i did a fresh checkout of todays geoserver. build it. it went fine. but when
i try runing it in tomcat. i get a sever error. this is the log:
157 [INFO] org.vfny.geoserver.global.xml.XMLConfigReader - Decoding file
name:
tasmania_state_boundaries:::tasmania_state_boundaries
157 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - Loading
configurat
ion file:
E:\tools\apache-tomcat-5.5.17\webapps\geoserver_new\data\featureTypes\
tasmania_water_bodies\info.xml
157 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - added
featureType
name:
tasmania_water_bodies:::tasmania_water_bodies
204 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for
category CRSFactory:
org.geotools.referencing.factory.GeotoolsFactory
282 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for
category DatumFactory:
org.geotools.referencing.factory.DatumAliases
implementations for
category MathTransformFactory:
org.geotools.referencing.operation.DefaultMathTransformFactory
422 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for
category GridFormatFactorySpi:
org.geotools.gce.arcgrid.ArcGridFormatFactory
org.geotools.gce.geotiff.GeoTiffFormatFactorySpi
org.geotools.gce.gtopo30.GTopo30FormatFactory
org.geotools.gce.image.WorldImageFormatFactory
org.geotools.gce.imagemosaic.ImageMosaicFormatFactory
org.geotools.gce.imagepyramid.ImagePyramidFormatFactory
454 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for
category GridCoverageFactory:
org.geotools.coverage.grid.GridCoverageFactory
469 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for
category CoordinateOperationFactory:
org.geotools.referencing.operation.DefaultCoordinateOperationFactory
org.geotools.referencing.operation.AuthorityBackedFactory
org.geotools.referencing.operation.BufferedCoordinateOperationFactory
implementations for
category CSFactory:
485 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for
category CoordinateOperationAuthorityFactory:
org.geotools.referencing.factory.epsg.DefaultFactory
500 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations for
category DataSource:
org.geotools.referencing.factory.epsg.HSQLDataSource
844 [CONFIG] - Connected to EPSG database
"jdbc:hsqldb:file:/E:/tools/apache (
...) temp/Geotools/Databases/HSQL/EPSG" on "HSQL Database Engine".
1172 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations fo
r category CRSAuthorityFactory:
org.geotools.referencing.factory.epsg.LongitudeFirstFactory
org.geotools.referencing.factory.wms.AutoCRSFactory
org.geotools.referencing.factory.wms.WebCRSFactory
1422 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations fo
r category MathTransformProvider:
org.geotools.referencing.operation.transform.LogarithmicTransform1D$Provider
org.geotools.referencing.operation.transform.ExponentialTransform1D$Provider
org.geotools.referencing.operation.transform.ProjectiveTransform$ProviderAffin
e
org.geotools.referencing.operation.transform.ProjectiveTransform$ProviderLongi
tudeRotation
org.geotools.referencing.operation.transform.GeocentricTranslation$Provider
org.geotools.referencing.operation.transform.GeocentricTranslation$ProviderSev
enParam
org.geotools.referencing.operation.transform.GeocentricTranslation$ProviderFra
meRotation
org.geotools.referencing.operation.transform.GeocentricTransform$Provider
org.geotools.referencing.operation.transform.GeocentricTransform$ProviderInver
se
org.geotools.referencing.operation.transform.MolodenskiTransform$Provider
org.geotools.referencing.operation.transform.MolodenskiTransform$ProviderAbrid
ged
org.geotools.referencing.operation.transform.NADCONTransform$Provider
org.geotools.referencing.operation.transform.WarpTransform2D$Provider
org.geotools.referencing.operation.projection.EquidistantCylindrical$Provider
org.geotools.referencing.operation.projection.PlateCarree$Provider
org.geotools.referencing.operation.projection.Mercator1SP$Provider
org.geotools.referencing.operation.projection.Mercator2SP$Provider
org.geotools.referencing.operation.projection.TransverseMercator$Provider
org.geotools.referencing.operation.projection.TransverseMercator$Provider_Sout
hOrientated
org.geotools.referencing.operation.projection.ObliqueMercator$Provider
org.geotools.referencing.operation.projection.ObliqueMercator$Provider_Hotine
org.geotools.referencing.operation.projection.ObliqueMercator$Provider_TwoPoin
t
org.geotools.referencing.operation.projection.ObliqueMercator$Provider_Hotine_
TwoPoint
org.geotools.referencing.operation.projection.AlbersEqualArea$Provider
org.geotools.referencing.operation.projection.LambertConformal1SP$Provider
org.geotools.referencing.operation.projection.LambertConformal2SP$Provider
org.geotools.referencing.operation.projection.LambertConformalBelgium$Provider
org.geotools.referencing.operation.projection.LambertConformalESRI$Provider
org.geotools.referencing.operation.projection.Orthographic$Provider
org.geotools.referencing.operation.projection.Stereographic$Provider_Oblique
org.geotools.referencing.operation.projection.Stereographic$Provider_Polar_A
org.geotools.referencing.operation.projection.Stereographic$Provider_Polar_B
org.geotools.referencing.operation.projection.Stereographic$Provider_North_Pol
e
org.geotools.referencing.operation.projection.Stereographic$Provider_South_Pol
e
org.geotools.referencing.operation.projection.Stereographic$Provider_USGS
org.geotools.referencing.operation.projection.NewZealandMapGrid$Provider
org.geotools.referencing.operation.projection.Krovak$Provider
1797 [CONFIG] org.geotools.factory.FactoryRegistry - Factory
implementations fo
r category DataStoreFactorySpi:
org.geotools.data.property.PropertyDataStoreFactory
org.geotools.data.dir.DirectoryDataStoreFactory
org.geotools.data.gml.GMLDataStoreFactory
org.geotools.data.shapefile.indexed.IndexedShapefileDataStoreFactory
org.geotools.data.postgis.PostgisDataStoreFactory
org.geotools.data.shapefile.ShapefileDataStoreFactory
1813 [SEVERE] org.vfny.geoserver.global.Data - FeatureTypeInfo
tasmania_state_b
oundaries:::tasmania_state_boundaries ignored - as DataStore
tasmania_state_boun
daries is unavailable:java.io.FileNotFoundException:
17\webapps\geoserver_new\data\taz_shapes\tasmania_state_boundaries.shp
cdf:::Nulls coul
d not be used - DataStore cdf is not defined!
cgf:::MLines cou
ld not be used - DataStore cgf is not defined!
DS_tiger_roads::
:tiger_roads ignored - as DataStore DS_tiger_roads is
tFoundException:
E:\tools\apache-tomcat-5.5.17\webapps\geoserver_new\data\nyc\ti
ger_roads.shp
1829 [SEVERE] org.vfny.geoserver.global.Data - FeatureTypeInfo
cdf:::Locks coul
cgf:::Lines coul
tasmania_cities:
::tasmania_cities ignored - as DataStore tasmania_cities is
taz_shapes\tasmania_cities.shp
tasmania_roads::
:tasmania_roads ignored - as DataStore tasmania_roads is
eNotFoundException:
E:\tools\apache-tomcat-5.5.17\webapps\geoserver_new\data\taz
_shapes\tasmania_roads.shp
cgf:::Points cou
cdf:::Other coul
DS_giant_polygon
:::giant_polygon ignored - as DataStore DS_giant_polygon is
nyc\giant_polygon.shp
cgf:::MPoints co
uld not be used - DataStore cgf is not defined!
cgf:::MPolygons
could not be used - DataStore cgf is not defined!
tasmania_water_b
odies:::tasmania_water_bodies ignored - as DataStore tasmania_water_bodies
is un
eoserver_new\data\taz_shapes\tasmania_water_bodies.shp
DS_poi:::poi ign
ored - as DataStore DS_poi is unavailable:java.io.FileNotFoundException:
E:\tool
s\apache-tomcat-5.5.17\webapps\geoserver_new\data\nyc\poi.shp
cdf:::Deletes co
uld not be used - DataStore cdf is not defined!
states_shapefile
:::states ignored - as DataStore states_shapefile is
FoundException:
E:\tools\apache-tomcat-5.5.17\webapps\geoserver_new\data\shapefi
les\states.shp
DS_poly_landmark
s:::poly_landmarks ignored - as DataStore DS_poly_landmarks is
unavailable:java.
ta\nyc\poly_landmarks.shp
cdf:::Seven coul
cdf:::Updates co
cdf:::Fifteen co
cdf:::Inserts co
cgf:::Polygons c
29.1.2007 13:02:18
org.springframework.beans.factory.support.AbstractBeanFactory
destroySingletons
INFO: Destroying singletons in factory
{org.springframework.beans.factory.suppor
t.DefaultListableBeanFactory defining beans
[catalog,serviceFinder,wfs,wfsConfig
,wfsRegisterar,wfsConfigRegisterar,wfsAbstractService,wfsService,wfsGetCapabilit
ies,wfsDescribeFeatureType,wfsGetFeature,wfsLockFeature,wfsGetFeatureWithLock,wf
sTransaction,validation,validationConfig,validationRegisterar,validationConfigRe
gisterar,wcs,wcsConfig,wcsRegisterar,wcsConfigRegisterar,wcsAbstractService,wcsS
ervice,wcsGetCapabilities,wcsDescribeCoverage,wcsGetCoverage,applicationState,ap
plicationStateRegisterar,config,geoServer,globalConfig,data,dataConfig,dataRegis
terar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegisterar,speedServi
ceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrateg
y,wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbstractService,wmsService,
wmsGetCapabilities,wmsDescribeFeatureType,wmsGetFeatureInfo,wmsGetLegendGraphic,
wmsGetMap,wmsGetMapLegacy,wmsPutStyles,kmlReflector,GIFLegendProducerFactory,Jai
LegendProducerFactory,PNGLegendProducerFactory,PNGMapProducerFactory,GeoTiffMapP
roducerFactory,TiffMapProducerFactory,SVGMapProducerFactory,GIFMapProducerFactor
y,KMLMapProducerFactory,KMZMapProducerFactory,PDFMapProducerFactory,JPEGMapProdu
cerFactory]; root of BeanFactory hierarchy}
29.1.2007 13:02:18 org.springframework.web.context.ContextLoader
initWebApplicat
ionContext
SEVERE: Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating
bean wit
h name 'dataConfig' defined in URL
[jar:file:/E:/tools/apache-tomcat-5.5.17/weba
pps/geoserver_new/WEB-INF/lib/main-1.5.0-beta2.jar!/applicationContext.xml]:
Ins
tantiation of bean failed; nested exception is
org.springframework.beans.FatalBe
anException: Could not instantiate class
[org.vfny.geoserver.config.DataConfig];
constructor threw exception; nested exception is
java.lang.NullPointerException
: null
org.springframework.beans.FatalBeanException: Could not instantiate class
[org.v
fny.geoserver.config.DataConfig]; constructor threw exception; nested
exception
is java.lang.NullPointerException: null
at
org.vfny.geoserver.global.CoverageInfo.getPrefix(CoverageInfo.java:35
3)
at
org.vfny.geoserver.global.CoverageInfo.getName(CoverageInfo.java:375)
at org.vfny.geoserver.global.Data.toDTO(Data.java:998)
at
org.vfny.geoserver.config.DataConfig.<init>(DataConfig.java:217)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native
Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstruct
orAccessorImpl.java:39)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingC
onstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:494)
at
org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:1
00)
at
org.springframework.beans.factory.support.SimpleInstantiationStrategy
.instantiate(SimpleInstantiationStrategy.java:75)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBean
Factory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:669)
at
Factory.createBean(AbstractAutowireCapableBeanFactory.java:329)
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean
(AbstractBeanFactory.java:226)
at
(AbstractBeanFactory.java:147)
at
org.springframework.beans.factory.support.DefaultListableBeanFactory.
preInstantiateSingletons(DefaultListableBeanFactory.java:275)
at
org.springframework.context.support.AbstractApplicationContext.refres
h(AbstractApplicationContext.java:318)
at
org.springframework.web.context.support.AbstractRefreshableWebApplica
tionContext.refresh(AbstractRefreshableWebApplicationContext.java:134)
at
org.springframework.web.context.ContextLoader.createWebApplicationCon
text(ContextLoader.java:230)
at
org.springframework.web.context.ContextLoader.initWebApplicationConte
xt(ContextLoader.java:156)
at
org.springframework.web.context.ContextLoaderListener.contextInitiali
zed(ContextLoaderListener.java:48)
at
org.apache.catalina.core.StandardContext.listenerStart(StandardContex
t.java:3729)
at
org.apache.catalina.core.StandardContext.start(StandardContext.java:4
187)
at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase
.java:759)
at
org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:73
9)
at
org.apache.catalina.core.StandardHost.addChild(StandardHost.java:524)
at
org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:809)
at
org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:698
at
org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:472
at
org.apache.catalina.startup.HostConfig.start(HostConfig.java:1122)
at
org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java
:310)
at
org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(Lifecycl
eSupport.java:119)
at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1021)
at
org.apache.catalina.core.StandardHost.start(StandardHost.java:718)
at
org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1013)
at
org.apache.catalina.core.StandardEngine.start(StandardEngine.java:442
at
org.apache.catalina.core.StandardService.start(StandardService.java:4
50)
at
org.apache.catalina.core.StandardServer.start(StandardServer.java:709
at org.apache.catalina.startup.Catalina.start(Catalina.java:551)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:294)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:432)
29.1.2007 13:02:18 org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context [/geoserver_new] startup failed due to previous errors
29.1.2007 13:02:19 org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-50
29.1.2007 13:02:19 org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
29.1.2007 13:02:19 org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/0 config=null
29.1.2007 13:02:19 org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
29.1.2007 13:02:19 org.apache.catalina.startup.Catalina start
INFO: Server startup in 4125 ms
