Hello,
am trying to use geoserver 2.2.5 with tomcat 7.0.34 following this tuto:http://ian01.geog.psu.edu/geoserver_docs/software/geoserver.html but am getting this error concerning the servlet jar:
5 mai 2013 14:10:25 org.apache.catalina.core.StandardEngine startInternal
INFO: Starting Servlet Engine: Apache Tomcat/7.0.34
5 mai 2013 14:10:25 org.apache.catalina.startup.HostConfig deployWAR
INFO: Déploiement de l'archive C:\Users\OUK\Desktop\PFE\tomcat-7.0.34\apache-tomcat-7.0.34\webapps\geoserver.war de l'application web
5 mai 2013 14:10:26 org.apache.catalina.loader.WebappClassLoader validateJarFile
INFO: validateJarFile(C:\Users\OUK\Desktop\PFE\tomcat-7.0.34\apache-tomcat-7.0.34\webapps\geoserver\WEB-INF\lib\servlet-api-2.5.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
05 mai 14:10:35 WARN [config.CustomEditorConfigurer] - Passing PropertyEditor instances into CustomEditorConfigurer is deprecated: use PropertyEditorRegistrars or PropertyEditor class names instead. Offending key [org.geotools.util.Version; offending editor instance: org.geoserver.platform.util.VersionPropertyEditor@anonymised.com
5 mai 2013 14:10:35 org.geoserver.platform.GeoServerExtensions checkContext
GRAVE: Extension lookup occured, but ApplicationContext is unset.
05 mai 14:10:35 ERROR [geoserver.global] -
can anyone figure out how to solve this problem, thnks.
Asma OUQALLI
Élève ingénieur : 3ème Sciences d’Information Géographique (SIG).
Chef de commission développement professionnel - Rotaract EHTP.
Chef de cellule Media - Olympiades EHTP 2012.
Ecole Hassania des Travaux Publics.
Mobile : +212 672 48 23 15.
Email : asma.ouqalli@anonymised.com
On Sun, May 5, 2013 at 3:36 PM, Asma ouqalli <asma.ouqalli@anonymised.com> wrote:
Hello,
The error you refer to.. is not an error, it's a warning, GeoServer
normally deploys fine even with it (yes, that message is always present,
it's annoying and we're working to remove it, but it does not prevent the
deploy to succeed).
The real error is somewhere else, you'll probably find it in the
geoserver.log file, contained in the GeoServer data directory
GeoServer training in Milan, 6th & 7th June 2013! Visit
http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi andrea,
but when i try to open the link of geoserver i don’t get nothing,
in my log file the only line that contains error is this : 2013-05-05 15:12:55,195 ERROR [geoserver.global] -
i don’t really know what’s the problem :s
2013/5/5 Andrea Aime <andrea.aime@anonymised.com>
Asma OUQALLI
Email : asma.ouqalli@anonymised.com…
Hello,
The error you refer to… is not an error, it’s a warning, GeoServer normally deploys fine even with it (yes, that message is always present, it’s annoying and we’re working to remove it, but it does not prevent the deploy to succeed).
The real error is somewhere else, you’ll probably find it in the geoserver.log file, contained in the GeoServer data directory
GeoServer training in Milan, 6th & 7th June 2013! Visit http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
