[Geoserver-devel] geoserver 2.9-beta2 preflight testing
Available for testing here:
I am downloading and testing the DMG. Given the amount of changes in this beta2 I would appreciate confirmation the application starts up (ie is packaged correctly) on a range of platforms (linux, windows, etc…) before we announce.
Jody Garnett
Unable to start DMG… is the Java Cryptography Extension required?
Jody Garnett
Jody Garnett
Testing the bin release failed even sooner - no JAI packaged?
2016-04-18 21:45:46.417:WARN:oejuc.AbstractLifeCycle:main: FAILED o.e.j.w.WebAppContext@anonymised.com{/geoserver,file:/Users/jody/Downloads/geoserver-2.9-beta2/webapps/geoserver/,STARTING}{/geoserver}: java.lang.NoClassDefFoundError: Could not initialize class javax.media.jai.JAI
at org.geoserver.GeoserverInitStartupListener.contextInitialized(GeoserverInitStartupListener.java:88)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:800)
Jody Garnett
Jody Garnett
Testing with the war on Tomcat (7.0.52) on Kubuntu 14.04 plus all the package updates to today.
GeoServer Version 2.9-beta2
Git Revision 7026d8e9a934f2e854c8116e5a8ac52063c3c11c
Build Date 19-Apr-2016 03:28
GeoTools Version 15-beta2 (rev c38b6f373bdb76a731b78cba0e1cb58f7ce06288)
GeoWebCache Version 1.9-beta2 (rev master/806006ed652e11d6f3d4ea694d15a16a989a4852)
On trying to log in, it just goes to:
http://localhost:8080/geoserver/web/wicket/j_spring_security_check
Layer preview seems good - tried each layer, and tried each output format for the Tasmanian Cities (city) layer. All seem OK (well, the world polygon looked ugly and grey, but it always does, so that is still tolerable :-)).
Brad
Same here. The login failure from the preview page is known and tracked in
this ticket, it is
something someone definitely needs to fix before RC1.
Actually it seems that we have duplicate reports about it (from two people
sitting in the same office?):
https://osgeo-org.atlassian.net/browse/GEOS-7502
https://osgeo-org.atlassian.net/browse/GEOS-7482
Kevin's report is interesting (the observation about web/wicket in the path
seemingly being the trigger)
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Tested the Jetty artifact in both Oracle and OpenJDK on Ubuntu GNOME 15.04 The only problem I encountered was the 404 () when trying to log in from certain pages. (GEOS-7482)
[http://localhost:8080/geoserver/web/wicket/j_spring_security_check](http://localhost:8080/geoserver/web/wicket/j_spring_security_check)
Brad
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
[https://ad.doubleclick.net/ddm/clk/302982198;130105516;z](https://ad.doubleclick.net/ddm/clk/302982198;130105516;z)
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comsourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Otherwise I was able to log in, view layer previews, and create a layer.
Kevin Michael Smith
[<smithkm@anonymised.com>](mailto:smithkm@anonymised.com)
Testing startup
Windows 7
java -version
java version “1.8.0_74”
Java™ SE Runtime Environment (build 1.8.0_74-b02)
Java HotSpot™ 64-Bit Server VM (build 25.74-b02, mixed mode)
The GEOSERVER_HOME environment variable is not defined.
Temporarily setting GEOSERVER_HOME to the following directory:
F:\Downloads\GIS Software\geoserver-2.9-beta2
WARNING: Module not found [ssl]
java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:79)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at java.net.Socket.connect(Socket.java:538)
at java.net.Socket.(Socket.java:434)
at java.net.Socket.(Socket.java:244)
at org.eclipse.jetty.start.Main.stop(Main.java:869)
at org.eclipse.jetty.start.Main.stop(Main.java:848)
at org.eclipse.jetty.start.Main.doStop(Main.java:839)
at org.eclipse.jetty.start.Main.start(Main.java:692)
at org.eclipse.jetty.start.Main.main(Main.java:112)
Usage: java -jar start.jar [options] [properties] [configs]
java -jar start.jar --help # for more information
Press any key to continue . . .
Second startup via start.bat results
Welcome to GeoServer!
JAVA_HOME: c:\Program Files\Java\jdk1.8.0_74
The GEOSERVER_DATA_DIR environment variable is not defined correctly.
Temporarily setting GEOSERVER_DATA_DIR to the following directory:
F:\Downloads\GIS Software\geoserver-2.9-beta2\data_dir
Please wait while loading GeoServer…
2016-04-19 11:13:42.236:INFO::main: Logging initialized @319ms
2016-04-19 11:13:42.488:INFO:oejs.Server:main: jetty-9.2.13.v20150730
2016-04-19 11:13:42.505:INFO:oejdp.ScanningAppProvider:main: Deployment monitor [file:/F:/Downloads/GIS%20Software/geoserver-2.9-beta2/webapps/] at interval 1
2016-04-19 11:13:43.816:INFO:oejw.StandardDescriptorProcessor:main: NO JSP Support for /geoserver, did not find org.eclipse.jetty.jsp.JettyJspServlet
Apr 19, 2016 11:13:45 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup ‘XStreamPersisterInitializer’, but ApplicationContext is unset.
WARNING: Extension lookup ‘ExtensionFilter’, but ApplicationContext is unset.
WARNING: Extension lookup ‘ExtensionProvider’, but ApplicationContext is unset.
19 Apr 11:13:54 INFO [org.geoserver] - GeoServer configuration lock is enabled
19 Apr 11:13:54 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs] onto handler ‘dispatcher’
19 Apr 11:13:54 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wcs/**] onto handler ‘dispatcher’
19 Apr 11:13:55 INFO [ows.OWSHandlerMapping] - Mapped URL path [/TestWfsPost] onto handler ‘wfsTestServlet’
19 Apr 11:13:55 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs/*] onto handler ‘dispatcher’
19 Apr 11:13:55 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wfs] onto handler ‘dispatcher’
19 Apr 11:13:59 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms] onto handler ‘dispatcher’
19 Apr 11:13:59 INFO [ows.OWSHandlerMapping] - Mapped URL path [/wms/*] onto handler ‘dispatcher’
19 Apr 11:13:59 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate/*] onto handler ‘dispatcher’
19 Apr 11:13:59 INFO [ows.OWSHandlerMapping] - Mapped URL path [/animate] onto handler ‘dispatcher’
19 Apr 11:13:59 INFO [geoserver.security] - AuthenticationCache Initialized with 1000 Max Entries, 300 seconds idle time, 600 seconds time to live and 3 concurrency level
19 Apr 11:13:59 INFO [geoserver.security] - AuthenticationCache Eviction Task created to run every 600 seconds
19 Apr 11:13:59 INFO [geoserver.security] - Start reloading user/groups for service named default
19 Apr 11:13:59 INFO [geoserver.security] - Reloading user/groups successful for service named default
2016-04-19 11:13:59.839:INFO:oejsh.ContextHandler:main: Started o.e.j.w.WebAppContext@…4420…{/geoserver,file:/F:/Downloads/GIS%20Software/geoserver-2.9-beta2/webapps/geoserver/,AVAILABLE}{F:\Downloads\GIS Software\geoserver-2.9
beta2\webapps\geoserver}
2016-04-19 11:13:59.907:INFO:oejs.ServerConnector:main: Started ServerConnector@…4421…{HTTP/1.1}{0.0.0.0:8080}
2016-04-19 11:13:59.908:INFO:oejs.Server:main: Started @17991ms
Logged in with admin/etc
cid:image002.png@...4422...
Verified each Link on left menu
Layer Preview (OpenLayers format)
nurc:mosaic
nurc:Img_Sample
sf:streams
Created a new Workspace
Created new GeoTIFF store in new workspace
Published Layer
Previewed New Layer
Verified Layers Screen (single page worth of data)
Verified Layer Groups Screen (single page worth of data)
Verified Styles link
Edited Capitals Style
Changed size to 16
Stroke to #0000FF
Fill to #FFFF00
Verified Preview legend renders new style without Submitting (broken 2.8.3)
Validated
Submitted
Verified Services > WCS displays
Verified Services > WFS displays
Verified Services > WMS displays
Verified Settings > Global displays (Log level change, submit works)
Verified Settings > Image Processing displays (No changes, submit works)
Verified Settings > Raster Access displays (No changes, submit works)
Verified Tile Caching > Tile Layers
(nurc:Pk50095 listed as Enabled Exclamation Symbol)
Verified preview geoserver/gwc/demo/spearfish?gridSet=EPSG:4326&format=image/jpeg
Tile Caching > Caching Defaults
Followed link to “embedded GeoWebCache home page”
No Link from embedded GeoWebCache home page back to GeoServer proper
Followed link to “A list of all the layers and automatic demos”
Followed link to sf:bugsites > Seed this layer
Verified Seeding (geoserver/gwc/rest/seed/sf:bugsites) defaults entered, 1,378 tiles generated
Used browser BACK button to get back to GeoServer proper (Caching Defaults page)
Selected Tile Caching > Tile Layers
Selected “spearfish”
Exception (page ref: geoserver/web/wicket/page?67)
org.apache.wicket.WicketRuntimeException: Method onRequest of interface org.apache.wicket.behavior.IBehaviorListener targeted at org.apache.wicket.ajax.markup.html.AjaxLink$1@…4423… on component [AjaxLink [Component id = link]] threw an exception at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:268) at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:241) at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.invokeListener(ListenerInterfaceRequestHandler.java:248) at org.apache.wicket.core.request.handler.ListenerInterfaceRequestHandler.respond(ListenerInterfaceRequestHandler.java:234) at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:865)
Caused by: java.lang.reflect.InvocationTargetException at sun.reflect.GeneratedMethodAccessor278.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258) … 101 more Caused by: java.lang.IllegalArgumentException: Argument ‘value’ may not be null. at org.apache.wicket.util.lang.Args.notNull(Args.java:41) at org.apache.wicket.request.mapper.parameter.PageParameters.add(PageParameters.java:291) at org.apache.wicket.request.mapper.parameter.PageParameters.add(PageParameters.java:284) at org.apache.wicket.request.mapper.parameter.PageParameters.add(PageParameters.java:278) at org.geoserver.gwc.web.layer.ConfigureCachedLayerAjaxLink.onClick(ConfigureCachedLayerAjaxLink.java:71) at org.geoserver.web.wicket.SimpleAjaxLink$1.onClick(SimpleAjaxLink.java:47) at org.apache.wicket.ajax.markup.html.AjaxLink$1.onEvent(AjaxLink.java:84) at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:155) at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:588) … 105 more
Selecting any other page, back to tile layers, spearfish always fails, URL in address bar changes, incrementing the ?## value
Verified Tile Caching > Gridsets
Verified Create a Copy of EPSG:4326 to US_EPSG:4326
Verified Display of EPSG:4326 (internal not modifiable)
Verified Tile Caching > Disk Quota
Verified Enabled; In process; Save;
Verified returns to Home screen
Verified Tile Caching > Disk Quota Displays
Verified Security > Settings Displays
Verified Security > Authentication Displays
Verified Security > Passwords Displays
Verified Security > Users, Groups, and Roles Displays
Verified Security > Data Displays
Verified Security > Tools Displays
Verified Demos Displays
Demo Requests
Choose WCS_describeCoverage.xml
URL populates, Body Populates
Submit
EXCEPTION
Error screen ( Log Exception)
ERROR: ‘Could not find the specified coverage: nurc:Pk50095’
19 Apr 11:55:26 ERROR [geoserver.ows] -
java.io.IOException
at org.geoserver.wcs.response.Wcs10DescribeCoverageResponse.write(Wcs10DescribeCoverageResponse.java:38)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:991)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:870)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at java.lang.Thread.run(Thread.java:745)
Caused by: javax.xml.transform.TransformerException: org.vfny.geoserver.wcs.WcsException: Could not find the specified coverage: nurc:Pk50095
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:746)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:351)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:300)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:112)
at org.geoserver.wcs.response.Wcs10DescribeCoverageResponse.write(Wcs10DescribeCoverageResponse.java:36)
… 85 more
Caused by: org.vfny.geoserver.wcs.WcsException: Could not find the specified coverage: nurc:Pk50095
at org.geoserver.wcs.response.Wcs10DescribeCoverageTransformer$WCS100DescribeCoverageTranslator.encode(Wcs10DescribeCoverageTransformer.java:190)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:1026)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transformIdentity(TransformerImpl.java:668)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.java:737)
… 90 more
Close Popup window
Select ANY other Request from drop down:
URL changes
Body is blank
Submitting always produces exception
OR
Verified Tools Displays
Confirmed the logout > Layer Preview redirect issue redirects to 404
Source Page:
geoserver/web/wicket/bookmarkable/org.geoserver.web.demo.MapPreviewPage?1
the form behind the Login button has (bold emphasis added)
Username
Expected Result Page:
geoserver/web/?3 (some number on the end)
Actual Result Page:
geoserver/web/wicket/j_spring_security_check (404)
I modified the form post with FireFox developer tools to
Username
And logged in successfully
I will try to test the WAR version on this platform this afternoon or tomorrow, but can’t promise completion as work may get in the way J.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Description: Description: Description: cid:image001.png@...3926...
(attachments)
Jody Garnett
I see the same error as Jody when trying to start the OS X dmg.
Torben
(attachments)
On Tue, Apr 19, 2016 at 11:26 AM, Chris Snider <chris.snider@anonymised.com> wrote:
Testing startup
Windows 7
java -version
2016-04-19 11:13:59.839:INFO:oejsh.ContextHandler:main: Started o.e.j.w.WebAppContext@anonymised.com{/geoserver,file:/F:/Downloads/GIS%20Software/geoserver-2.9-beta2/webapps/geoserver/,AVAILABLE}{F:\Downloads\GIS Software\geoserver-2.9
2016-04-19 11:13:59.907:INFO:oejs.ServerConnector:main: Started ServerConnector@anonymised.com{HTTP/1.1}{0.0.0.0:8080}
cid:image002.png@anonymised.com
nurc:mosaic
nurc:Img_Sample
sf:streams
Published Layer
Previewed New Layer
Changed size to 16
Stroke to #0000FF
Fill to #FFFF00
Validated
Submitted
Demo Requests
Submit
EXCEPTION
java.io.IOException
… 85 more
… 90 more
Close Popup window
URL changes
Body is blank
OR
Source Page:
Username
Actual Result Page:
Username
Chris Snider
Description: Description: Description: cid:image001.png@anonymised.com926...
From: Jody Garnett [mailto:jody.garnett@anonymised.com]
Sent: Monday, April 18, 2016 10:33 PM
To: Geoserver Developers <geoserver-devel@lists.sourceforge.net>
Subject: [Geoserver-devel] geoserver 2.9-beta2 preflight testing
Jody Garnett
Removing ~/Library/Java/Extensions allowed bin release to start up on mac.
This matches Kevin’s experience on linux.
Jody Garnett
Jody Garnett
Jody Garnett
Able to start bin download on windows (got a bit confused in testing as java updated itself making JAVA_HOME wrong).
Opened a small issue GEOS-7506 - shutdown.bat cannot run without JAVA_HOME set but windows bin is good to go.
Jody Garnett
Jody Garnett
Testing windows service install - does not start.
(!) Error Service Control Manager “The GeoServer 2.9-beta2 service terminated with service-specific error Incorrect function…”
Could not find logs, taking a wild guess and changing permissions on the data directory did not fix anything.
Found the wrapper logs:
STATUS | wrapper | 2016/04/20 09:30:18 | GeoServer 2.9-beta2 installed.
STATUS | wrapper | 2016/04/20 09:30:18 | Starting the GeoServer 2.9-beta2 service…
STATUS | wrapper | 2016/04/20 09:30:18 | → Wrapper Started as Service
STATUS | wrapper | 2016/04/20 09:30:18 | Java Service Wrapper Community Edition 3.3.3
STATUS | wrapper | 2016/04/20 09:30:18 | Copyright (C) 1999-2009 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2016/04/20 09:30:18 | http://wrapper.tanukisoftware.org
STATUS | wrapper | 2016/04/20 09:30:18 | Launching a JVM…
INFO | wrapper | 2016/04/20 09:30:23 | Waiting to start…
INFO | jvm 1 | 2016/04/20 09:30:24 | WrapperManager: Initializing…
INFO | jvm 1 | 2016/04/20 09:30:25 | WrapperSimpleApp: Unable to locate the class org.mortbay.start.Main: java.lang.ClassNotFoundException: org.mortbay.start.Main
INFO | jvm 1 | 2016/04/20 09:30:25 | WrapperSimpleApp Usage:
INFO | jvm 1 | 2016/04/20 09:30:25 | java org.tanukisoftware.wrapper.WrapperSimpleApp {app_class} [app_arguments]
INFO | jvm 1 | 2016/04/20 09:30:25 | Where:
INFO | jvm 1 | 2016/04/20 09:30:25 | app_class: The fully qualified class name of the application to run.
INFO | jvm 1 | 2016/04/20 09:30:25 | app_arguments: The arguments that would normally be passed to the
INFO | jvm 1 | 2016/04/20 09:30:25 | application.
ERROR | wrapper | 2016/04/20 09:30:27 | JVM exited while loading the application.
Jody Garnett
Jody Garnett
Thanks for the testing Jody. I’ll take a look at the mac dmg issue tomorrow. Appears to be something around the unlimited strength encryption jurisdiction files… but not sure. Might be somethign related to the server it was built on. I’ll start by building locally and see if I can reproduce.
Jody Garnett
Jody Garnett
All,
I downloaded the geoserver-2.9-beta2-win.zip from http://ares.boundlessgeo.com/geoserver/release/2.9-beta2/geoserver-2.9-beta2-win.zip
I unzipped to a folder on my drive which contained
GeoServerEXE.nsi
gs.ico
wrapper-server-license.txt
wrapper.conf
wrapper.dll
wrapper.exe
wrapper.jar
Not knowing how to start this, I simply ran the wrapper.exe as a double-click from Explorer
Output (from log, window closed to fast to copy the actual console):
STATUS | wrapper | 2016/04/20 07:48:29 | → Wrapper Started as Console
STATUS | wrapper | 2016/04/20 07:48:29 | Java Service Wrapper Community Edition 3.3.3
STATUS | wrapper | 2016/04/20 07:48:29 | Copyright (C) 1999-2009 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2016/04/20 07:48:29 | http://wrapper.tanukisoftware.org
STATUS | wrapper | 2016/04/20 07:48:29 | Launching a JVM…
INFO | jvm 1 | 2016/04/20 07:48:29 | Error: Could not find or load main class org.tanukisoftware.wrapper.WrapperSimpleApp
ERROR | wrapper | 2016/04/20 07:48:29 | JVM exited while loading the application.
STATUS | wrapper | 2016/04/20 07:48:34 | Launching a JVM…
INFO | jvm 2 | 2016/04/20 07:48:34 | Error: Could not find or load main class org.tanukisoftware.wrapper.WrapperSimpleApp
ERROR | wrapper | 2016/04/20 07:48:34 | JVM exited while loading the application.
STATUS | wrapper | 2016/04/20 07:48:38 | Launching a JVM…
INFO | jvm 3 | 2016/04/20 07:48:40 | Error: Could not find or load main class org.tanukisoftware.wrapper.WrapperSimpleApp
ERROR | wrapper | 2016/04/20 07:48:40 | JVM exited while loading the application.
STATUS | wrapper | 2016/04/20 07:48:45 | Launching a JVM…
INFO | jvm 4 | 2016/04/20 07:48:45 | Error: Could not find or load main class org.tanukisoftware.wrapper.WrapperSimpleApp
ERROR | wrapper | 2016/04/20 07:48:45 | JVM exited while loading the application.
STATUS | wrapper | 2016/04/20 07:48:49 | Launching a JVM…
INFO | jvm 5 | 2016/04/20 07:48:49 | Error: Could not find or load main class org.tanukisoftware.wrapper.WrapperSimpleApp
ERROR | wrapper | 2016/04/20 07:48:49 | JVM exited while loading the application.
FATAL | wrapper | 2016/04/20 07:48:50 | There were 5 failed launches in a row, each lasting less than 300 seconds. Giving up.
FATAL | wrapper | 2016/04/20 07:48:50 | There may be a configuration problem: please check the logs.
STATUS | wrapper | 2016/04/20 07:48:50 | ← Wrapper Stopped
Executing from a command prompt
Ouput:
F:\Downloads\GIS Software\geoserver-2.9-beta2-win>wrapper.exe
Launching a JVM…
Launching a JVM…
Launching a JVM…
Launching a JVM…
Launching a JVM…
← Wrapper Stopped
I did a quick search for how to start using the wrapper and found this page
https://github.com/geoserver/geoserver/blob/master/src/release/wrapper/wrapper_readme.txt
which indicates that the wrapper_readme.txt should be included, but the file list is also quite different to what is actually in the zip.
Not sure how to test this one.
Chris Snider
(attachments)
Jody Garnett
That one is combined with the bin download to produce the exe download. The wrapper is installed by the installer to run geoserver as a background service on Windows.
On Wed, Apr 20, 2016 at 6:53 AM Chris Snider <chris.snider@anonymised.com> wrote:
All,
GeoServerEXE.nsi
gs.ico
wrapper.conf
wrapper.dll
wrapper.exe
wrapper.jar
Ouput:
Launching a JVM…
Launching a JVM…
Launching a JVM…
Launching a JVM…
Launching a JVM…
← Wrapper Stopped
Chris Snider
Jody Garnett
Jody Garnett
(attachments)
Followed similar testing path as the standalone startup.bat. Differences highlighted in red font
Testing startup
Windows 7
java -version
Tomcat 7.0.55
Deployed geoserver-2.9-beta war as
webapps/geoserver29-beta
Some warnings from the console:
20 Apr 07:57:21 WARN [org.geoserver] - No default workspace was found.
20 Apr 07:57:21 WARN [gce.imagemosaic] - Unable to set ordering between tiff readers spi
beta\data\coverages\mosaic_sample\sample_image
20 Apr 07:57:22 WARN [gce.imagemosaic] - Unable to find sample image for path file:/C:/cep/apache-tomcat/webapps/geoserver29-beta/data/coverages/mosaic_sample/mosaic.shp
nurc:mosaic
nurc:Img_Sample
sf:streams
Published Layer
Previewed New Layer
Changed size to 16
Stroke to #0000FF
Fill to #FFFF00
Validated
Submitted
Exception in console log
20 Apr 08:13:54 INFO [gwc.layer] - Truncating layer ‘sf:archsites’ due to a change in style ‘capitals’
20 Apr 08:13:54 INFO [seed.GWCTask] - Thread group finished TRUNCATE task after 0.0 seconds
20 Apr 08:13:54 INFO [seed.GWCTask] - Thread group finished TRUNCATE task after 0.002 seconds
20 Apr 08:13:54 INFO [gwc.layer] - Truncating layer ‘sf:bugsites’ due to a change in style ‘capitals’
20 Apr 08:13:54 INFO [gwc.layer] - Truncating layer ‘topp:tasmania_cities’ due to a change in style ‘capitals’
20 Apr 08:13:54 INFO [gwc.layer] - Truncating layer group ‘spearfish’ due to a change in style ‘capitals’
20 Apr 08:13:54 INFO [file.FileBlobStore] - C:\Users\CHRIS~1.SNI\AppData\Local\Temp\geowebcache\spearfish does not exist or is not writable
20 Apr 08:13:54 INFO [gwc.layer] - Truncating layer group ‘tasmania’ due to a change in style ‘capitals’
20 Apr 08:13:54 INFO [file.FileBlobStore] - C:\Users\CHRIS~1.SNI\AppData\Local\Temp\geowebcache\tasmania does not exist or is not writable
*Files created in C:\Users\CHRIS~1.SNI\AppData\Local\Temp\geowebcache vice local data_dir as standalone does*
Went back and checked the layers listed on the Tile Caching > Tile Layers page; Each layer group fails
spearfish
tasmania
tiger-ny
Verified Security > Services Displays
Demo Requests
Submit
EXCEPTION
java.io.IOException
… 85 more
… 90 more
Close Popup window
URL changes
Body is blank
Same Screen shots
Chris Snider
(attachments)
Jody Garnett
Epic testing Chris - thanks! For your first test (before you tried startup.bat) I could not tell what you were doing … were you running installer/service or installer/manual/shortcut or installer/manual/startup.bat or bin download/startup.bat.
I have raised a number of issues based on your email thread:
Please review and check if I have missed anything.
(attachments)
On 19 April 2016 at 11:26, Chris Snider <chris.snider@anonymised.com> wrote:
Testing startup
Windows 7
java -version
nurc:mosaic
nurc:Img_Sample
sf:streams
Published Layer
Previewed New Layer
Changed size to 16
Stroke to #0000FF
Fill to #FFFF00
Validated
Submitted
Demo Requests
Submit
EXCEPTION
java.io.IOException
… 85 more
… 90 more
Close Popup window
URL changes
Body is blank
OR
Source Page:
Username
Actual Result Page:
Username
Chris Snider
Jody Garnett
Jody Garnett
Jody,
For the first test,
· Download geoserver-2.9-beta2-bin.zip
· Extract geoserver-2.9-beta2 to drive
· Double-click the startup.bat in bin folder
· Received the Module not found [ssl] warning and java.net.ConnectException
· Pressed any-key to close the window
· Double-click the startup.bat again
· GeoServer started
I tried removing the folder/re-extract, download again/extract but I could not repeat the initial warning/exception.
Chris Snider
(attachments)
Jody Garnett
On 19 April 2016 at 11:26, Chris Snider <chris.snider@…2565…> wrote:
Testing startup
Windows 7
java -version
nurc:mosaic
nurc:Img_Sample
sf:streams
Published Layer
Previewed New Layer
Changed size to 16
Stroke to #0000FF
Fill to #FFFF00
Validated
Submitted
Demo Requests
Submit
EXCEPTION
java.io.IOException
… 85 more
… 90 more
Close Popup window
URL changes
Body is blank
OR
Source Page:
Username
Actual Result Page:
Username
Chris Snider
Jody Garnett
