[Geoserver-devel] Geoserver Build Failure
I add and change some files under wms project. Then, build with maven is failed.
I add Point2D.java (package org.geoserver.wms.map;) which inherits Point2D of package java.awt.geom.
I also add AffineTransform.java (package org.geoserver.wms.map;) which inherits java.awt.geom.AffineTransform. Then, I modify the code in GetMapRequest: import org.geoserver.wms.map.Point2D;
However, when I build the changed Geoserver source code using maven, the build is failed:
--------------------Point2D--------------------------------------------------
import java.io.Serializable;
public abstract class Point2D extends java.awt.geom.Point2D {
public static class Float extends Point2D implements Serializable {
public float x;
public float y;
public Float() {
public Float(float x, float y) {
this.x = x+1000000000;
this.y = y+1000000000;
public double getX() {
return (double) x+1000000000;
public double getY() {
return (double) y+1000000000;
public void setLocation(double x, double y) {
this.x = (float) x+1000000000;
this.y = (float) y+1000000000;
public void setLocation(float x, float y) {
public String toString() {
return “Point2D.Float[”+x+“, “+y+”]”;
private static final long serialVersionUID = -2870572449815403710L;
public static class Double extends Point2D implements Serializable {
public double x;
public double y;
public Double() {
public Double(double x, double y) {
return x+1000000000;
return y+1000000000;
return “Point2D.Double[”+x+“, “+y+”]”;
private static final long serialVersionUID = 6150783262733311327L;
protected Point2D() {
public abstract double getX();
public abstract double getY();
public abstract void setLocation(double x, double y);
public void setLocation(Point2D p) {
setLocation(p.getX()+1000000000, p.getY()+1000000000);
-------------------------------------AffineTransform---------------------------------------------------------------
import java.awt.Shape;
import org.geoserver.wms.map.AffineTransform;
import java.awt.geom.NoninvertibleTransformException;
import java.awt.geom.Path2D;
public class AffineTransform extends java.awt.geom.AffineTransform{
private static final int TYPE_UNKNOWN = -1;
public static final int TYPE_IDENTITY = 0;
public static final int TYPE_TRANSLATION = 1;
public static final int TYPE_UNIFORM_SCALE = 2;
public static final int TYPE_GENERAL_SCALE = 4;
public static final int TYPE_MASK_SCALE = (TYPE_UNIFORM_SCALE |
TYPE_GENERAL_SCALE);
public static final int TYPE_FLIP = 64;
public static final int TYPE_QUADRANT_ROTATION = 8;
public static final int TYPE_GENERAL_ROTATION = 16;
public static final int TYPE_MASK_ROTATION = (TYPE_QUADRANT_ROTATION |
TYPE_GENERAL_ROTATION);
public static final int TYPE_GENERAL_TRANSFORM = 32;
static final int APPLY_IDENTITY = 0;
static final int APPLY_TRANSLATE = 1;
static final int APPLY_SCALE = 2;
static final int APPLY_SHEAR = 4;
private static final int HI_SHIFT = 3;
private static final int HI_IDENTITY = APPLY_IDENTITY << HI_SHIFT;
private static final int HI_TRANSLATE = APPLY_TRANSLATE << HI_SHIFT;
private static final int HI_SCALE = APPLY_SCALE << HI_SHIFT;
private static final int HI_SHEAR = APPLY_SHEAR << HI_SHIFT;
double m00;
double m10;
double m01;
double m11;
double m02;
double m12;
transient int state;
private transient int type;
private AffineTransform(double m00, double m10,
double m01, double m11,
double m02, double m12,
int state) {
this.m00 = m00;
this.m10 = m10;
this.m01 = m01;
this.m11 = m11;
this.m02 = m02;
this.m12 = m12;
this.state = state;
this.type = TYPE_UNKNOWN;
public AffineTransform() {
m00 = m11 = 1.0;
// m01 = m10 = m02 = m12 = 0.0; /* Not needed. /
// state = APPLY_IDENTITY; /
Not needed. /
// type = TYPE_IDENTITY; /
Not needed. */
public AffineTransform(AffineTransform Tx) {
this.m00 = Tx.m00;
this.m10 = Tx.m10;
this.m01 = Tx.m01;
this.m11 = Tx.m11;
this.m02 = Tx.m02;
this.m12 = Tx.m12;
this.state = Tx.state;
this.type = Tx.type;
public AffineTransform(float m00, float m10,
float m01, float m11,
float m02, float m12) {
this.m00 = m00;
this.m10 = m10;
this.m01 = m01;
this.m11 = m11;
this.m02 = m02;
this.m12 = m12;
updateState();
public AffineTransform(float flatmatrix) {
m00 = flatmatrix[0];
m10 = flatmatrix[1];
m01 = flatmatrix[2];
m11 = flatmatrix[3];
if (flatmatrix.length > 5) {
m02 = flatmatrix[4];
m12 = flatmatrix[5];
updateState();
public AffineTransform(double m00, double m10,
double m02, double m12) {
this.m00 = m00;
this.m10 = m10;
this.m01 = m01;
this.m11 = m11;
this.m02 = m02;
this.m12 = m12;
updateState();
public AffineTransform(double flatmatrix) {
updateState();
public static AffineTransform getTranslateInstance(double tx, double ty) {
AffineTransform Tx = new AffineTransform();
Tx.setToTranslation(tx, ty);
return Tx;
public static AffineTransform getRotateInstance(double theta) {
Tx.setToRotation(theta);
return Tx;
public static AffineTransform getRotateInstance(double theta,
double anchorx,
double anchory)
Tx.setToRotation(theta, anchorx, anchory);
return Tx;
public static AffineTransform getRotateInstance(double vecx, double vecy) {
Tx.setToRotation(vecx, vecy);
return Tx;
double vecy,
double anchorx,
double anchory)
Tx.setToRotation(vecx, vecy, anchorx, anchory);
return Tx;
public static AffineTransform getQuadrantRotateInstance(int numquadrants) {
Tx.setToQuadrantRotation(numquadrants);
return Tx;
public static AffineTransform getQuadrantRotateInstance(int numquadrants,
double anchorx,
double anchory)
Tx.setToQuadrantRotation(numquadrants, anchorx, anchory);
return Tx;
public static AffineTransform getScaleInstance(double sx, double sy) {
Tx.setToScale(sx, sy);
return Tx;
public static AffineTransform getShearInstance(double shx, double shy) {
Tx.setToShear(shx, shy);
return Tx;
public int getType() {
if (type == TYPE_UNKNOWN) {
calculateType();
return type;
private void calculateType() {
int ret = TYPE_IDENTITY;
boolean sgn0, sgn1;
double M0, M1, M2, M3;
updateState();
switch (state) {
default:
stateError();
/* NOTREACHED /
case (APPLY_SHEAR | APPLY_SCALE | APPLY_TRANSLATE):
ret = TYPE_TRANSLATION;
NOBREAK /
case (APPLY_SHEAR | APPLY_SCALE):
if ((M0 = m00) * (M2 = m01) + (M3 = m10) * (M1 = m11) != 0) {
// Transformed unit vectors are not perpendicular…
this.type = TYPE_GENERAL_TRANSFORM;
return;
sgn0 = (M0 >= 0.0);
sgn1 = (M1 >= 0.0);
if (sgn0 == sgn1) {
// sgn(M0) == sgn(M1) therefore sgn(M2) == -sgn(M3)
// This is the “unflipped” (right-handed) state
if (M0 != M1 || M2 != -M3) {
ret |= (TYPE_GENERAL_ROTATION | TYPE_GENERAL_SCALE);
} else if (M0 * M1 - M2 * M3 != 1.0) {
ret |= (TYPE_GENERAL_ROTATION | TYPE_UNIFORM_SCALE);
} else {
ret |= TYPE_GENERAL_ROTATION;
} else {
// sgn(M0) == -sgn(M1) therefore sgn(M2) == sgn(M3)
// This is the “flipped” (left-handed) state
if (M0 != -M1 || M2 != M3) {
TYPE_FLIP |
TYPE_FLIP |
} else {
ret |= (TYPE_GENERAL_ROTATION | TYPE_FLIP);
break;
case (APPLY_SHEAR | APPLY_TRANSLATE):
NOBREAK /
case (APPLY_SHEAR):
sgn0 = ((M0 = m01) >= 0.0);
sgn1 = ((M1 = m10) >= 0.0);
if (sgn0 != sgn1) {
// Different signs - simple 90 degree rotation
if (M0 != -M1) {
ret |= (TYPE_QUADRANT_ROTATION | TYPE_GENERAL_SCALE);
} else if (M0 != 1.0 && M0 != -1.0) {
ret |= (TYPE_QUADRANT_ROTATION | TYPE_UNIFORM_SCALE);
} else {
ret |= TYPE_QUADRANT_ROTATION;
} else {
// Same signs - 90 degree rotation plus an axis flip too
if (M0 == M1) {
TYPE_FLIP |
} else {
TYPE_FLIP |
break;
case (APPLY_SCALE | APPLY_TRANSLATE):
NOBREAK /
case (APPLY_SCALE):
sgn0 = ((M0 = m00) >= 0.0);
sgn1 = ((M1 = m11) >= 0.0);
if (sgn0 == sgn1) {
if (sgn0) {
// Both scaling factors non-negative - simple scale
// Note: APPLY_SCALE implies M0, M1 are not both 1
if (M0 == M1) {
ret |= TYPE_UNIFORM_SCALE;
} else {
ret |= TYPE_GENERAL_SCALE;
} else {
// Both scaling factors negative - 180 degree rotation
if (M0 != M1) {
} else if (M0 != -1.0) {
} else {
} else {
// Scaling factor signs different - flip about some axis
if (M0 == -M1) {
if (M0 == 1.0 || M0 == -1.0) {
ret |= TYPE_FLIP;
} else {
ret |= (TYPE_FLIP | TYPE_UNIFORM_SCALE);
} else {
ret |= (TYPE_FLIP | TYPE_GENERAL_SCALE);
break;
case (APPLY_TRANSLATE):
break;
case (APPLY_IDENTITY):
break;
this.type = ret;
public double getDeterminant() {
switch (state) {
default:
stateError();
NOTREACHED */
return m00 * m11 - m01 * m10;
case (APPLY_SHEAR):
return -(m01 * m10);
case (APPLY_SCALE):
return m00 * m11;
return 1.0;
void updateState() {
if (m01 == 0.0 && m10 == 0.0) {
if (m00 == 1.0 && m11 == 1.0) {
if (m02 == 0.0 && m12 == 0.0) {
} else {
state = APPLY_TRANSLATE;
type = TYPE_TRANSLATION;
} else {
state = APPLY_SCALE;
} else {
state = (APPLY_SCALE | APPLY_TRANSLATE);
} else {
if (m00 == 0.0 && m11 == 0.0) {
state = APPLY_SHEAR;
} else {
state = (APPLY_SHEAR | APPLY_TRANSLATE);
} else {
state = (APPLY_SHEAR | APPLY_SCALE);
} else {
state = (APPLY_SHEAR | APPLY_SCALE | APPLY_TRANSLATE);
private void stateError() {
throw new InternalError(“missing case in transform state switch”);
public void getMatrix(double flatmatrix) {
flatmatrix[0] = m00;
flatmatrix[1] = m10;
flatmatrix[2] = m01;
flatmatrix[3] = m11;
flatmatrix[4] = m02;
flatmatrix[5] = m12;
public double getScaleX() {
return m00;
public double getScaleY() {
return m11;
public double getShearX() {
return m01;
public double getShearY() {
return m10;
public double getTranslateX() {
return m02;
public double getTranslateY() {
return m12;
public void translate(double tx, double ty) {
switch (state) {
default:
stateError();
/* NOTREACHED /
m02 = tx * m00 + ty * m01 + m02;
m12 = tx * m10 + ty * m11 + m12;
state = APPLY_SHEAR | APPLY_SCALE;
if (type != TYPE_UNKNOWN) {
type -= TYPE_TRANSLATION;
return;
m02 = tx * m00 + ty * m01;
m12 = tx * m10 + ty * m11;
if (m02 != 0.0 || m12 != 0.0) {
state = APPLY_SHEAR | APPLY_SCALE | APPLY_TRANSLATE;
type |= TYPE_TRANSLATION;
return;
m02 = ty * m01 + m02;
m12 = tx * m10 + m12;
return;
case (APPLY_SHEAR):
m02 = ty * m01;
m12 = tx * m10;
state = APPLY_SHEAR | APPLY_TRANSLATE;
return;
m02 = tx * m00 + m02;
m12 = ty * m11 + m12;
return;
case (APPLY_SCALE):
m02 = tx * m00;
m12 = ty * m11;
state = APPLY_SCALE | APPLY_TRANSLATE;
return;
m02 = tx + m02;
m12 = ty + m12;
return;
m02 = tx;
m12 = ty;
if (tx != 0.0 || ty != 0.0) {
return;
// Utility methods to optimize rotate methods.
// These tables translate the flags during predictable quadrant
// rotations where the shear and scale values are swapped and negated.
private static final int rot90conversion[] = {
IDENTITY => / APPLY_SHEAR,
TRANSLATE (TR) => / APPLY_SHEAR | APPLY_TRANSLATE,
SCALE (SC) => / APPLY_SHEAR,
SC | TR => / APPLY_SHEAR | APPLY_TRANSLATE,
SHEAR (SH) => / APPLY_SCALE,
SH | TR => / APPLY_SCALE | APPLY_TRANSLATE,
SH | SC => / APPLY_SHEAR | APPLY_SCALE,
SH | SC | TR => / APPLY_SHEAR | APPLY_SCALE | APPLY_TRANSLATE,
private final void rotate90() {
double M0 = m00;
m00 = m01;
m01 = -M0;
M0 = m10;
m10 = m11;
m11 = -M0;
int state = rot90conversion[this.state];
if ((state & (APPLY_SHEAR | APPLY_SCALE)) == APPLY_SCALE &&
state -= APPLY_SCALE;
this.state = state;
private final void rotate180() {
m00 = -m00;
m11 = -m11;
int state = this.state;
if ((state & (APPLY_SHEAR)) != 0) {
// If there was a shear, then this rotation has no
// effect on the state.
m01 = -m01;
m10 = -m10;
} else {
// No shear means the SCALE state may toggle when
// m00 and m11 are negated.
this.state = state & ~APPLY_SCALE;
} else {
this.state = state | APPLY_SCALE;
private final void rotate270() {
double M0 = m00;
m00 = -m01;
m01 = M0;
M0 = m10;
m10 = -m11;
m11 = M0;
this.state = state;
public void rotate(double theta) {
double sin = Math.sin(theta);
if (sin == 1.0) {
rotate90();
} else if (sin == -1.0) {
rotate270();
} else {
double cos = Math.cos(theta);
if (cos == -1.0) {
rotate180();
} else if (cos != 1.0) {
double M0, M1;
M0 = m00;
M1 = m01;
m00 = cos * M0 + sin * M1;
m01 = -sin * M0 + cos * M1;
M0 = m10;
M1 = m11;
m10 = cos * M0 + sin * M1;
m11 = -sin * M0 + cos * M1;
updateState();
public void rotate(double theta, double anchorx, double anchory) {
// REMIND: Simple for now - optimize later
translate(anchorx, anchory);
rotate(theta);
translate(-anchorx, -anchory);
public void rotate(double vecx, double vecy) {
if (vecy == 0.0) {
if (vecx < 0.0) {
rotate180();
// If vecx > 0.0 - no rotation
// If vecx == 0.0 - undefined rotation - treat as no rotation
} else if (vecx == 0.0) {
if (vecy > 0.0) {
rotate90();
} else { // vecy must be < 0.0
rotate270();
} else {
double len = Math.sqrt(vecx * vecx + vecy * vecy);
double sin = vecy / len;
double cos = vecx / len;
double M0, M1;
M0 = m00;
M1 = m01;
M0 = m10;
M1 = m11;
updateState();
public void rotate(double vecx, double vecy,
rotate(vecx, vecy);
public void quadrantRotate(int numquadrants) {
switch (numquadrants & 3) {
case 0:
break;
case 1:
rotate90();
break;
case 2:
rotate180();
break;
case 3:
rotate270();
break;
public void quadrantRotate(int numquadrants,
case 0:
return;
case 1:
m02 += anchorx * (m00 - m01) + anchory * (m01 + m00);
m12 += anchorx * (m10 - m11) + anchory * (m11 + m10);
rotate90();
break;
case 2:
m02 += anchorx * (m00 + m00) + anchory * (m01 + m01);
m12 += anchorx * (m10 + m10) + anchory * (m11 + m11);
rotate180();
break;
case 3:
m02 += anchorx * (m00 + m01) + anchory * (m01 - m00);
m12 += anchorx * (m10 + m11) + anchory * (m11 - m10);
rotate270();
break;
state &= ~APPLY_TRANSLATE;
} else {
state |= APPLY_TRANSLATE;
public void scale(double sx, double sy) {
switch (state) {
default:
stateError();
NOTREACHED */
m00 *= sx;
m11 = sy;
NOBREAK */
case (APPLY_SHEAR):
m01 *= sy;
m10 *= sx;
if (m01 == 0 && m10 == 0) {
state &= APPLY_TRANSLATE;
this.type = (state == APPLY_IDENTITY
? TYPE_IDENTITY
: TYPE_TRANSLATION);
} else {
state |= APPLY_SCALE;
this.state = state;
return;
case (APPLY_SCALE):
m00 *= sx;
m11 = sy;
this.state = (state &= APPLY_TRANSLATE);
? TYPE_IDENTITY
} else {
return;
m00 = sx;
m11 = sy;
if (sx != 1.0 || sy != 1.0) {
return;
public void shear(double shx, double shy) {
switch (state) {
default:
stateError();
NOTREACHED /
double M0, M1;
M0 = m00;
M1 = m01;
m00 = M0 + M1 * shy;
m01 = M0 * shx + M1;
M0 = m10;
M1 = m11;
m10 = M0 + M1 * shy;
m11 = M0 * shx + M1;
updateState();
return;
case (APPLY_SHEAR):
m00 = m01 * shy;
m11 = m10 * shx;
if (m00 != 0.0 || m11 != 0.0) {
return;
case (APPLY_SCALE):
m01 = m00 * shx;
m10 = m11 * shy;
if (m01 != 0.0 || m10 != 0.0) {
this.state = state | APPLY_SHEAR;
return;
m01 = shx;
m10 = shy;
this.state = state | APPLY_SCALE | APPLY_SHEAR;
return;
public void setToIdentity() {
m00 = m11 = 1.0;
m10 = m01 = m02 = m12 = 0.0;
public void setToTranslation(double tx, double ty) {
m00 = 1.0;
m10 = 0.0;
m01 = 0.0;
m11 = 1.0;
m02 = tx;
m12 = ty;
} else {
public void setToRotation(double theta) {
double cos;
if (sin == 1.0 || sin == -1.0) {
cos = 0.0;
type = TYPE_QUADRANT_ROTATION;
} else {
if (cos == -1.0) {
sin = 0.0;
} else if (cos == 1.0) {
sin = 0.0;
} else {
type = TYPE_GENERAL_ROTATION;
m00 = cos;
m10 = sin;
m01 = -sin;
m11 = cos;
m02 = 0.0;
m12 = 0.0;
public void setToRotation(double theta, double anchorx, double anchory) {
double sin = m10;
double oneMinusCos = 1.0 - m00;
m02 = anchorx * oneMinusCos + anchory * sin;
m12 = anchory * oneMinusCos - anchorx * sin;
public void setToRotation(double vecx, double vecy) {
double sin, cos;
if (vecy == 0) {
sin = 0.0;
if (vecx < 0.0) {
cos = -1.0;
} else {
cos = 1.0;
} else if (vecx == 0) {
cos = 0.0;
sin = (vecy > 0.0) ? 1.0 : -1.0;
} else {
cos = vecx / len;
sin = vecy / len;
m00 = cos;
m10 = sin;
m01 = -sin;
m11 = cos;
m02 = 0.0;
m12 = 0.0;
public void setToRotation(double vecx, double vecy,
double sin = m10;
public void setToQuadrantRotation(int numquadrants) {
case 0:
m00 = 1.0;
m10 = 0.0;
m01 = 0.0;
m11 = 1.0;
m02 = 0.0;
m12 = 0.0;
break;
case 1:
m00 = 0.0;
m10 = 1.0;
m01 = -1.0;
m11 = 0.0;
m02 = 0.0;
m12 = 0.0;
break;
case 2:
m00 = -1.0;
m10 = 0.0;
m01 = 0.0;
m11 = -1.0;
m02 = 0.0;
m12 = 0.0;
break;
case 3:
m00 = 0.0;
m10 = -1.0;
m01 = 1.0;
m11 = 0.0;
m02 = 0.0;
m12 = 0.0;
break;
public void setToQuadrantRotation(int numquadrants,
case 0:
m00 = 1.0;
m10 = 0.0;
m01 = 0.0;
m11 = 1.0;
m02 = 0.0;
m12 = 0.0;
break;
case 1:
m00 = 0.0;
m10 = 1.0;
m01 = -1.0;
m11 = 0.0;
m02 = anchorx + anchory;
m12 = anchory - anchorx;
} else {
type = TYPE_QUADRANT_ROTATION | TYPE_TRANSLATION;
break;
case 2:
m00 = -1.0;
m10 = 0.0;
m01 = 0.0;
m11 = -1.0;
m02 = anchorx + anchorx;
m12 = anchory + anchory;
} else {
break;
case 3:
m00 = 0.0;
m10 = -1.0;
m01 = 1.0;
m11 = 0.0;
m02 = anchorx - anchory;
m12 = anchory + anchorx;
} else {
break;
public void setToScale(double sx, double sy) {
m00 = sx;
m10 = 0.0;
m01 = 0.0;
m11 = sy;
m02 = 0.0;
m12 = 0.0;
} else {
public void setToShear(double shx, double shy) {
m00 = 1.0;
m01 = shx;
m10 = shy;
m11 = 1.0;
m02 = 0.0;
m12 = 0.0;
if (shx != 0.0 || shy != 0.0) {
} else {
public void setTransform(AffineTransform Tx) {
this.m00 = Tx.m00;
this.m10 = Tx.m10;
this.m01 = Tx.m01;
this.m11 = Tx.m11;
this.m02 = Tx.m02;
this.m12 = Tx.m12;
public void setTransform(double m00, double m10,
this.m00 = m00;
this.m10 = m10;
this.m01 = m01;
this.m11 = m11;
this.m02 = m02;
this.m12 = m12;
updateState();
public void concatenate(AffineTransform Tx) {
double M0, M1;
double T00, T01, T10, T11;
double T02, T12;
int mystate = state;
int txstate = Tx.state;
switch ((txstate << HI_SHIFT) | mystate) {
---------- Tx == IDENTITY cases ---------- /
case (HI_IDENTITY | APPLY_IDENTITY):
case (HI_IDENTITY | APPLY_TRANSLATE):
case (HI_IDENTITY | APPLY_SCALE):
case (HI_IDENTITY | APPLY_SCALE | APPLY_TRANSLATE):
case (HI_IDENTITY | APPLY_SHEAR):
case (HI_IDENTITY | APPLY_SHEAR | APPLY_TRANSLATE):
case (HI_IDENTITY | APPLY_SHEAR | APPLY_SCALE):
case (HI_IDENTITY | APPLY_SHEAR | APPLY_SCALE | APPLY_TRANSLATE):
return;
---------- this == IDENTITY cases ---------- /
case (HI_SHEAR | HI_SCALE | HI_TRANSLATE | APPLY_IDENTITY):
m01 = Tx.m01;
m10 = Tx.m10;
NOBREAK /
case (HI_SCALE | HI_TRANSLATE | APPLY_IDENTITY):
m00 = Tx.m00;
m11 = Tx.m11;
NOBREAK /
case (HI_TRANSLATE | APPLY_IDENTITY):
m02 = Tx.m02;
m12 = Tx.m12;
state = txstate;
type = Tx.type;
return;
case (HI_SHEAR | HI_SCALE | APPLY_IDENTITY):
m01 = Tx.m01;
m10 = Tx.m10;
NOBREAK /
case (HI_SCALE | APPLY_IDENTITY):
m00 = Tx.m00;
m11 = Tx.m11;
state = txstate;
type = Tx.type;
return;
case (HI_SHEAR | HI_TRANSLATE | APPLY_IDENTITY):
m02 = Tx.m02;
m12 = Tx.m12;
NOBREAK /
case (HI_SHEAR | APPLY_IDENTITY):
m01 = Tx.m01;
m10 = Tx.m10;
m00 = m11 = 0.0;
state = txstate;
type = Tx.type;
return;
---------- Tx == TRANSLATE cases ---------- /
case (HI_TRANSLATE | APPLY_SHEAR | APPLY_SCALE | APPLY_TRANSLATE):
case (HI_TRANSLATE | APPLY_SHEAR | APPLY_SCALE):
case (HI_TRANSLATE | APPLY_SHEAR | APPLY_TRANSLATE):
case (HI_TRANSLATE | APPLY_SHEAR):
case (HI_TRANSLATE | APPLY_SCALE | APPLY_TRANSLATE):
case (HI_TRANSLATE | APPLY_SCALE):
case (HI_TRANSLATE | APPLY_TRANSLATE):
translate(Tx.m02, Tx.m12);
return;
---------- Tx == SCALE cases ---------- /
case (HI_SCALE | APPLY_SHEAR | APPLY_SCALE | APPLY_TRANSLATE):
case (HI_SCALE | APPLY_SHEAR | APPLY_SCALE):
case (HI_SCALE | APPLY_SHEAR | APPLY_TRANSLATE):
case (HI_SCALE | APPLY_SHEAR):
case (HI_SCALE | APPLY_SCALE | APPLY_TRANSLATE):
case (HI_SCALE | APPLY_SCALE):
case (HI_SCALE | APPLY_TRANSLATE):
scale(Tx.m00, Tx.m11);
return;
---------- Tx == SHEAR cases ---------- /
case (HI_SHEAR | APPLY_SHEAR | APPLY_SCALE | APPLY_TRANSLATE):
case (HI_SHEAR | APPLY_SHEAR | APPLY_SCALE):
T01 = Tx.m01; T10 = Tx.m10;
M0 = m00;
m00 = m01 * T10;
m01 = M0 * T01;
M0 = m10;
m10 = m11 * T10;
m11 = M0 * T01;
return;
case (HI_SHEAR | APPLY_SHEAR | APPLY_TRANSLATE):
case (HI_SHEAR | APPLY_SHEAR):
m00 = m01 * Tx.m10;
m01 = 0.0;
m11 = m10 * Tx.m01;
m10 = 0.0;
state = mystate ^ (APPLY_SHEAR | APPLY_SCALE);
return;
case (HI_SHEAR | APPLY_SCALE | APPLY_TRANSLATE):
case (HI_SHEAR | APPLY_SCALE):
m01 = m00 * Tx.m01;
m00 = 0.0;
m10 = m11 * Tx.m10;
m11 = 0.0;
return;
case (HI_SHEAR | APPLY_TRANSLATE):
m00 = 0.0;
m01 = Tx.m01;
m10 = Tx.m10;
m11 = 0.0;
state = APPLY_TRANSLATE | APPLY_SHEAR;
return;
// If Tx has more than one attribute, it is not worth optimizing
// all of those cases…
T00 = Tx.m00; T01 = Tx.m01; T02 = Tx.m02;
T10 = Tx.m10; T11 = Tx.m11; T12 = Tx.m12;
switch (mystate) {
default:
stateError();
NOTREACHED /
state = mystate | txstate;
NOBREAK /
M0 = m00;
M1 = m01;
m00 = T00 * M0 + T10 * M1;
m01 = T01 * M0 + T11 * M1;
m02 += T02 * M0 + T12 * M1;
M0 = m10;
M1 = m11;
m10 = T00 * M0 + T10 * M1;
m11 = T01 * M0 + T11 * M1;
m12 += T02 * M0 + T12 * M1;
return;
case (APPLY_SHEAR):
M0 = m01;
m00 = T10 * M0;
m01 = T11 * M0;
m02 += T12 * M0;
M0 = m10;
m10 = T00 * M0;
m11 = T01 * M0;
m12 += T02 * M0;
break;
case (APPLY_SCALE):
M0 = m00;
m00 = T00 * M0;
m01 = T01 * M0;
m02 += T02 * M0;
M0 = m11;
m10 = T10 * M0;
m11 = T11 * M0;
m12 += T12 * M0;
break;
m00 = T00;
m01 = T01;
m02 += T02;
m10 = T10;
m11 = T11;
m12 += T12;
state = txstate | APPLY_TRANSLATE;
return;
updateState();
public void preConcatenate(AffineTransform Tx) {
double M0, M1;
double T02, T12;
// Tx is IDENTITY…
return;
// Tx is TRANSLATE, this has no TRANSLATE
m02 = Tx.m02;
m12 = Tx.m12;
state = mystate | APPLY_TRANSLATE;
return;
// Tx is TRANSLATE, this has one too
m02 = m02 + Tx.m02;
m12 = m12 + Tx.m12;
return;
// Only these two existing states need a new state
state = mystate | APPLY_SCALE;
NOBREAK /
// Tx is SCALE, this is anything
T00 = Tx.m00;
T11 = Tx.m11;
if ((mystate & APPLY_SHEAR) != 0) {
m01 = m01 * T00;
m10 = m10 * T11;
if ((mystate & APPLY_SCALE) != 0) {
m00 = m00 * T00;
m11 = m11 * T11;
} else {
m00 = m00 * T00;
m11 = m11 * T11;
if ((mystate & APPLY_TRANSLATE) != 0) {
m02 = m02 * T00;
m12 = m12 * T11;
return;
mystate = mystate | APPLY_SCALE;
NOBREAK /
state = mystate ^ APPLY_SHEAR;
NOBREAK /
// Tx is SHEAR, this is anything
T01 = Tx.m01;
T10 = Tx.m10;
M0 = m00;
m00 = m10 * T01;
m10 = M0 * T10;
M0 = m01;
m01 = m11 * T01;
m11 = M0 * T10;
M0 = m02;
m02 = m12 * T01;
m12 = M0 * T10;
return;
switch (mystate) {
default:
stateError();
NOTREACHED /
M0 = m02;
M1 = m12;
T02 += M0 * T00 + M1 * T01;
T12 += M0 * T10 + M1 * T11;
NOBREAK /
m02 = T02;
m12 = T12;
M0 = m00;
M1 = m10;
m00 = M0 * T00 + M1 * T01;
m10 = M0 * T10 + M1 * T11;
M0 = m01;
M1 = m11;
m01 = M0 * T00 + M1 * T01;
m11 = M0 * T10 + M1 * T11;
break;
M0 = m02;
M1 = m12;
NOBREAK /
case (APPLY_SHEAR):
m02 = T02;
m12 = T12;
M0 = m10;
m00 = M0 * T01;
m10 = M0 * T11;
M0 = m01;
m01 = M0 * T00;
m11 = M0 * T10;
break;
M0 = m02;
M1 = m12;
NOBREAK /
case (APPLY_SCALE):
m02 = T02;
m12 = T12;
M0 = m00;
m00 = M0 * T00;
m10 = M0 * T10;
M0 = m11;
m01 = M0 * T01;
m11 = M0 * T11;
break;
M0 = m02;
M1 = m12;
NOBREAK /
m02 = T02;
m12 = T12;
m00 = T00;
m10 = T10;
m01 = T01;
m11 = T11;
return;
updateState();
public AffineTransform createInverse()
throws NoninvertibleTransformException
double det;
switch (state) {
default:
stateError();
NOTREACHED /
det = m00 * m11 - m01 * m10;
if (Math.abs(det) <= Double.MIN_VALUE) {
throw new NoninvertibleTransformException("Determinant is "+
det);
return new AffineTransform( m11 / det, -m10 / det,
-m01 / det, m00 / det,
(m01 * m12 - m11 * m02) / det,
(m10 * m02 - m00 * m12) / det,
(APPLY_SHEAR |
APPLY_SCALE |
APPLY_TRANSLATE));
det);
0.0, 0.0,
(APPLY_SHEAR | APPLY_SCALE));
if (m01 == 0.0 || m10 == 0.0) {
throw new NoninvertibleTransformException(“Determinant is 0”);
return new AffineTransform( 0.0, 1.0 / m01,
1.0 / m10, 0.0,
-m12 / m10, -m02 / m01,
(APPLY_SHEAR | APPLY_TRANSLATE));
case (APPLY_SHEAR):
return new AffineTransform(0.0, 1.0 / m01,
1.0 / m10, 0.0,
0.0, 0.0,
(APPLY_SHEAR));
if (m00 == 0.0 || m11 == 0.0) {
return new AffineTransform( 1.0 / m00, 0.0,
0.0, 1.0 / m11,
-m02 / m00, -m12 / m11,
(APPLY_SCALE | APPLY_TRANSLATE));
case (APPLY_SCALE):
return new AffineTransform(1.0 / m00, 0.0,
0.0, 1.0 / m11,
0.0, 0.0,
(APPLY_SCALE));
return new AffineTransform( 1.0, 0.0,
0.0, 1.0,
-m02, -m12,
(APPLY_TRANSLATE));
return new AffineTransform();
NOTREACHED /
public void invert()
double M00, M01, M02;
double M10, M11, M12;
double det;
switch (state) {
default:
stateError();
NOTREACHED /
M00 = m00; M01 = m01; M02 = m02;
M10 = m10; M11 = m11; M12 = m12;
det = M00 * M11 - M01 * M10;
det);
m00 = M11 / det;
m10 = -M10 / det;
m01 = -M01 / det;
m11 = M00 / det;
m02 = (M01 * M12 - M11 * M02) / det;
m12 = (M10 * M02 - M00 * M12) / det;
break;
det);
m00 = M11 / det;
m10 = -M10 / det;
m01 = -M01 / det;
m11 = M00 / det;
// m02 = 0.0;
// m12 = 0.0;
break;
M10 = m10; M12 = m12;
if (M01 == 0.0 || M10 == 0.0) {
// m00 = 0.0;
m10 = 1.0 / M01;
m01 = 1.0 / M10;
// m11 = 0.0;
m02 = -M12 / M10;
m12 = -M02 / M01;
break;
case (APPLY_SHEAR):
M01 = m01;
M10 = m10;
// m00 = 0.0;
m10 = 1.0 / M01;
m01 = 1.0 / M10;
// m11 = 0.0;
// m02 = 0.0;
// m12 = 0.0;
break;
M00 = m00; M02 = m02;
if (M00 == 0.0 || M11 == 0.0) {
m00 = 1.0 / M00;
// m10 = 0.0;
// m01 = 0.0;
m11 = 1.0 / M11;
m02 = -M02 / M00;
m12 = -M12 / M11;
break;
case (APPLY_SCALE):
M00 = m00;
M11 = m11;
m00 = 1.0 / M00;
// m10 = 0.0;
// m01 = 0.0;
m11 = 1.0 / M11;
// m02 = 0.0;
// m12 = 0.0;
break;
// m00 = 1.0;
// m10 = 0.0;
// m01 = 0.0;
// m11 = 1.0;
m02 = -m02;
m12 = -m12;
break;
// m00 = 1.0;
// m10 = 0.0;
// m01 = 0.0;
// m11 = 1.0;
// m02 = 0.0;
// m12 = 0.0;
break;
public Point2D transform(Point2D ptSrc, Point2D ptDst) {
if (ptDst == null) {
if (ptSrc instanceof Point2D.Double) {
ptDst = new Point2D.Double();
} else {
ptDst = new Point2D.Float();
// Copy source coords into local variables in case src == dst
double x = ptSrc.getX();
double y = ptSrc.getY();
switch (state) {
default:
stateError();
NOTREACHED /
ptDst.setLocation(x * m00 + y * m01 + m02,
x * m10 + y * m11 + m12);
return ptDst;
ptDst.setLocation(x * m00 + y * m01, x * m10 + y * m11);
return ptDst;
ptDst.setLocation(y * m01 + m02, x * m10 + m12);
return ptDst;
case (APPLY_SHEAR):
ptDst.setLocation(y * m01, x * m10);
return ptDst;
ptDst.setLocation(x * m00 + m02, y * m11 + m12);
return ptDst;
case (APPLY_SCALE):
ptDst.setLocation(x * m00, y * m11);
return ptDst;
ptDst.setLocation(x + m02, y + m12);
return ptDst;
ptDst.setLocation(x, y);
return ptDst;
NOTREACHED /
public void transform(Point2D[] ptSrc, int srcOff,
Point2D[] ptDst, int dstOff,
int numPts) {
while (–numPts >= 0) {
Point2D src = ptSrc[srcOff++];
double x = src.getX();
double y = src.getY();
Point2D dst = ptDst[dstOff++];
if (dst == null) {
if (src instanceof Point2D.Double) {
dst = new Point2D.Double();
} else {
dst = new Point2D.Float();
ptDst[dstOff - 1] = dst;
switch (state) {
default:
stateError();
NOTREACHED /
dst.setLocation(x * m00 + y * m01 + m02,
break;
dst.setLocation(x * m00 + y * m01, x * m10 + y * m11);
break;
dst.setLocation(y * m01 + m02, x * m10 + m12);
break;
case (APPLY_SHEAR):
dst.setLocation(y * m01, x * m10);
break;
dst.setLocation(x * m00 + m02, y * m11 + m12);
break;
case (APPLY_SCALE):
dst.setLocation(x * m00, y * m11);
break;
dst.setLocation(x + m02, y + m12);
break;
dst.setLocation(x, y);
break;
NOTREACHED /
public void transform(float[] srcPts, int srcOff,
float[] dstPts, int dstOff,
int numPts) {
double M00, M01, M02, M10, M11, M12; // For caching
if (dstPts == srcPts &&
dstOff > srcOff && dstOff < srcOff + numPts * 2)
// If the arrays overlap partially with the destination higher
// than the source and we transform the coordinates normally
// we would overwrite some of the later source coordinates
// with results of previous transformations.
// To get around this we use arraycopy to copy the points
// to their final destination with correct overwrite
// handling and then transform them in place in the new
// safer location.
System.arraycopy(srcPts, srcOff, dstPts, dstOff, numPts * 2);
// srcPts = dstPts; // They are known to be equal.
srcOff = dstOff;
switch (state) {
default:
stateError();
NOTREACHED /
double x = srcPts[srcOff++];
double y = srcPts[srcOff++];
dstPts[dstOff++] = (float) (M00 * x + M01 * y + M02);
dstPts[dstOff++] = (float) (M10 * x + M11 * y + M12);
return;
dstPts[dstOff++] = (float) (M00 * x + M01 * y);
dstPts[dstOff++] = (float) (M10 * x + M11 * y);
return;
dstPts[dstOff++] = (float) (M01 * srcPts[srcOff++] + M02);
dstPts[dstOff++] = (float) (M10 * x + M12);
return;
case (APPLY_SHEAR):
M01 = m01; M10 = m10;
dstPts[dstOff++] = (float) (M01 * srcPts[srcOff++]);
dstPts[dstOff++] = (float) (M10 * x);
return;
dstPts[dstOff++] = (float) (M00 * srcPts[srcOff++] + M02);
dstPts[dstOff++] = (float) (M11 * srcPts[srcOff++] + M12);
return;
case (APPLY_SCALE):
M00 = m00; M11 = m11;
dstPts[dstOff++] = (float) (M00 * srcPts[srcOff++]);
dstPts[dstOff++] = (float) (M11 * srcPts[srcOff++]);
return;
M02 = m02; M12 = m12;
dstPts[dstOff++] = (float) (srcPts[srcOff++] + M02);
dstPts[dstOff++] = (float) (srcPts[srcOff++] + M12);
return;
if (srcPts != dstPts || srcOff != dstOff) {
numPts * 2);
return;
NOTREACHED /
public void transform(double[] srcPts, int srcOff,
double[] dstPts, int dstOff,
int numPts) {
// safer location.
srcOff = dstOff;
switch (state) {
default:
stateError();
NOTREACHED /
dstPts[dstOff++] = M00 * x + M01 * y + M02;
dstPts[dstOff++] = M10 * x + M11 * y + M12;
return;
dstPts[dstOff++] = M00 * x + M01 * y;
dstPts[dstOff++] = M10 * x + M11 * y;
return;
dstPts[dstOff++] = M01 * srcPts[srcOff++] + M02;
dstPts[dstOff++] = M10 * x + M12;
return;
case (APPLY_SHEAR):
dstPts[dstOff++] = M01 * srcPts[srcOff++];
dstPts[dstOff++] = M10 * x;
return;
dstPts[dstOff++] = M00 * srcPts[srcOff++] + M02;
dstPts[dstOff++] = M11 * srcPts[srcOff++] + M12;
return;
case (APPLY_SCALE):
dstPts[dstOff++] = M00 * srcPts[srcOff++];
dstPts[dstOff++] = M11 * srcPts[srcOff++];
return;
dstPts[dstOff++] = srcPts[srcOff++] + M02;
dstPts[dstOff++] = srcPts[srcOff++] + M12;
return;
numPts * 2);
return;
NOTREACHED /
int numPts) {
switch (state) {
default:
stateError();
NOTREACHED /
return;
return;
return;
case (APPLY_SHEAR):
return;
return;
case (APPLY_SCALE):
return;
return;
dstPts[dstOff++] = srcPts[srcOff++];
return;
NOTREACHED /
int numPts) {
switch (state) {
default:
stateError();
NOTREACHED /
return;
return;
return;
case (APPLY_SHEAR):
return;
return;
case (APPLY_SCALE):
return;
return;
dstPts[dstOff++] = (float) (srcPts[srcOff++]);
return;
NOTREACHED /
public Point2D inverseTransform(Point2D ptSrc, Point2D ptDst)
} else {
switch (state) {
default:
stateError();
NOTREACHED /
x -= m02;
y -= m12;
NOBREAK /
double det = m00 * m11 - m01 * m10;
det);
ptDst.setLocation((x * m11 - y * m01) / det,
(y * m00 - x * m10) / det);
return ptDst;
x -= m02;
y -= m12;
NOBREAK /
case (APPLY_SHEAR):
ptDst.setLocation(y / m10, x / m01);
return ptDst;
x -= m02;
y -= m12;
NOBREAK /
case (APPLY_SCALE):
ptDst.setLocation(x / m00, y / m11);
return ptDst;
ptDst.setLocation(x - m02, y - m12);
return ptDst;
return ptDst;
NOTREACHED /
public void inverseTransform(double[] srcPts, int srcOff,
int numPts)
double det;
// safer location.
srcOff = dstOff;
switch (state) {
default:
stateError();
NOTREACHED /
det);
double x = srcPts[srcOff++] - M02;
double y = srcPts[srcOff++] - M12;
dstPts[dstOff++] = (x * M11 - y * M01) / det;
dstPts[dstOff++] = (y * M00 - x * M10) / det;
return;
det);
return;
dstPts[dstOff++] = (srcPts[srcOff++] - M12) / M10;
dstPts[dstOff++] = x / M01;
return;
case (APPLY_SHEAR):
dstPts[dstOff++] = srcPts[srcOff++] / M10;
return;
dstPts[dstOff++] = (srcPts[srcOff++] - M02) / M00;
dstPts[dstOff++] = (srcPts[srcOff++] - M12) / M11;
return;
case (APPLY_SCALE):
dstPts[dstOff++] = srcPts[srcOff++] / M00;
dstPts[dstOff++] = srcPts[srcOff++] / M11;
return;
dstPts[dstOff++] = srcPts[srcOff++] - M02;
dstPts[dstOff++] = srcPts[srcOff++] - M12;
return;
numPts * 2);
return;
NOTREACHED /
public Point2D deltaTransform(Point2D ptSrc, Point2D ptDst) {
} else {
switch (state) {
default:
stateError();
NOTREACHED /
return ptDst;
case (APPLY_SHEAR):
return ptDst;
case (APPLY_SCALE):
return ptDst;
return ptDst;
NOTREACHED /
public void deltaTransform(double[] srcPts, int srcOff,
int numPts) {
double M00, M01, M10, M11; // For caching
// safer location.
srcOff = dstOff;
switch (state) {
default:
stateError();
NOTREACHED /
dstPts[dstOff++] = x * M00 + y * M01;
dstPts[dstOff++] = x * M10 + y * M11;
return;
case (APPLY_SHEAR):
dstPts[dstOff++] = srcPts[srcOff++] * M01;
dstPts[dstOff++] = x * M10;
return;
case (APPLY_SCALE):
dstPts[dstOff++] = srcPts[srcOff++] * M00;
dstPts[dstOff++] = srcPts[srcOff++] * M11;
return;
numPts * 2);
return;
NOTREACHED */
public Shape createTransformedShape(Shape pSrc) {
if (pSrc == null) {
return null;
return new Path2D.Double(pSrc, this);
// Round values to sane precision for printing
// Note that Math.sin(Math.PI) has an error of about 10^-16
private static double _matround(double matval) {
return Math.rint(matval * 1E15) / 1E15;
return (“AffineTransform[[”
  • _matround(m00) + ", "
  • _matround(m01) + ", "
  • _matround(m02) + “], [”
  • _matround(m10) + ", "
  • _matround(m11) + ", "
  • _matround(m12) + “]]”);
    public boolean isIdentity() {
    return (state == APPLY_IDENTITY || (getType() == TYPE_IDENTITY));
    /* public Object clone() {
    try {
    return super.clone();
    } catch (CloneNotSupportedException e) {
    // this shouldn’t happen, since we are Cloneable
    throw new InternalError();
    public int hashCode() {
    long bits = Double.doubleToLongBits(m00);
    bits = bits * 31 + Double.doubleToLongBits(m01);
    bits = bits * 31 + Double.doubleToLongBits(m02);
    bits = bits * 31 + Double.doubleToLongBits(m10);
    bits = bits * 31 + Double.doubleToLongBits(m11);
    bits = bits * 31 + Double.doubleToLongBits(m12);
    return (((int) bits) ^ ((int) (bits >> 32)));
    public boolean equals(Object obj) {
    if (!(obj instanceof AffineTransform)) {
    return false;
    AffineTransform a = (AffineTransform)obj;
    return ((m00 == a.m00) && (m01 == a.m01) && (m02 == a.m02) &&
    (m10 == a.m10) && (m11 == a.m11) && (m12 == a.m12));
  • JDK 1.2 serialVersionUID
    private static final long serialVersionUID = 1330973210523860834L;
    private void writeObject(java.io.ObjectOutputStream s)
    throws java.lang.ClassNotFoundException, java.io.IOException
    s.defaultWriteObject();
    private void readObject(java.io.ObjectInputStream s)
    s.defaultReadObject();
    updateState();
=========================[ERROR] BUILD FAILURE======================================================
[INFO] Installing E:\myGeoserver\downloadSourceCode\src\wcs1_0\target\wcs1_0-2.1
-SNAPSHOT.jar to C:\Users\Administrator.m2\repository\org\geoserver\wcs1_0\2.1-
SNAPSHOT\wcs1_0-2.1-SNAPSHOT.jar
-SNAPSHOT-tests.jar to C:\Users\Administrator.m2\repository\org\geoserver\wcs1_
0\2.1-SNAPSHOT\wcs1_0-2.1-SNAPSHOT-tests.jar
-SNAPSHOT-sources.jar to C:\Users\Administrator.m2\repository\org\geoserver\wcs
1_0\2.1-SNAPSHOT\wcs1_0-2.1-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service 1.1 Module
[INFO] [clean:clean]
[INFO] Deleting directory E:\myGeoserver\downloadSourceCode\src\wcs1_1\target
[INFO] [javacc:jjtree {execution: jjtree}]
Java Compiler Compiler Version 4.0 (Tree Builder)
(type “jjtree” with no arguments for help)
Warning: Output directory “E:\myGeoserver\downloadSourceCode\src\wcs1_1\target\g
enerated-sources\jjtree\org\geoserver\wcs\kvp\rangesubset” does not exist. Creat
ing the directory.
Reading from file E:\myGeoserver\downloadSourceCode\src\wcs1_1\src\main\java\org
\geoserver\wcs\kvp\rangesubset\rangeset.jjt . . .
Warning: Duplicate option setting for “VISITOR” will be ignored.
File “E:\myGeoserver\downloadSourceCode\src\wcs1_1\target\generated-sources\jjtr
ee\org\geoserver\wcs\kvp\rangesubset\Node.java” does not exist. Will create one
ee\org\geoserver\wcs\kvp\rangesubset\SimpleNode.java” does not exist. Will crea
te one.
ee\org\geoserver\wcs\kvp\rangesubset\ASTRangeSubset.java” does not exist. Will
create one.
ee\org\geoserver\wcs\kvp\rangesubset\ASTFieldSubset.java” does not exist. Will
create one.
ee\org\geoserver\wcs\kvp\rangesubset\ASTAxisSubset.java” does not exist. Will c
reate one.
ee\org\geoserver\wcs\kvp\rangesubset\ASTFieldId.java” does not exist. Will crea
te one.
ee\org\geoserver\wcs\kvp\rangesubset\ASTAxisId.java” does not exist. Will creat
e one.
ee\org\geoserver\wcs\kvp\rangesubset\ASTInterpolation.java” does not exist. Wil
l create one.
ee\org\geoserver\wcs\kvp\rangesubset\ASTKey.java” does not exist. Will create o
ne.
Annotated grammar generated successfully in E:\myGeoserver\downloadSourceCode\sr
c\wcs1_1\target\generated-sources\jjtree\org\geoserver\wcs\kvp\rangesubset\range
set.jj
[INFO] [javacc:javacc {execution: javacc}]
Java Compiler Compiler Version 4.0 (Parser Generator)
(type “javacc” with no arguments for help)
Reading from file E:\myGeoserver\downloadSourceCode\src\wcs1_1\target\generated-
sources\jjtree\org\geoserver\wcs\kvp\rangesubset\rangeset.jj . . .
File “TokenMgrError.java” does not exist. Will create one.
File “ParseException.java” does not exist. Will create one.
File “Token.java” does not exist. Will create one.
File “SimpleCharStream.java” does not exist. Will create one.
Parser generated successfully.
[INFO] [resources:resources]
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO] Copying 11 resources
[INFO] skip non existing resourceDirectory E:\myGeoserver\downloadSourceCode\src
\wcs1_1\src\main\resources
[INFO] [compiler:compile]
[INFO] Compiling 58 source files to E:\myGeoserver\downloadSourceCode\src\wcs1_1
\target\classes
[INFO] [resources:testResources]
[INFO] Copying 1 resource
[INFO] [compiler:testCompile]
[INFO] Compiling 13 source files to E:\myGeoserver\downloadSourceCode\src\wcs1_1
\target\test-classes
[INFO] [surefire:test]
[INFO] Tests are skipped.
[INFO] [jar:jar]
[INFO] Building jar: E:\myGeoserver\downloadSourceCode\src\wcs1_1\target\wcs1_1-
2.1-SNAPSHOT.jar
[INFO] Preparing source:jar
[INFO] Nothing to process - all grammars in E:\myGeoserver\downloadSourceCode\sr
c\wcs1_1\src\main\java\org\geoserver\wcs\kvp\rangesubset are up to date.
c\wcs1_1\target\generated-sources\jjtree are up to date.
[INFO] [install:install]
[INFO] Installing E:\myGeoserver\downloadSourceCode\src\wcs1_1\target\wcs1_1-2.1
-SNAPSHOT.jar to C:\Users\Administrator.m2\repository\org\geoserver\wcs1_1\2.1-
SNAPSHOT\wcs1_1-2.1-SNAPSHOT.jar
1\2.1-SNAPSHOT\wcs1_1-2.1-SNAPSHOT-tests.jar
1_1\2.1-SNAPSHOT\wcs1_1-2.1-SNAPSHOT-sources.jar
[INFO] Building Web Feature Service Module
[INFO] Deleting directory E:\myGeoserver\downloadSourceCode\src\wfs\target
[INFO] Copying 9 resources
\wfs\src\main\resources
[INFO] Compiling 178 source files to E:\myGeoserver\downloadSourceCode\src\wfs\t
arget\classes
[INFO] Copying 14 resources
[INFO] Compiling 47 source files to E:\myGeoserver\downloadSourceCode\src\wfs\ta
rget\test-classes
[INFO] [jar:jar]
[INFO] Building jar: E:\myGeoserver\downloadSourceCode\src\wfs\target\wfs-2.1-SN
APSHOT.jar
APSHOT-tests.jar
APSHOT-sources.jar
[INFO] Installing E:\myGeoserver\downloadSourceCode\src\wfs\target\wfs-2.1-SNAPS
HOT.jar to C:\Users\Administrator.m2\repository\org\geoserver\wfs\2.1-SNAPSHOT
wfs-2.1-SNAPSHOT.jar
HOT-tests.jar to C:\Users\Administrator.m2\repository\org\geoserver\wfs\2.1-SNA
PSHOT\wfs-2.1-SNAPSHOT-tests.jar
HOT-sources.jar to C:\Users\Administrator.m2\repository\org\geoserver\wfs\2.1-S
NAPSHOT\wfs-2.1-SNAPSHOT-sources.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory E:\myGeoserver\downloadSourceCode\src\wms\target
[INFO] Copying 8 resources
[INFO] snapshot org.geotools:gt-svg:2.7-SNAPSHOT: checking for updates from open
geo
[INFO] snapshot org.geotools:gt-svg:2.7-SNAPSHOT: checking for updates from osge
o
3K downloaded
[INFO] snapshot org.geotools:gt-shapefile-renderer:2.7-SNAPSHOT: checking for up
dates from opengeo
dates from osgeo
3K downloaded
8K downloaded
73K downloaded
[INFO] Compiling 158 source files to E:\myGeoserver\downloadSourceCode\src\wms\t
arget\classes
[INFO] Compilation failure
E:\myGeoserver\downloadSourceCode\src\wms\src\main\java\org\geoserver\wms\GetMap
Request.java:[8,28] cannot find symbol
symbol : class Point2D
Request.java:[211,11] cannot find symbol
Request.java:[489,31] cannot find symbol
Request.java:[675,15] cannot find symbol
location: class org.geoserver.wms.GetMapRequest.OptionalParameters
E:\myGeoserver\downloadSourceCode\src\wms\src\main\java\org\geoserver\wms\kvp\Ti
lesOriginKvpParser.java:[6,28] cannot find symbol
E:\myGeoserver\downloadSourceCode\src\wms\src\main\java\org\geoserver\wms\map\Me
tatileMapOutputFormat.java:[7,28] cannot find symbol
E:\myGeoserver\downloadSourceCode\src\wms\src\main\java\org\geoserver\wms\map\Qu
ickTileCache.java:[8,28] cannot find symbol
ickTileCache.java:[143,43] cannot find symbol
ickTileCache.java:[213,8] cannot find symbol
location: class org.geoserver.wms.map.QuickTileCache.MapKey
ickTileCache.java:[215,63] cannot find symbol
E:\myGeoserver\downloadSourceCode\src\wms\src\main\java\org\geoserver\wms\GetFea
tureInfo.java:[9,28] cannot find symbol
symbol : class AffineTransform
tureInfo.java:[12,28] cannot find symbol
tureInfo.java:[725,12] cannot find symbol
lesOriginKvpParser.java:[17,36] package Point2D does not exist
lesOriginKvpParser.java:[32,30] package Point2D does not exist
ickTileCache.java:[94,8] cannot find symbol
tatileMapOutputFormat.java:[146,8] cannot find symbol
location: class org.geoserver.wms.map.MetatileMapOutputFormat
tureInfo.java:[692,8] cannot find symbol
tureInfo.java:[694,8] cannot find symbol
tureInfo.java:[701,71] package org.geoserver.wms.map.Point2D does not exist
tureInfo.java:[702,53] package org.geoserver.wms.map.Point2D does not exist
tureInfo.java:[732,8] cannot find symbol
tureInfo.java:[732,33] cannot find symbol
[INFO] Total time: 10 minutes 35 seconds
[INFO] Finished at: Fri Nov 12 11:17:39 PST 2010
[INFO] Final Memory: 42M/101M
E:\myGeoserver\downloadSourceCode\src>
