Ok, I understand now. I have tested the Windows installer with 2.20-RC and the installer sets GEOSERVER_HOME environment. Since that I have been running the RC version on this computer because startup.bat checks GEOSERVER_HOME. That was not a problem for me earlier because a) normally I do not want to install Geoserver as a Windows service and b) Windows service installation was broken anyway.
User who wants to switch between Geoserver versions must remember to check the environment variables.
-Jukka-
Lähettäjä: Rahkonen Jukka (MML)
Lähetetty: torstai 24. helmikuuta 2022 21.16
Vastaanottaja: ‘Jody Garnett’ <jody.garnett@…403…>
Kopio: GeoServer geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] GeoServer 2.20.3 available for preflight testing
Hi Jody,
Yes, I have correct zip, but from the logs I found this entry:
2022-02-24 20:56:13.307:INFO:oejdp.ScanningAppProvider:main: Deployment monitor [file:///C:/ohjelmat/gs20rc/GeoServer/webapps/] at interval 1
So the startup.bat from gs 2.20.3 decided to use something from an older version (2.20RC) that I have used before and that I still had on my computer. I deleted the whole 2.20RC directory, started 2.20.3 again and now the logs show this
2022-02-24 20:59:38.495:INFO:oejdp.ScanningAppProvider:main: Deployment monitor [file:///C:/ohjelmat/gs_2203/webapps/] at interval 1
so deployment monitor points to correct directory and the user interface shows correctly 2.20.3.
I wonder what GeoServer version was actually started when I still had the 2.20RC directory. I still have 6 different GeoServer versions on my computer because I tend to start the same version that a user who has some problem is using. I think it has been working well. Is there something new in this Deployment monitor thing?
-Jukka Rahkonen-
Lähettäjä: Jody Garnett <jody.garnett@…403…>
Lähetetty: torstai 24. helmikuuta 2022 20.06
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen@…4189…>
Kopio: GeoServer <geoserver-devel@lists.sourceforge.net>
Jukka:
I downloaded geoserver-2.20.3-bin.zip and see the server status page reporting:
Build Information
GeoServer Version
2.20.3
Git Revision
8cca82dc95b5609476f4fe9208e9e61ba5ff7c82
Build Date
23-Feb-2022 17:51
GeoTools Version
26.3 (rev 0e5c8319f4fed5f8751097541db27b744a1b24d1)
GeoWebCache Version
1.20.1 (rev 1.20.x/68f4e6bb663682ab9c8c2ccd0bb2a7dd7ad5d685)
And the welcome page:
This GeoServer instance is running version 2.20.3. For more information please contact the administrator.
Can you please double check your download?
Jody Garnett
On Wed, 23 Feb 2022 at 23:58, Rahkonen Jukka (MML) <jukka.rahkonen@…4189…> wrote:
I tried bin-zip on Windows 10 with OpenJDK 11. I did not notice any trouble. However, the welcome page shows ”This GeoServer instance is running version 2.20-RC. For more information please contact the administrator” and 2.20-RC appears also in Server Status – Modules page.
-Jukka Rahkonen-
Lähetetty: keskiviikko 23. helmikuuta 2022 22.56
Vastaanottaja: GeoServer <geoserver-devel@lists.sourceforge.net>
Aihe: [Geoserver-devel] GeoServer 2.20.3 available for preflight testingArtifacts available for testing here: https://build.geoserver.org/job/geoserver-release/43/artifact/distribution/2.20.3/
Release notes (no longer in jira): https://github.com/geoserver/geoserver/releases/tag/2.20.3
We are still watching the windows job have trouble with permissions, it creates the installer though which is the main thing.
Not aware of any special needs for testing, there is a new ENTITY_RESOLUTION_ALLOWLIST to try out.
Jody Garnett
