Hey everybody-
My name's Chris Patterson, and I've been working recently on the GeoServer 2 interface.
Thought it might be good to check in and send along my $.02 on where we stand regarding UI stuff right now:
==Sidebar
* needs reorganization
* needs a listing (with at-a-glance status bars) for all the currently active services
* there was some conversation in IRC about bringing the [Persist] [Revert] buttons back into the sidebar, so they'd be always accessible (rather than on the server admin screen, where they are now).
==Data Manager
* Needs a lot of attention. Individual pages need to be converted to use the same markup conventions as the rest of the UI, and may need to be reordered / reorganized to be easier to use.
* We're using a tree view on the main data manager page (and have a fair amount of work invested in it). I'm not convinced this is the best approach for displaying this data, as I don't think we'll ever be nested more than two layers deep. This may be a moot point, given the amount of time invested in the tree view and our time constraints - but I'd love to get a better solution if we end up with time to do it.
==Demo pages
* Needs some attention to avoid the link-overload effect of listing every single format for every item.
==Avoiding overwrite collisions
* David and I have chatted about various ways to help users avoid overwriting each other's changes. The last time we'd talked, the options (in descending order of preference) were:
** Since wicket keeps track of what page each user is on, display messaging to the effect of "Hey! So-and-so is already on this page" when accessing a page that's already in use.
** Store the configuration time with the session data, and display messaging if the configuration is updated by another user
** Display the relevant configuration update time on pages which need it
==Errata
* Pagination will probably be needed on all pages which may display sufficiently-long result sets
* All result sets should be sorted by a sensible column. Time pending, adding client-side sorting by other columns might be nice (although it could be confusing in conjunction with pagination [users could think that they were looking at a different set of results])
* Adding animation and more AJAX-y effects as appropriate are all time-permitting at this point
Chris
