the last build failure cause seems to actually be this:
Caused by: java.io.IOException: Disk quota exceeded
at java.io.FileOutputStream.writeBytes(Native Method)
at java.io.FileOutputStream.write(FileOutputStream.java:260)
at java.io.BufferedOutputStream.flushBuffer(BufferedOutputStream.java:65)
at java.io.BufferedOutputStream.flush(BufferedOutputStream.java:123)
at sun.nio.cs.StreamEncoder.implFlush(StreamEncoder.java:278)
at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java:122)
at java.io.OutputStreamWriter.flush(OutputStreamWriter.java:212)
at com.thoughtworks.xstream.core.util.QuickWriter.flush(QuickWriter.java:75)
... 38 more
Hmmm… not something I can help solve on this end
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Working on freeing up space. Freed up an initial bit so builds should function again and looking at freeing up more.
On Sun, Aug 11, 2013 at 3:09 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
... 38 more
Ing. Andrea Aime
@geowolf
Technical Lead
Get 100% visibility into Java/.NET code with AppDynamics Lite!
It’s a free troubleshooting tool designed for production.
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://pubads.g.doubleclick.net/gampad/clk?id=48897031&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
