Sorry for being late in the play.
I slightly amended the post to reflect andrea+ alessandro's help and I
also asked andrea to add a few more points which have been released
together with this release.
A quick suggestion, please, next time start a separate thread for the
blog post otherwise it is easy to overlook messages like this one in
an ongoing flow of discussion.
Thx everybody for the hard work towards 2.9!
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Sat, May 28, 2016 at 12:01 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Thanks for helping Alex, we will proceed with the release.
For PSC members their is a draft blog post waiting your review, we will
publish Monday morning.
Jody Garnett
On 27 May 2016 at 14:53, Alex Goudine <agoudine@anonymised.com> wrote:
GeoServer 2.9 system independent binary works on Ubuntu 14.04 (after
installing Java 8)
On Fri, May 27, 2016 at 2:14 PM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
Windows 7 Install (background service)
- working! (installed on fresh system)
- uninstall - work folder still orphaned by uninstall (so some manual
clean up is needed)
Windows 7 Install (manual start)
- worked as expected
- uninstalled cleanly
Jody Garnett
On 27 May 2016 at 12:40, Jody Garnett <jody.garnett@anonymised.com> wrote:
Preflight artifacts are available for testing:
- http://ares.boundlessgeo.com/geoserver/release/2.9.0/
I think we flushed out most of the packaging / installer trouble during
the RC, today we get to see the results!
Feedback on linux, windows, mac encouraged, please respond to this post.
Jody Garnett
What NetFlow Analyzer can do for you? Monitors network bandwidth and
traffic
patterns at an interface-level. Reveals which users, apps, and protocols
are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning reports.
https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
Geoserver-devel mailing list
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
planning reports. https://ad.doubleclick.net/ddm/clk/305295220;132659582;e
