After some testing, I found a small difference between 2.6.2 and 2.7-rc1. But I think there is no bug, just misunderstanding by me.
As the documentation says " (...) If a permission at the global level is not specified, global permissions are assumed to allow read/write access. If a permission for a workspace is not specified, it inherits permissions from the global specification. If a permission for a layer is not specified, it inherits permissions from its workspace specification. (...)"
I thought I have to deny all access in first place in order to be able to follow a "white-list" approach.
- Check 1: Deletion of default data security rules
*.*.r *
*.*.w *
GeoServer 2.6.2: Not possible, they are getting re-created automatically
GeoServer 2.7-rc1: Not possible, they are getting re-created automatically
- Check 2: Limitation of layer access
Adding:
topp.states.r testrole
GeoServer 2.6.2: OK: Layer "states" only readable for role "testrole"
GeoServer 2.7-rc1: OK: Layer "states" only readable for role "testrole"
after adding the new rule, I am able to remove both default rules on both versions. As expected, this has no effect on security
And this is where the differences occurs:
GeoServer 2.6.2: All layers except layer "topp.states" are shown in layer preview and are accessible via WMS for unauthorized users
(Like I expected)
GeoServer 2.7-rc1: All layers except all layers of workspace topp are shown in layer preview. This is not what I have expected.
To summarize:
* I was confused by the fact, that deletion of both default security rules does not has any effect. The still remain active but are invisible.
I expected the deletion to make them inactive. Maybe it should be really be impossible to remove them from the GUI or the removal should have an effect
* Maybe a minor issue: Contents shown in layer preview for unprivileged users differ between GeoServer 2.6.2 and 2.7-rc1 in my testcase
Best regards,
Patric
web www.geops.de
rss www.geops.de/blog/feed
follow www.twitter.com/geops
On 03/17/2015 04:36 PM, Andrea Aime wrote:
On Mon, Mar 16, 2015 at 9:00 PM, Jody Garnett <jody.garnett@anonymised.com
<mailto:jody.garnett@anonymised.com>> wrote:
First up thanks for testing, I am not aware of any security changes
in 2.7 (it did not make the short list of features we asked for help
testing).
We had some changes as part of the jdbcconfig scalability work,
https://github.com/geoserver/geoserver/pull/836
If this is confirmed to be a problem, I'd call it a relase blocker.
I won't be able to have a look before late tonight (mountain time) though
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio
stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti,
copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento
contrario ai principi dettati dal D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
Protection Code).Any use not in accord with its purpose, any disclosure,
reproduction, copying, distribution, or either dissemination, either
whole or partial, is strictly forbidden except previous formal approval
of the named addressee(s). If you are not the intended recipient, please
contact immediately the sender by telephone, fax or e-mail and delete
the information in this message that has been received in error. The
sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility
for changes made after they were sent or for other risks which arise as
a result of e-mail transmission, viruses, etc.
