[Geoserver-devel] GeoServer 2.2 beta1 - WFS 2.0 Axis Order
Hello everyone,
I created a layer “gmd_ex” (postgis as datasource). The internal preview in OpenLayers (WMS 1.1.0) looks fine.
SRS definition of source-layer (EPSG:31468) → using native SRS
PROJCS["DHDN / 3-degree Gauss-Kruger zone 4",
  GEOGCS["DHDN",
    DATUM["Deutsches Hauptdreiecksnetz",
      SPHEROID["Bessel 1841", 6377397.155, 299.1528128, AUTHORITY["EPSG","7004"]],
      TOWGS84[612.4, 77.0, 440.2, -0.054, 0.057, -2.797, 2.55],
      AUTHORITY["EPSG","6314"]],
    PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
    UNIT["degree", 0.017453292519943295],
    AXIS["Geodetic longitude", EAST],
    AXIS["Geodetic latitude", NORTH],
    AUTHORITY["EPSG","4314"]],
  PROJECTION["Transverse_Mercator", AUTHORITY["EPSG","9807"]],
  PARAMETER["central_meridian", 12.0],
  PARAMETER["latitude_of_origin", 0.0],
  PARAMETER["scale_factor", 1.0],
  PARAMETER["false_easting", 4500000.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
<b>  AXIS["Easting", EAST],
  AXIS["Northing", NORTH],
</b>  AUTHORITY["EPSG","31468"]]
The determined envelope also looks fine.
I tried several WFS 2.0 requests (stored queries):
http://www.weichand.de/2012/04/22/wfs-2-0-geoserver-beta-stored-queries-beispiele/
In the GetFeatureResponse (GML 3.2.1) the axis-order is inverted (Northing, Easting).
Also in the SHAPE-ZIP Output-Format:
  GEOGCS["DHDN",
  UNIT["m", 1.0],
<b>  AXIS["Northing", NORTH],
  AXIS["Easting", EAST], </b>
The shapefile is shown with the wrong axis-order in QGIS (using SRS:EPSG:31468).
Best regards
Jürgen
On Tue, Apr 24, 2012 at 10:42 AM, Jürgen Weichand <
juergen.weichand@anonymised.com> wrote:
Hello everyone,
I created a layer "gmd_ex" (postgis as datasource). The internal preview
SRS definition of source-layer (EPSG:31468) --> using native SRS
  GEOGCS["DHDN",
  UNIT["m", 1.0], * AXIS["Easting", EAST],
  AXIS["Northing", NORTH], * AUTHORITY["EPSG","31468"]]
In these stored queries you are using the deprecated EPSG:XYWZ format,
which GeoServer
assumes to force lon/lat order, if you want the natural EPSG order you'll
have to use
the srs expression mandated by WFS 2.0, the urn:... format.
See this for a bit more details:
http://docs.geoserver.org/latest/en/user/services/wfs/basics.html#axis-ordering
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
On Tue, Apr 24, 2012 at 11:13 AM, Andrea Aime
which GeoServer
have to use
Actually I see you using the expression only in the BBOX filter, but not
asking for an explicit
reprojection. Might be a bug, not sure.
Ing. Andrea Aime
Tech lead
which GeoServer
you'll have to use
Note that these are *not* the urn:ogc form mandated by WFS 2.0 but the transitional WFS 1.1(?) urn:x-ogc form implemented in GeoServer before urn:ogc was assigned to OGC by the IANA. GeoServer supports queries with the official srsName format, for example:
srsName=urn:ogc:def:crs:EPSG:4326
but be aware that while these requests are honoured, WFS responses are encoded with, for example:
srsName="urn:x-ogc:def:crs:EPSG:4326"
even for WFS 2.0.0. Some clients may not care.
See:
http://jira.codehaus.org/browse/GEOS-4545
http://jira.codehaus.org/browse/GEOT-3581
http://geoserver-devel.821594.n3.nabble.com/Geoserver-devel-srsName-urn-x-ogc-vs-urn-ogc-more-headaches-and-long-term-decisions-td1887641.html
Wow, OGC have been working overtime to annoy Andrea this week. :wink:
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
