[Geoserver-devel] Geoserver 2.20.0, Encoding German Umlaut-Problems
Hi list,
switching from 2.19.1 to 2.20.0 Geoserver I got so called
Umlaut-Problems in our german geoserver web interface:
Every german Umlaut like ö, ü and so on is replaced by a question mark.
Is there any configuration available to fix this?
Thanks
Stefan
Dipl. Ing. Stefan Overkamp
Laakmannsbusch 44, 42555 Velbert
tel.: 0177 / 79 76 159
overkamp@anonymised.com
I can confirm the issue, by switching my browser to German locale (there are extensions to do that).
That said:
  • This is the developer list, it’s intended to be used by developers only. Unless you plan to contribute code to GeoServer, please use the user list
  • We had a 2.20 RC out for over a month, with developers interested in feedback about it. Unfortunately this issue was not reported before 2.20.0 went out… Now you can open a ticket in the tracker, but you’ll have to wait for someone to pick it up, among many other issues, during a bug fix code sprint (might be a while).
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
