[Geoserver-devel] geoserver 2.8.x branch build error on htmlvalidator-1.2.pom - how to resolve?
[ERROR] Failed to execute goal on project gs-web-core: Could not resolve depende
ncies for project org.geoserver.web:gs-web-core:jar:2.8-SNAPSHOT: Failed to coll
ect dependencies at org.wicketstuff:htmlvalidator:jar:1.2: Failed to read artifa
ct descriptor for org.wicketstuff:htmlvalidator:jar:1.2: Could not transfer arti
fact org.wicketstuff:htmlvalidator:pom:1.2 from/to boundless (https://boundless.
artifactoryonline.com/boundless/snapshot/): Failed to transfer file: https://bou
ndless.artifactoryonline.com/boundless/snapshot/org/wicketstuff/htmlvalidator/1.
2/htmlvalidator-1.2.pom. Return code is: 409 , ReasonPhrase:Conflict. → [Help 1
If I plug the URL (https://boundless.artifactoryonline.com/boundless/snapshot/org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom) into my browser I get…
“errors” : [ {
“status” : 409,
“message” : “The repository ‘snapshot’ rejected the artifact ‘snapshot:org/wicketstuff/htmlvalidator/1.2/htmlvalidator-1.2.pom’ due to its snapshot/release handling policy.”
I got past this error by copying the .m2 directory from another workstation and doing an offline build.
(attachments)
ATT00001.txt (80 Bytes)
ATT00002.txt (180 Bytes)
Sent: Wednesday, November 04, 2015 3:51 AM
To: geoserver-devel@lists.sourceforge.net
Subject: [Geoserver-devel] geoserver 2.8.x branch build error on htmlvalidator-1.2.pom - how to resolve?
“errors” : [ {
“status” : 409,
Thanks for the detailed problem report, I will pass it on to the administrator. Is there a public repo for that dependency?
On Wed, Nov 4, 2015 at 11:40 AM Walter Stovall <walter.stovall@anonymised.com> wrote:
“errors” : [ {
“status” : 409,
Geoserver-devel mailing list
Jody Garnett
Hi Jody,
that jar it too old and cannot be found anymore in the main repos, the oldest version available seems to be 1.5:
http://mvnrepository.com/artifact/org.wicketstuff.htmlvalidator/wicketstuff-htmlvalidator
That’s probably not compatible however, requires wicket 1.5, we are using 1.4
This is part of the reason why we want to upgrade Wicket… in the meantime, that
jar should be uploaded into artifactory manually
On Fri, Nov 6, 2015 at 4:50 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
“errors” : [ {
“status” : 409,
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I uploaded 1.2 (which was what the original bug report called for). However we may need to change the pom.xml
boundless Boundless Maven Repository [https://boundless.artifactoryonline.com/boundless/main/](https://boundless.artifactoryonline.com/boundless/main/) true
Can you try uncommenting (so the 1.2 jar can be found), or use maven command line (and your OSGeo credentials) to deploy to the OSGeo repo.
Jody
On 6 November 2015 at 08:14, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Jody,
Jody Garnett
“errors” : [ {
“status” : 409,
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
