[Geoserver-devel] GeoServer 2.24.5 pre-release artifacts ready for testing
with a few days delay, here are the 2.24.5 release artifacts ready for quick review:
https://build.geoserver.org/view/release/job/geoserver-release/lastSuccessfulBuild/artifact/distribution/2.24.5/
Will wait for someone to give it a spin and then do a release.
By the way, while I was at it, I tried to re-create the “magical” environment needed to run the GWC release scripts, as a Dockerfile, and put out a PR for it:
https://github.com/GeoWebCache/gwc-release/pull/13
While it can use improvement, it’s probably enough for other to jump in, try, and suggest improvements.
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
Thanks Andrea,
I tested the bin distribution without incident:
  • That is fun about the GWC release script; what is the command line to run and connect into it?
  • RUNNING.html mentions downloading Java 17, but I now understand that this requires “extra effort” :stuck_out_tongue_winking_eye:
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Thank you!
All details on how to build and run are in the PR description. They should go into some README for sure, but I’ve already spent too much time on the current release,
hence my plea at the end of the description “can you review and possibly help to make this better?”
