Can't run geoserver after adding hibernate monitoring plugin.
If somebody knows the reason pls help. Thaks in advice.
JDK version 1.7.0_80 (I tryed x64 and x86) OS Windows 10 x64, i also tryed
on win server 2008 r2
Here is geoserver log:
C:\Program Files (x86)\GeoServer 2.7.1.1\bin>call "C:\Program Files
(x86)\Java\jdk1.7.0_80\bin\java.exe" -DGEOSERVER_DATA_DIR="C:\Program Files
(x86)\GeoServer 2.7.1.1\data_dir" -Xmx512m -XX:MaxPermSize=128m
-DSTOP.PORT=8079 -DSTOP.KEY=geoserver -Djetty.port=8080
-Djetty.logs="C:\Program Files (x86)\GeoServer 2.7.1.1\logs" -jar
"C:\Program Files (x86)\GeoServer 2.7.1.1\start.jar"
2017-08-05 12:35:01.710::INFO: Logging to STDERR via
org.mortbay.log.StdErrLog
2017-08-05 12:35:01.790::WARN: Deprecated configuration used for C:\Program
Files (x86)\GeoServer 2.7.1.1/webapps
2017-08-05 12:35:01.807::INFO: jetty-6.1.8
рту 05, 2017 12:35:02 PM org.geoserver.platform.GeoServerExtensions
checkContext
WARNING: Extension lookup 'XStreamPersisterInitializer', but
ApplicationContext is unset.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
2017-08-05 12:35:02.740:/geoserver:INFO: Initializing Spring root
WebApplicationContext
рту 05, 2017 12:35:03 PM org.geoserver.platform.GeoServerExtensions
checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but
05 рту 12:35:03 INFO [config.GeoServerPropertyConfigurer] - Loading
properties file from URL
[file:/C:/Program%20Files%20(x86)/GeoServer%202.7.1.1/data_dir/monitoring/hibernate.properties]
05 рту 12:35:03 INFO [geoserver.monitor] - Configuring monitoring database
2.7.1.1\data_dir\monitoring\db.properties
05 рту 12:35:03 WARN [support.DisposableBeanAdapter] - Invocation of destroy
method failed on bean with name 'geoServerLoader':
java.lang.NullPointerException
05 рту 12:35:03 ERROR [context.ContextLoader] - Context initialization
failed
org.springframework.beans.factory.BeanCreationException: Error creating bean
with name 'controlFlowCallbackProxy' defined in URL
[jar:file:/C:/Program%20Files%20(x86)/GeoServer%202.7.1.1/webapps/geoserver/WEB-INF/lib/gs-monitor-core-2.7.1.1.jar!/applicationContext.xml]:
Cannot resolve reference to bean 'monitor' while setting constructor
argument; nested exception is
with name 'monitor' defined in URL
Instantiation of bean failed; nested exception is
org.springframework.beans.BeanInstantiationException: Could not instantiate
bean class [org.geoserver.monitor.Monitor]: Constructor threw exception;
nested exception is org.springframework.beans.factory.BeanCreationException:
Error creating bean with name 'hibMonitorDAO' defined in URL
[jar:file:/C:/Program%20Files%20(x86)/GeoServer%202.7.1.1/webapps/geoserver/WEB-INF/lib/gs-monitor-hibernate-2.7.1.1.jar!/applicationContext-hib2.xml]:
Cannot resolve reference to bean 'hibSessionFactory' while setting bean
property 'sessionFactory'; nested exception is
with name 'hibSessionFactory' defined in URL
Invocation of init method failed; nested exception is
java.lang.NoClassDefFoundError: javassist/util/proxy/MethodFilter
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:329)
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:107)
at
org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:630)
at
org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at
org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
at
org.springframework.context.support.AbstractApplicationContext.registerBeanPostProcessors(AbstractApplicationContext.java:746)
at
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:457)
at
org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:388)
at
org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:293)
at
org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
at
org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:23)
at
org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at
org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at
org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at
org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at
org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at
org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
at
org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
at
at
at
at
org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
Caused by: org.springframework.beans.factory.BeanCreationException: Error
creating bean with name 'monitor' defined in URL
at
org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:288)
at
at
at
at
at
at
at
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:323)
... 39 more
Caused by: org.springframework.beans.BeanInstantiationException: Could not
instantiate bean class [org.geoserver.monitor.Monitor]: Constructor threw
exception; nested exception is
at
org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:162)
at
org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:121)
at
org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:280)
... 48 more
at
at
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1360)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1118)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517)
at
at
at
at
at
at
org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1105)
at
org.geoserver.platform.GeoServerExtensions.getBean(GeoServerExtensions.java:227)
at
org.geoserver.platform.GeoServerExtensions.extensions(GeoServerExtensions.java:168)
at
org.geoserver.platform.GeoServerExtensions.extensions(GeoServerExtensions.java:264)
at
org.geoserver.monitor.MonitorConfig.createDAO(MonitorConfig.java:164)
at org.geoserver.monitor.Monitor.<init>(Monitor.java:61)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native
Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:526)
at
org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:147)
... 50 more
creating bean with name 'hibSessionFactory' defined in URL
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1455)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
at
at
at
at
at
at
... 70 more
Caused by: java.lang.NoClassDefFoundError: javassist/util/proxy/MethodFilter
at
org.hibernate.bytecode.javassist.BytecodeProviderImpl.getProxyFactoryFactory(BytecodeProviderImpl.java:49)
at
org.hibernate.tuple.entity.PojoEntityTuplizer.buildProxyFactoryInternal(PojoEntityTuplizer.java:203)
at
org.hibernate.tuple.entity.PojoEntityTuplizer.buildProxyFactory(PojoEntityTuplizer.java:181)
at
org.hibernate.tuple.entity.AbstractEntityTuplizer.<init>(AbstractEntityTuplizer.java:158)
at
org.hibernate.tuple.entity.PojoEntityTuplizer.<init>(PojoEntityTuplizer.java:76)
at
org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping.<init>(EntityEntityModeToTuplizerMapping.java:80)
at
org.hibernate.tuple.entity.EntityMetamodel.<init>(EntityMetamodel.java:325)
at
org.hibernate.persister.entity.AbstractEntityPersister.<init>(AbstractEntityPersister.java:457)
at
org.hibernate.persister.entity.SingleTableEntityPersister.<init>(SingleTableEntityPersister.java:131)
at
org.hibernate.persister.PersisterFactory.createClassPersister(PersisterFactory.java:84)
at
org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:261)
at
org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1327)
at
org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:860)
at
org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:779)
at
org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:188)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1514)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1452)
... 77 more
Caused by: java.lang.ClassNotFoundException:
javassist.util.proxy.MethodFilter
at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
at
org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:366)
at
org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:337)
... 94 more
2017-08-05 12:35:03.201::WARN: Failed startup of context
org.mortbay.jetty.webapp.WebAppContext@anonymised.com{/geoserver,file:/C:/Program%20Files%20(x86)/GeoServer%202.7.1.1/webapps/geoserver/}
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 39 more
at
at
at
... 48 more
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Method)
at
at
at
... 50 more
at
at
at
at
at
at
at
at
... 70 more
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 77 more
at
at
... 94 more
2017-08-05 12:35:03.286::WARN: Nested in
java.lang.NoClassDefFoundError: javassist/util/proxy/MethodFilter:
java.lang.ClassNotFoundException: javassist.util.proxy.MethodFilter
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Method)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
2017-08-05 12:35:04.364::INFO: Opened C:\Program Files (x86)\GeoServer
2.7.1.1\logs\2017_08_05.request.log
2017-08-05 12:35:04.380::INFO: Started SelectChannelConnector@anonymised.com:8080
View this message in context: http://osgeo-org.1560.x6.nabble.com/Geoserver-2-7-1-1-Monitoring-plugin-tp5330561.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
