[Geoserver-devel] GeoServer 2.12-beta artifacts available for testing
I tried the Windows exe-installer, seemed to work OK.
-Jukka Rahkonen-
Lähettäjä: Torben Barsballe [mailto:tbarsballe@…3839…]
Lähetetty: 15. syyskuuta 2017 0:15
Vastaanottaja: geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] GeoServer 2.12-beta artifacts available for testing
GeoServer 2.12-beta now published. Draft blog post here, if anyone wants to take a look. Will be announced shortly.
Torben
On Thu, Sep 14, 2017 at 11:59 AM, David Vick <dvick@…3839…> wrote:
All,
I have fixed this bug, PR is here https://github.com/GeoWebCache/geowebcache/pull/542
David Vick
Software Developer | Boundless
dvick@…3839…
mobile: +1-636-698-3174
On Thu, Sep 14, 2017 at 12:21 PM, Torben Barsballe <tbarsballe@…3839…> wrote:
I think we can count this as a bug against the beta, as long as it gets fixed before RC-1. I’m going to proceed with publishing the release.
Torben
On Thu, Sep 14, 2017 at 10:17 AM, David Vick <dvick@…3839…> wrote:
I can confirm that is affecting embedded only. I was fighting this error on Standalone on Friday, I believe what is happening is the ContentNegotiationManager in RestConfiguration in the Rest module is streaming the contents before passing the request to the Controller. Consequently, the contents at the Controller are empty. This is the line that is throwing the error
BufferedReader formReader = request.getReader();
even changing to an inputStreamReader() will result in the data being an empty string.
The resolution for Standalone was to remove the ContentNegotiationManager from the configuration, however, I’m not sure that is an option for us in GeoServer.
David Vick
dvick@…3839…
On Wed, Sep 13, 2017 at 6:44 PM, Torben Barsballe <tbarsballe@…3839…> wrote:
Ben - Devon has ran into the same issue. I wonder if this affects only embedded GeoWebCache, or standalone as well?
Doc build is now fixed, and the correct docs are getting created; new artifacts are available from http://build-slave-01.geoserver.org/geoserver/release/2.12-beta/
Torben
On Wed, Sep 13, 2017 at 3:38 PM, Ben Caradoc-Davies <ben@…4191…> wrote:
Basic smoke tests work for me on debian/sid with the bin zip. No SNAPSHOT jars in this or the war zip.
Seeding topp:states in GWC fails. I pressed Submit here:
http://localhost:8080/geoserver/gwc/rest/seed/topp:states
Response is text/plain “STREAMED” and this exception is seen at the console:
14 Sep 10:29:52 ERROR [geoserver.rest] - STREAMED
java.lang.IllegalStateException: STREAMED
at org.eclipse.jetty.server.Request.getReader(Request.java:978)
at javax.servlet.ServletRequestWrapper.getReader(ServletRequestWrapper.java:266)
at org.geowebcache.rest.service.FormService.handleFormPost(FormService.java:159)
at org.geowebcache.rest.controller.SeedController.doPost(SeedController.java:120)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:205)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:133)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:116)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:827)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:738)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:963)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:897)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:872)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:89)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:215)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:110)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:499)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
at java.lang.Thread.run(Thread.java:748)
Kind regards,
Ben.
On 14/09/17 10:03, Torben Barsballe wrote:
The geoserver 2.12-beta artifacts are available for testing from
(Windows exe and OS X dmg are not yet available, but will be soon)
In addition to the regular tests of the GeoServer executable, please also
verify the docs, as the doc build procedure has changed as of 2.12.
Any assistance testing is appreciated.
Torben
Geoserver-devel mailing list
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Thanks for the improvements to the blog post Andrea.
Torben
On Fri, Sep 15, 2017 at 5:34 AM, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
-Jukka Rahkonen-
Lähettäjä: Torben Barsballe [mailto:tbarsballe@boundlessgeo.com]
Vastaanottaja: geoserver-devel <geoserver-devel@anonymised.comsourceforge.net>
Torben
On Thu, Sep 14, 2017 at 11:59 AM, David Vick <dvick@anonymised.com> wrote:
All,
David Vick
On Thu, Sep 14, 2017 at 12:21 PM, Torben Barsballe <tbarsballe@anonymised.com.3839…> wrote:
Torben
David Vick
On Wed, Sep 13, 2017 at 6:44 PM, Torben Barsballe <tbarsballe@anonymised.com3839…> wrote:
Torben
On Wed, Sep 13, 2017 at 3:38 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Kind regards,
Ben.
Torben
Geoserver-devel@anonymised.comsourceforge.net
Director
New Zealand
thanks, just noticed that some pictures are too big, but I was in a rush before working
hours this morning… if nobody else gets to it I might find time to shrink them a bit
tomorrow or Sunday
On Fri, Sep 15, 2017 at 6:06 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Geoserver-devel@anonymised.com.366…sourceforge.net
On Fri, Sep 15, 2017 at 5:34 AM, Rahkonen Jukka (MML) <jukka.rahkonen@maanmittauslaitos.fi> wrote:
-Jukka Rahkonen-
Lähettäjä: Torben Barsballe [mailto:tbarsballe@anonymised.como.com]
Vastaanottaja: geoserver-devel <geoserver-devel@anonymised.comorge.net>
Torben
All,
David Vick
Torben
David Vick
Torben
Kind regards,
Ben.
Torben
Geoserver-devel@anonymised.comrge.net
Director
New Zealand
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I’ve shrunk the ones that were overlapping the sidebar. I might take a second pass and shrink some of the other ones that might be a bit bigger than necessary.
Torben
On Fri, Sep 15, 2017 at 9:11 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
tomorrow or Sunday
Torben
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
On Fri, Sep 15, 2017 at 5:34 AM, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.comtos.fi> wrote:
-Jukka Rahkonen-
Torben
All,
David Vick
Torben
David Vick
Torben
Kind regards,
Ben.
Torben
Director
New Zealand
