[Geoserver-devel] geoserver 2.20.2 available for preflight testing
artefacts available for testing here: https://build.geoserver.org/view/release/job/geoserver-release/40/artifact/distribution/2.20.2
I am not aware of any special priorities for testing, the release notes are now here https://github.com/geoserver/geoserver/releases/tag/2.20.2
I am curious if the windows installer job will work (or run into permissions issues again).
Jody Garnett
Okay, got 1st problem:
Caused by: java.lang.NoSuchMethodError: java.nio.ByteBuffer.position(I)Ljava/nio/ByteBuffer;
at org.geotools.data.shapefile.dbf.DbaseFileHeader.readHeader(DbaseFileHeader.java:577)
Expect one of the jobs built using Java 11, and thus this bundle will not work on Java 8.
Confirmed: Changing to Java 11 works as expected.
Let me know if there are any other issues and I can restart the release process tomorrow.
Jody Garnett
New artefacts ready for testing:
https://build.geoserver.org/view/release/job/geoserver-release/41/artifact/distribution/2.20.2/
Now working in Java 8.
Windows installer also available: https://build.geoserver.org/view/release/job/geoserver-release/ws/distribution/2.20.2/GeoServer-2.20.2-winsetup.exe
(The windows job is having some issues with chmod)
Jody Garnett
istribution/2.20.2/
Booted the war on a recent ubuntu distro, with Tomcat 9.
    GeoServer Version
    2.20.2
    Git Revision
    578fcc9f509efb27568498566a09d22f1070f97f
    Build Date
    23-Jan-2022 18:45
    GeoTools Version
    26.2 (rev 64c409b2a537142993932e706c3f9c6e9efa7529)
    GeoWebCache Version
    1.20.1 (rev 1.20.x/68f4e6bb663682ab9c8c2ccd0bb2a7dd7ad5d685)
Ubuntu: 11.0.13 (OpenJDK 64-Bit Server VM)
Login looks OK. No issues noted with layer preview samples.
Statistics disabled by default, enabling them produces:
    Enable All Statistics
Updated at 2022-01-24 11:57:47.270
Info Value
Operating system Ubuntu 21.04
Uptime 02:40:49
System average load 1 minute 1.19
System average load 5 minutes 0.98
System average load 15 minutes 0.72
Number of physical CPUs 6
Number of logical CPUs 12
Number of running process 413
Number of running threads 1615
CPU load average 5.43 %
CPU 1 load 7.21 %
CPU 2 load 4.46 %
CPU 3 load 7.21 %
CPU 4 load 4.46 %
CPU 5 load 5.45 %
CPU 6 load 6.31 %
CPU 7 load 2.78 %
CPU 8 load 6.31 %
CPU 9 load 8.11 %
CPU 10 load 5.36 %
CPU 11 load 3.67 %
CPU 12 load 3.64 %
Used physical memory 12.73 %
Total physical memory 62.6 GiB
Free physical memory 54.6 GiB
Used swap memory 0.00 %
Total swap memory 2.0 GiB
Free swap memory 2.0 GiB
File system usage 81.98 %
Partition [/] used space 81.99 %
Partition [/dev/nvme0n1p1] used space 1.02 %
Partition [/dev/nvme0n1p2] used space 81.99 %
Partition [/] total space 937.4 GiB
Partition [/dev/nvme0n1p1] total space 511.0 MiB
Partition [/dev/nvme0n1p2] total space 937.4 GiB
Partition [/] free space 168.8 GiB
Partition [/dev/nvme0n1p1] free space 505.8 MiB
Partition [/dev/nvme0n1p2] free space 168.8 GiB
Network interfaces send 22907547.00 bytes
Network interfaces received 1241767557.00 bytes
Network interface [docker0] received 0 B
Network interface [docker0] send 0 B
Network interface [wlp0s20f3] send 21.8 MiB
Network interface [wlp0s20f3] received 1.2 GiB
CPU temperature 39.00 °C
CPU voltage NOT AVAILABLE
Speed fan 1 3217 rpm
Speed fan 2 3507 rpm
GeoServer CPU usage 0.25 %
GeoServer threads 81
GeoServer JVM memory usage 2.81 %
Looks good.
I was not aware you could enable/disable the statistics?
Announcement is ready to go here https://github.com/geoserver/geoserver.github.io/pull/117
Because of the way github pages works this pull request should be merged (when ready) on the 24th.
Jody Garnett
The checkbox at the top of the tab does the job.
Brad
Is that … new?
Jody Garnett
On Monday, 24 January 2022 4:57:46 PM AEDT Jody Garnett wrote:
Is that … new?
Fairly new:
https://github.com/geoserver/geoserver/commit/
53cfa824388ee8b936cff6afc799177fb6871a52
Brad
