[Geoserver-devel] geoserver-2.7.x build fixed by removing -T2
I was able to fix my shiny new geoserver-2.7.x build on ares by removing -T2 from the maven command line. It now takes an hour. But it passes.
-T2 builds up to two modules concurrently. It also acts as an unintended nondeterministic detector for non-thread-safe test fixtures, and makes maven log output nearly incomprehensible. But it makes maven much faster too.
Ben Caradoc-Davies <ben@anonymised.com>
Software Engineer
Transient Software <http://transient.nz>
New Zealand
On Sun, Feb 22, 2015 at 3:08 AM, Ben Caradoc-Davies <ben@anonymised.com>
too.
Yes, the -T2 was added because build times were unbearably slow. Any clue
as to which tests were failing due to the concurrency?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hi Ben,
as far as I can see there was a single build failing, and the one test failed in it had this assertion fail:
File dd = getTestData().getDataDirectoryRoot();
File wfs = new File(dd, “wfs”);
File transform = new File(wfs, “transform”);
if (transform.exists()) {
FileUtils.deleteDirectory(transform);
assertTrue(transform.mkdirs());
So it’s trying to make sure a certain directory in the test data dir exists but is empty.
I’m not sure why it failed the first time, but since each tests runs in its own randomly generated
data directory, I don’t see how this can be related to concurrency either
On Sun, Feb 22, 2015 at 8:45 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sun, Feb 22, 2015 at 3:08 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
too.
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
