On Thu, Nov 20, 2014 at 7:15 PM, Andrea Aime <andrea.aime@anonymised.com>
wrote:
On Thu, Nov 20, 2014 at 6:47 PM, Ian Schneider <
ischneider@anonymised.com> wrote:
I actually saw this a few weeks ago but thought it was a build error
related to me using the wrong maven repo.
I found the problem: https://bugzilla.mozilla.org/show_bug.cgi?id=1083090
tl;dr: we're sending bogus content-length headers back with gzip
compressed resources
To verify, go to about:config and search for gzip. Remove
the network.http.accept-encoding values (gzip and deflate) and reload the
page - it should work.
Hum... I'm confused, I changed the gzipfilter recently to avoid making it
go OOM on large GML
outputs, but I don't see it setting the content-lenght anymore. It used
to, but I've removed that part,
and the GZIPResponseWrapper actually kills every attempt at setting the
content
lenght from the other geoserver code?
Also, asking for
http://localhost:8080/geoserver/web/resources/org.geoserver.web.GeoServerBasePage/css/geoserver.css
I get the full file in Firefox
However, if I make the req request via curl:
curl -sH 'Accept-encoding: gzip' -D - -o /tmp/test.out "
HTTP/1.1 200 OK
Expires: Thu, 20 Nov 2014 19:18:10 GMT
Set-Cookie: JSESSIONID=1xgphycxw49gs;Path=/geoserver
Last-Modified: Mon, 17 Nov 2014 09:39:28 GMT
Cache-Control: max-age=3600
Content-Type: text/css; charset=UTF-8
*Content-Length: 19882*
Content-Encoding: gzip
Server: Jetty(6.1.8)
Ha! Hum... something must be going on, because the wrapper is trying to
prevent the code setting the content-lenght by overriding
that method...
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
