[Geoserver-devel] GeoServer 2.16.1 release train reminder
Bin-zip tested on Windows, runs and sends GetCapabilities for all the services and layer preview is OK.
-Jukka-
Lähettäjä: Jody Garnett <jody.garnett@…403…>
Lähetetty: maanantai 25. marraskuuta 2019 6.30
Vastaanottaja: Gabriel Roldan <gabriel.roldan@…403…>
Kopio: GeoServer geoserver-devel@lists.sourceforge.net; Andrea Aime <andrea.aime@…1268…>
Aihe: Re: [Geoserver-devel] GeoServer 2.16.1 release train reminder
Once again ask folks to review blog post, and test the release artifacts above.
(I will be in a position to test mid-week)
Jody Garnett
On Thu, 21 Nov 2019 at 17:58, Jody Garnett <jody.garnett@…403…> wrote:
Initial release artifacts are reading for testing:
https://build.geoserver.org/view/release/job/geoserver-release/261/artifact/distribution/2.16.1
I expect to release Friday (after folks have had a chance to try out the above and review the blog posts)
Jody Garnett
On Wed, 20 Nov 2019 at 21:37, Jody Garnett <jody.garnett@…403…> wrote:
I am currently working on the geotools build, here are the details for the upcoming release.
GeoServer 2.16.1
Blog draft is ready for review, I have included stock headings for security updates / community updates / About 2.16 Series sections which I hope we can recycle each time.
Jody Garnett
On Wed, 20 Nov 2019 at 11:27, Gabriel Roldan <gabriel.roldan@…403…> wrote:
Jody, let it slip till next release, don’t even waste your time.
(btw, the npe was a newly introduced issue of my own, the clean up of null checks is good and verified they were testing for nulls that couldn’t happen inside the internal code, not user input of any kind)
On Wed, 20 Nov 2019 at 14:59, Jody Garnett <jody.garnett@…403…> wrote:
Gabriel my testing was fine, but I admit to being somewhat hesitant given fernando’s recent trouble.
I understand you wanting to clean up code. The strategy of removing null checks that should not happen is always risky (for when they happen).
Jody Garnett
On Mon, 18 Nov 2019 at 10:34, Jody Garnett <jody.garnett@…403…> wrote:
I will test myself locally and get back to you.
Jody Garnett
On Mon, 18 Nov 2019 at 06:20, Gabriel Roldan <gabriel.roldan@…403…> wrote:
re-issued GEOS-9191 pr[1] with new test cases to cover the issue that forced us to revert the other one.
I’ll leave it to you, Jody, to decide whether to include the 2.16.x backport on this release. IMHO it should be safe, and I tested manually with a data directory that has no gwc-layers directory with and without the fix commit and it seems all good.
Gabriel
[1] https://github.com/geoserver/geoserver/pull/3909
[2] https://github.com/geoserver/geoserver/pull/3909/commits/65cc9227b7a9138edb9313784d53e4c718158958
On Mon, 18 Nov 2019 at 05:16, Andrea Aime <andrea.aime@…1268…> wrote:
Reminder 2, 2.16.1 is a stable series release, so careful about what you backport
only a few days before the release
On Mon, Nov 18, 2019 at 6:38 AM Jody Garnett <jody.garnett@…403…> wrote:
The GeoServer 2.16.2 release is scheduled for this week. If you have any fixes or pull requests this is your reminder :slight_smile:
Jody Garnett
Geoserver-devel mailing list
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Gabriel Roldán
Gabriel Roldán
Thanks Jukka,
The application runs fine of macOS.
Given the build problems about OpenJDK vs OracleJDK and discussion in yesterday’s meeting I think I should add a comment to the release announcement about Java 8u221 changing the handling of URLs.
On Tue, Nov 26, 2019 at 11:57 AM Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
-Jukka-
Lähettäjä: Jody Garnett <jody.garnett@anonymised.com03…>
Vastaanottaja: Gabriel Roldan <gabriel.roldan@anonymised.com>
Kopio: GeoServer <geoserver-devel@lists.sourceforge.net>; Andrea Aime <andrea.aime@anonymised.com>
Jody Garnett
On Thu, 21 Nov 2019 at 17:58, Jody Garnett <jody.garnett@anonymised.com…> wrote:
Jody Garnett
On Wed, 20 Nov 2019 at 21:37, Jody Garnett <jody.garnett@anonymised.com…> wrote:
GeoServer 2.16.1
Jody Garnett
On Wed, 20 Nov 2019 at 11:27, Gabriel Roldan <gabriel.roldan@anonymised.com…403…> wrote:
On Wed, 20 Nov 2019 at 14:59, Jody Garnett <jody.garnett@anonymised.com…> wrote:
Jody Garnett
On Mon, 18 Nov 2019 at 10:34, Jody Garnett <jody.garnett@anonymised.com…> wrote:
Jody Garnett
On Mon, 18 Nov 2019 at 06:20, Gabriel Roldan <gabriel.roldan@anonymised.com…403…> wrote:
Gabriel
On Mon, 18 Nov 2019 at 05:16, Andrea Aime <andrea.aime@anonymised.com.> wrote:
On Mon, Nov 18, 2019 at 6:38 AM Jody Garnett <jody.garnett@anonymised.com3…> wrote:
Jody Garnett
Gabriel Roldán
Gabriel Roldán
How does this sound:
Note: Our builds detected a change in Oracle JDK 8u221 URL handling, this release was made with 8u202 as a result. Future releases will be made using OpenJDK.
Jody Garnett
Hi Jody,
that works fine for me
