[Geoserver-devel] geoserver access problem
hi all, i am trying to access geoserver from internet . i have got public ip also. but couldnot access the geoserver from that public ip and opened firewall for 8080 too. i want to access geoserver like
http://120.89.130.69:8080/geoserver
but it is not working
geoserver still says like “started SelectChannelConnector @ 0.0.0.0:8080
should any configuration file of geoserver be changed or anything else.
i would very much appericiate your help thanks in advance.
These sorts of questions are more suitable to the users list, you will get a better response there.
As for the issue. I don't think it is a geoserver problem. As long as your firewall is set up to allow or forward requests to the geoserver instance it should work. GeoServer does not constrain itself to listening just on localhost or anything. So there should not be any additional configuration.
So i would verify that your firewall is configured correctly, and ensure there are no other network issues going on.
-Justin
geoserver still says like "started SelectChannelConnector @ 0.0.0.0:8080 <http://0.0.0.0:8080>"
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
