[Geoserver-devel] GeoServer 2.22.0 release artifacts ready for testing
the release artifacts are available here, if you have time for a quick test:
https://build.geoserver.org/view/release/job/geoserver-release/lastSuccessfulBuild/artifact/distribution/2.22.0/
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Hi, Andrea,
Thanks for the release - I did some quick tests.
a) I tried the bin release with both java 8 and java 11 on OSX with apple silicon (M1)
b) I didnt see any issues
I did some quick checks of the new base-map (World), and the new welcome page.
I also note the changes to the styles page as well as the logging.
Dave
David Blasby
Mobile:
E-mail: david.blasby@…2488…
https://www.geocat.net
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31318416664
---- On Thu, 17 Nov 2022 10:29:23 -0800 Andrea Aime andrea.aime@anonymised.com wrote —
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Geoserver-devel mailing list
Thanks David!
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
On 17-11-2022 19:29, Andrea Aime wrote:
I just succesfully deployed this in some of our containers (upgrading from 2.22-RC, looking good.
There's a small IMO cosmetic thing in the About page, but only when "nl" is selected.
It seems the builds has not expanded the version number etc. in the html:
GeoServer installatie
Geoserver Versie
@project.version@
Revisie
@build.revision@
Datum
@build.timestamp@
GeoTools Versie
28.0 (rev 93b0abe9bc755432862825e19306e8b8e7114c2d)
1.22.0 (rev 1.22.x/ba83cb90b873cb98b7f418f577a4ae8b3ec1adbf)
It's fine for eg. en, da and shows the same issue for some other languages.
- M
Doing some quick tests with war bundle: java temurin- 11.0.16.1+1) / apachine-tomcat-9.0.68
  1. Bundle:
  2. **Bundle does not readme and running instructions.**1. Quick test: bin/catalina.sh run
  3. Language chooser
  4. shows German and Dutch translation of welcome page description1. Natural Earth GeoPackage and workspace
  5. ne:world looks good1. Logging profile date formatting updates
  6. Logs have: “18 Nov. 08:17:23 INFO” with today’s date rather than milliseconds
  7. Startup logging messages - much improved
  8. Welcome Page Updates
  9. Welcome page is behaving correctly
  10. Contact information changes are good1. Style format displayed
  11. GWC security testing worked; turned off global services, made ne.* require authenticated
Docs:
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Hi Mark,
bummer… personally I don’t think it warrants a release do-over, can we open a ticket instead, and get it solved by 2.22.1?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Thanks!
  1. Bundle:
  2. Bundle does not readme and running instructions.
war files are not for the faint hearted, one should know what to do with them… but having the instructions
would be good. Also don’t think it’s new, I don’t see a README in the 2.21.x bundles either.
Ticket and fix by 2.22.1?
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Yep, please go ahead.
Maybe the way we build our docker image using the maven artifacts. I don’t understand why it is not consistent for all languages and Jody was unable to reproduce
Op vr 18 nov. 2022 18:31 schreef Andrea Aime <andrea.aime@anonymised.com>:
Hi Mark,
There’s a small IMO cosmetic thing in the About page, but only when “nl”
is selected.
Geoserver Versie
@project.version@
Revisie
@build.revision@
Datum
@build.timestamp@
GeoTools Versie
It’s fine for eg. en, da and shows the same issue for some other languages.
  • M
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Reopened the existing ticket: https://osgeo-org.atlassian.net/browse/GEOS-10606
Also checked the docs bundles.
And PR: https://github.com/geoserver/geoserver/pull/6367
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
