[Geoserver-devel] GeoServer 2.19.3 release artifacts available on build server, please test
At least bin-zip starts on Windows 10 with jre 11 and shows layer preview and capabilities.
-Jukka Rahkonen-
Lähettäjä: Andrea Aime <andrea.aime@…6887…>
Lähetetty: keskiviikko 22. joulukuuta 2021 11.02
Vastaanottaja: GeoServer geoserver-devel@lists.sourceforge.net
Aihe: [Geoserver-devel] GeoServer 2.19.3 release artifacts available on build server, please test
the artifacts are available here:
https://build.geoserver.org/view/release/job/geoserver-release/39/artifact/distribution/2.19.4/
Please let me know if you find any issue. I plan to hit the release button in the late
afternoon (CET time)
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Thanks!
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
