RC
Ian Turton
