jive
1
Avaialble on ares: http://ares.boundlessgeo.com/geoserver/release/2.9.3/
It looks like DMG and EXE generated correctly, please reply to this thread with testing results.
Release notes are here (if you would like to double check what has changed).
Jody Garnett
I tried the exe installer on Windows 10 with manual start. It installs and runs.
If I try to change the port into 8089 it starts at the default port 8080.
I do not quite remember all the discussion we had around
https://osgeo-org.atlassian.net/browse/GEOS-7677 but it was about installing as a service, not for manual start.
Installer writes now the user given port into startup.bat by adding:
-Djetty.port=8089
However, it does not have an effect. I wonder if there should be something about --module=http as well
-Jukka Rahkonen-
Lähettäjä: Jody Garnett jody.garnett@anonymised.com
Lähetetty: 23. marraskuuta 2016 3:08
Vastaanottaja: Geoserver Developers
Aihe: [Geoserver-devel] GeoServer 2.9.3 preflight testing
Jody Garnett
jive
3
Bleck, well this is why we do preflight testing. I wonder if this was just fixed on master and not backported…
https://github.com/geoserver/geoserver/pull/1924/files
On 22 November 2016 at 23:39, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
-Djetty.port=8089
-Jukka Rahkonen-
Lähettäjä: Jody Garnett <jody.garnett@anonymised.com>
Jody Garnett
Jody Garnett
From jira (https://osgeo-org.atlassian.net/browse/GEOS-7677) it claims to have been back ported
Ian
On 23 November 2016 at 08:05, Jody Garnett <jody.garnett@anonymised.com> wrote:
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Jody Garnett
On 22 November 2016 at 23:39, Rahkonen Jukka (MML) <jukka.rahkonen@maanmittauslaitos.fi> wrote:
-Djetty.port=8089
-Jukka Rahkonen-
Jody Garnett
Ian Turton
Lähetetty Windows Phonesta
Geoserver-devel@…366…sourceforge.net
Jody Garnett
-Djetty.port=8089
-Jukka Rahkonen-
Lähettäjä: Jody Garnett <jody.garnett@…403…>
Jody Garnett
Ian Turton
jive
6
Revised artifacts available for testing:
On 22 November 2016 at 17:08, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Jody Garnett
Tested the manual install of GeoServer on Windows 2012. Changed the default
port successfully with no issues.
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoServer-2-9-3-preflight-testing-tp5297037p5297345.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
