[Geoserver-devel] Geoserver and DefaultMap
I just tried working on fixing this one at home and find myself rather stuck,
GeoServer currently won't build JAIMapResponse is commited in terms of
DefaultMapContext - and this class is not in any of the jars commited to the
GeoServer libs directory.
So either I have caught someone in the middle of fixing everything I am out of luck.
Jody
stuck, GeoServer currently won't build JAIMapResponse is commited in terms
of DefaultMapContext - and this class is not in any of the jars commited to
the GeoServer libs directory.
of luck.
That class is in the map module. You do need to add it to the libs.
Best regards
Andrea Aime
Quoting Andrea Aime <andrea.aime@anonymised.com>:
> of luck.
Thanks Andrea: I am not sure that David our I were very clear in describing our
problem. We did not know how to generate the new jars to add to the libs.
But I now, after a couple hours, have the answer.
The wiki (not the developers guide) has the important maven goal we were looking
for (http://docs.codehaus.org/display/GEOTOOLS/How+to+cut+a+release).
And that goal is:
maven -Drelease.version=2.0-B3 createRelease
GeoServer has been using its own ant script assemble jars, recently it has
switched over to tracking the 2.0-B? releases. This set back is all about
lacking a clear jar update procedure in between 2.0-B? releases.
Jody
The libs have now been updated, the ant build files has as well.
Both scrips are not perfect:
- maven builds a gt2-opengis jar that ant simply squishes into gt2-main.jar
- ant builds a gt2-property jar that maven does not
If someone who understands the maven script can tell me what goes into the
opengis-2.0-B3.jar we can teach the ant script to follow suite.
But the long and short of it is that GeoServer development can proceed again.
Jody
our
looking
And that goal is:
Jody
This SF.Net email is sponsored by: IBM Linux Tutorials
Free Linux tutorial presented by Daniel Robbins, President and CEO of
GenToo technologies. Learn everything from fundamentals to system
administration.Compare, Download & Develop Open Source & Business Software - SourceForge
Geoserver-devel mailing list
