[Geoserver-devel] GeoServer 2.14.3 release artifacts ready for testing
Dear All,
GeoServer 2.14.3 artifacts are available for testing here: https://build.geoserver.org/geoserver/release/2.14.3
Alessandro Parma
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Alessandro Parma
DevOps Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Thanks Alessandro:
bin:
  • works fine on macOS with Java 8
  • initially ran it in java 11 by default and it did not startup :stuck_out_tongue:
exe:
  • install runs fine
  • was not able to test as service as I had a 64-bit java
  • marlin showed up correctly in the the status page
Jody Garnett
Thank you Jody, moving on then!
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Thank you Jody
Publishing now
Alessandro Parma
Alessandro Parma
DevOps Engineer
