The GeoServer 2.12-RC1 artifacts are available for testing from https://build.geoserver.org/geoserver/release/2.12-RC1/
Windows and macOS artifacts are in there way.
Torben
Torben
Torben,
looks good. No unexpected artifacts (such as SNAPSHOTS) in the bin, war, or the plugins I examined. Smoke tests on the bin look good. I tested many layer previews and several demo requests. GeoServer information and the admin pages as expected. I also saw the Marlin renderer information on startup. Testing performed on Debian sid with OpenJDK 8u144-b01-1 amd64.
Embedded GWC seeding works again, but tasks after the first cannot be killed: "Sorry, either task 1 has not started yet, or it is a truncate task that cannot be interrutped."
Note that the tested task was in fact task with id=3. Is the wrong task being killed?
Id Layer Status Type Estimated # of tiles Tiles completed Time elapsed Time remaining Tasks
3 topp:states RUNNING SEED 984,370 85,984 2 minutes 6 s 21 minutes 56 s (Task 1 of 1)
Kind regards,
Ben.
https://build.geoserver.org/geoserver/release/2.12-RC1/Windows and macOS artifacts are in there way.
Torben
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! http://sdm.link/slashdot_______________________________________________
Geoserver-devel mailing list
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
New build of geoserver out with a fix for the DMG issue - GeoServer now starts up on my machine. If someone else with a macOS machine can also test, that would be appreciated (DMG attached)
geoserver-2.12-RC1.dmg
Also fixed GEOS-8308.
Kevin, David - any ideas about the issue Ben encountered, above?
Torben
On Thu, Sep 28, 2017 at 5:19 PM, Ben Caradoc-Davies <ben@…4191…> wrote:
Torben,
Embedded GWC seeding works again, but tasks after the first cannot be killed: “Sorry, either task 1 has not started yet, or it is a truncate task that cannot be interrutped.”
3 topp:states RUNNING SEED 984,370 85,984 2 minutes 6 s 21 minutes 56 s (Task 1 of 1)Kind regards,
Torben
Geoserver-devel@anonymised.comrge.net
https://lists.sourceforge.net/lists/listinfo/geoserver-devel–
Director
New Zealand
