[Geoserver-devel] GeoServer 2.24-RC build artifacts ready
build artifacts are available here for early testing before we publish:
https://build.geoserver.org/view/release/job/geoserver-release/123/artifact/distribution/2.24-RC/
Let me know if you spot any blocker!
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
The blog anouncement is here for review also
http://github.com/geoserver/geoserver.github.io/pull/162
Jody
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
No blockers just some feedback, we can collect all feedback into a ticket later.
bin
  • README.html looks good, the link to https://github.com/geoserver/geoserver/wiki/Sponsor can be replaced with https://geoserver.org/sponsor/
  • RUNNING.html correctly has Java 11 or Java 17, the form more help link could point to https://docs.geoserver.org/latest/en/user/installation (it presently just points to https://geoserver.org)
  • start.sh shows some unfamiliar log messages:
    5 Sep. 22:32:09 CONFIG [org.geoserver] - Loaded service ‘WMTSInfoImpl–3ef31051:182c1e8b194:-8000’, enabled
    25 Sep. 22:32:09 CONFIG [org.geoserver] - Loaded service ‘wcs’, enabled
    25 Sep. 22:32:09 CONFIG [org.geoserver] - Loaded service ‘wfs’, enabled
    25 Sep. 22:32:09 CONFIG [org.geoserver] - Loaded service ‘wms’, enabled
    25 Sep. 22:32:09 CONFIG [org.geoserver] - Loaded service ‘WMTSInfoImpl-1c443fee:182c0f3f209:-7f98’, enabled
    25 Sep. 22:32:09 CONFIG [org.geoserver] - Loaded service ‘WCSInfoImpl-1c443fee:182c0f3f209:-7f96’, enabled
    25 Sep. 22:32:09 CONFIG [org.geoserver] - Loaded service ‘WFSInfoImpl-1c443fee:182c0f3f209:-7f97’, enabled
    25 Sep. 22:32:09 CONFIG [org.geoserver] - Loaded service ‘WMSInfoImpl-1c443fee:182c0f3f209:-7f99’, enabled
    I am going to guess those are info objects being created from scratch; I guess I expected a short default like ‘wmts’, ‘wcs’, and no duplicates?
  • Usual GWC schema validation warning:
    25 Sep. 22:32:08 CONFIG [gwc.config] - Create configuration file ‘gwc/geowebcache.xml’ from template jar:file:/Users/jgarnett/Downloads/geoserver-2.24-RC-bin/webapps/geoserver/WEB-INF/lib/gwc-core-1.24-RC.jar!/geowebcache_empty.xml
    25 Sep. 22:32:08 WARN [config.XMLConfiguration] - GWC configuration validation error: cvc-elt.1.a: Cannot find the declaration of element ‘gwcConfiguration’.
    25 Sep. 22:32:08 WARN [config.XMLConfiguration] - Will try to use configuration anyway. Please check the order of declared elements against the schema.
  • User interface is correctly showing disabled fields (great!)
  • Layers display as expected
  • resources/log4j.properties - this can be removed?? It is an old log4j 1.2 configuration for jetty perhaps …
  • logs/keepme.txt - this folder is here but I do not see geoserver.log or anything being recorded here
  • license/*.html - these look good - but where is the GPL licence :slightly_smiling_face: everything else is here …
htmldoc
  • looks fine, even the api docs
  • LICENSE.html is CCbyA as expected
    javadocs
  • README.html is the same as bin release
  • I could not find the usual framed javadocs; maybe that is no longer a thing
    war
  • license/ is missing GPL.html also
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
