Hi Ian,
I bet that is starts if you add
cd …
as the first line into startup.bat.
-Jukka Rahkonen-
Ian Turton wrote:
On WIndows 7 vm:
geoserver-2.9.-RC1.bin - works fine
geoserver-2.9-RC1.exe - fails to start manually with
G:\Program Files (x86)\GeoServer 2.9-RC1\bin>call “G:\java\jre\bin\java.exe” -DGY=geoserver -Djetty.port=8080 -Djetty.logs="G:\Program Files (x86)\GeoServer 2.9
WARNING: Module not found [ssl]
WARNING: Nothing to start, exiting …
Usage: java -jar start.jar [options] [properties] [configs]
java -jar start.jar --help # for more information
Which looks like the same problem the basic jetty starter had before.
Ian
On 3 May 2016 at 01:00, Jody Garnett <jody.garnett@…403…> wrote:
Thank you Torben (and Kevin) - really looking forward to having a release schedule again.
On Mon, May 2, 2016 at 6:36 PM Torben Barsballe <tbarsballe@…3839…> wrote:
The dmg and bin both look good on OS X.
Torben
On Mon, May 2, 2016 at 3:13 PM, Torben Barsballe <tbarsballe@…3839…> wrote:
The 2.9-RC1 artifacts are available for testing at:
http://ares.boundlessgeo.com/geoserver/release/2.9-RC1/
I am currently testing the OS X dmg, and will also test the system-independant binary. If others could test the artifacts on their OS of choice, that would be appreciated.
Torben
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z_______________________________________________
Geoserver-devel mailing list
Jody Garnett
Ian Turton
Adding cd … does fix it but I can’t see why as the jar path is hardcoded in in full as -jar “G:\Program Files (x86)\GeoServer 2.9-RC1\start.jar”
Ian
On 3 May 2016 at 09:50, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com> wrote:
Hi Ian,
cd …
-Jukka Rahkonen-
Ian Turton wrote:
On WIndows 7 vm:
Ian
On Mon, May 2, 2016 at 6:36 PM Torben Barsballe <tbarsballe@anonymised.com39…> wrote:
Torben
On Mon, May 2, 2016 at 3:13 PM, Torben Barsballe <tbarsballe@anonymised.com839…> wrote:
Torben
Jody Garnett
Ian Turton
Ian Turton
