[Geoserver-devel] GeoServer 2.9-RC1 artifacts ready for testing
The 2.9-RC1 artifacts are available for testing at:
http://ares.boundlessgeo.com/geoserver/release/2.9-RC1/
I am currently testing the OS X dmg, and will also test the system-independant binary. If others could test the artifacts on their OS of choice, that would be appreciated.
Torben
The dmg and bin both look good on OS X.
Torben
On Mon, May 2, 2016 at 3:13 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Thank you Torben (and Kevin) - really looking forward to having a release schedule again.
Torben
On WIndows 7 vm:
geoserver-2.9.-RC1.bin - works fine
geoserver-2.9-RC1.exe - fails to start manually with
G:\Program Files (x86)\GeoServer 2.9-RC1\bin>call “G:\java\jre\bin\java.exe” -DGY=geoserver -Djetty.port=8080 -Djetty.logs="G:\Program Files (x86)\GeoServer 2.9
WARNING: Module not found [ssl]
WARNING: Nothing to start, exiting …
Usage: java -jar start.jar [options] [properties] [configs]
java -jar start.jar --help # for more information
Which looks like the same problem the basic jetty starter had before.
Ian
On Mon, May 2, 2016 at 6:36 PM Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z_______________________________________________
Geoserver-devel mailing list
Jody Garnett
Torben
Ian Turton
