[Geoserver-devel] GeoServer 2.14-RC artifacts available for testing
Artifacts available here:
https://build.geoserver.org/geoserver/release/2.14-RC/
The windows installer is not there yet at the time of writing, but hopefully it will show up soon
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Checked that the PDF user manual has the right version and plenty of pages
Not related to the release, but noted that there is a section right at the end: “17.16.1 geoserver 2.7.0 on JBoss AS 5.1” – any objections to removing that, considering the age of 2.7 and that it isn’t even called JBoss any more?
Downloaded and installed the WAR on Tomcat8, starts up OK:
  • GeoServer Version 2.14-RC
  • Git Revision 5e6e4a798002c99d0494bb71fb921f2c0ce2c011
  • Build Date 21-Aug-2018 07:50
  • GeoTools Version 20-RC (rev 6b7ecb1a59368789ec130e3087276dcb5efc8a5d)
  • GeoWebCache Version 1.14-RC (rev master/2acfb90f7044b8ab376c589531aee66f47d2911d)
Checked some raster and vector layers preview OK, a couple of GetCapabilities, and some demo requests.
Seems OK – pretty light testing, but nothing concerning.
Brad
Sent: Tuesday, 21 August 2018 6:36 PM
To: Geoserver-devel geoserver-devel@anonymised.comet
Subject: [Geoserver-devel] GeoServer 2.14-RC artifacts available for testing
Ha ha, yes, seems about time to do it.
Thanks for testing it!
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Tested GeoServer WAR from https://build.geoserver.org/geoserver/release/2.14-RC/ on Tomcat8
Default deployment:
  • Layers and Layer Groups are good
  • SLD editor and Legends work correctly
  • Creation of new data stores works as espected
  • Tested Shapefiles with time-dimension, ok
Tested several plugins:
  • WPS OK
  • WMTS MultiDim OK
  • Importer OK
  • Monitoring OK
  • GeoFence Server OK
  • Oauth2 OK
Alessio.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
mob: +39 331 6233686
Awesome, thank you for the in-deep tests.
I’ll move on publishing the artifacts
