[Geoserver-devel] GeoServer builds broken by failing geogig-master build
Erik,
GeoServer builds on all branches (master, 2.11.x, 2.10.x, and 2.9.x) are broken because the geogig-master build is failing and has not updated the 1.1-SNAPSHOT jars to include the most recent API changes:
https://ci.locationtech.org/geogig/job/geogig-master/
Travis CI correctly identified that these pull requests would cause the GeoServer builds to fail. One of these checks had failed and three were still pending at the time that you merged these pull requests:
https://github.com/geoserver/geoserver/pull/2183
https://github.com/geoserver/geoserver/pull/2186
https://github.com/geoserver/geoserver/pull/2185
https://github.com/geoserver/geoserver/pull/2184
Once the geogig-master build has been fixed, please restart all the failing GeoServer Jenkins builds and all the Travis CI branch builds and pull request builds that failed because of this outage. I can help with this step.
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
I am sorry Ben, it does not seem to be a good day for build servers - the LocationTech build server was troubled earlier in the day (timing out when Erik was trying to reach it).
I am going to go remove geogig from the ares build jobs as a temporary measure while this is resolved.
On 23 March 2017 at 17:54, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Erik,
Kind regards,
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Jody Garnett
Jody,
do you mean removing geogig from the communityRelease profile?
Kind regards,
Ben.
Jody Garnett
Erik,
this step.
Kind regards,
Director
New Zealand
Director
New Zealand
No I changed the jobs to say -PcommunityRelease,!geogig
On 23 March 2017 at 18:21, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Jody,
Kind regards,
Ben.
Jody Garnett
Erik,
this step.
Kind regards,
Director
New Zealand
Director
New Zealand
Jody Garnett
Sigh it did not work, I escaped the bang and everything:
mvn -f src/community/pom.xml -B -U -DskipTests -PcommunityRelease,\!geogig clean install -DconfigDirectory=../../../data -T2 -fae
Next step as you say is removing geogig from the communityRelease so you can work today.
Jody Garnett
Jody Garnett
Jody,
Kind regards,
Ben.
Jody Garnett
Erik,
this step.
Kind regards,
Director
New Zealand
Director
New Zealand
My apologies. I merged the changes in GeoServer before I realized the LocationTech build server wasn’t properly building GeoGig. Trying to get things in too eagerly. I will not do that again.
If the geogig module hasn’t already been removed from the communityRelease list, I can make that change now, until the LocationTech build servers are functioning again.
Again, my sincerest apologies,
On Thu, Mar 23, 2017 at 9:00 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Erik Merkle
Software Engineer | Boundless
Jody Garnett
Jody Garnett
Jody,
Kind regards,
Ben.
Jody Garnett
Erik,
this step.
Kind regards,
Director
New Zealand
Director
New Zealand
Thanks for trying, Jody. My main concern is the loss of continuous integration and impact on Travis CI for pull requests. I am not submitting or merging pull requests today so am not yet personally affected.
As an aside, the Maven option that works for me is "-pl", which can be used to exclude a module by giving its path relative to the top-level pom. I use it to exclude app-schema oracle online tests. In the geogig case below, this would be:
-pl '!geogig'
However, I do not think that we should modify all the Jenkins and Travis CI builds as we will only have to change them all back, and community modules that do not compile are not permitted in the communityRelease profile. We should not need magic options to build.
When do we expect to see a successful geogig-master build? If we are likely to get one in the next 12 hours, we should just wait, otherwise we should remove geogig from the communityRelease profile on all affected branches.
Kind regards,
Ben.
can work today.
Jody Garnett
Jody Garnett
Jody,
Kind regards,
Ben.
when
Jody Garnett
Erik,
the
this step.
Kind regards,
Director
New Zealand
Director
New Zealand
Director
New Zealand
Yes, please, Erik. As discussed in my other email, unless you expect a successful geogig-master build in the next few hours, please remove geogig from the communityRelease profile on all affected branches.
Kind regards,
Ben.
LocationTech build server wasn't properly building GeoGig. Trying to get
If the geogig module hasn't already been removed from the communityRelease
functioning again.
Erik Merkle
Software Engineer | Boundless <http://boundlessgeo.com/&gt;
<http://d32wfbeasdaw38.cloudfront.net/img/Boundless_Logo.png&gt;
can work today.
Jody Garnett
Jody Garnett
Jody,
Kind regards,
Ben.
the
when
Jody Garnett
Erik,
are
the
and
this step.
Kind regards,
Director
New Zealand
Director
New Zealand
Director
New Zealand
Oh, and I see from the Jenkins notifications that Jody has already removed geogig and the builds are recovering. Thanks!
Kind regards,
Ben.
Kind regards,
Ben.
functioning again.
Erik Merkle
can work today.
Jody Garnett
Jody Garnett
Jody,
Kind regards,
Ben.
the
when
Jody Garnett
Erik,
are
the
and
this step.
Kind regards,
Director
New Zealand
Director
New Zealand
Director
New Zealand
I’ve previously sent a mail suggesting the geogig plugin to be built with its own dedicated
build on ares, as it’s frequently breaking the builds (compile wise) in GeoServer.
This would also give you the added benefit of being able to run tests on it :slight_smile:
On Fri, Mar 24, 2017 at 1:54 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Erik,
this step.
Kind regards,
Director
New Zealand
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I have just set that up with Erik for master, if that works as intended we will back port to the other branches.
On 24 March 2017 at 00:19, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
On Fri, Mar 24, 2017 at 1:54 AM, Ben Caradoc-Davies <ben@…4191…> wrote:
Erik,
this step.
Kind regards,
Director
New Zealand
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
All, the LocationTech build servers that build the GeoGig core artifacts appear to be functioning again. I’m going to re-trigger the build for this PR:
https://github.com/geoserver/geoserver/pull/2191
Merging this PR will compile the GeoGig module in the Travis build when a GeoServer PR is created, but the GeoGig module will remain disabled in the communityRelease for now. Once merged, GeoGig compilation/build issues may cause GeoServer GitHub Travis builds to fail, but they won’t cause GeoServer builds to fail. If this is an acceptable measure, Jody would you mind merging the PR and backporting. If this is not an acceptable measure, please let me know and I will try to come up with a better solution.
Again, my apologies for the inconveniences caused. When the GeoGig API gets to a less fluid state, we (the GeoGig team) can propose to re-enable the module in the communityRelease.
Many thanks,
On Fri, Mar 24, 2017 at 2:25 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Erik Merkle
Jody Garnett
Erik,
this step.
Kind regards,
Director
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
Erik,
I am unhappy with this pull request because it makes Travis CI and ares Jenkins inconsistent. This affects all pull requests. I would rather have the geogig module back in the communityRelease profile and closely monitored by GeoGig developers. The recent failure was caused by an infrastructure problem not an API change (there was an API change but the corresponding fixes were immediately merged into GeoServer). I would rather have the ares build fail for a short time every now and then than break the consistency between Travis CI and ares Jenkins.
Another solution could be to make a stable GeoGig branch for GeoServer to consume and backport GeoGig API changes to this branch at your convenience. This will allow you to choose when to deal with API changes on the GeoServer side. You could achieve the same effect with GeoGig milestones or changing the GeoGig pom version. How much GeoGig API change is coming, and which approach do you think would be easiest?
I have no problem with including the geogig module in the communityRelease profile right now if it compiles and will in the future receive your usual close attention.
Kind regards,
Ben.
appear to be functioning again. I'm going to re-trigger the build for this
PR:
cause GeoServer GitHub Travis builds to fail, but they won't cause
Many thanks,
Erik Merkle
Jody Garnett
wrote:
I've previously sent a mail suggesting the geogig plugin to be built with
its own dedicated
build on ares, as it's frequently breaking the builds (compile wise) in
GeoServer.
it :slight_smile:
wrote:
Erik,
this step.
Kind regards,
Director
New Zealand
Check out the vibrant tech community on one of the world's most
Ing. Andrea Aime
@geowolf
Technical Lead
phone: +39 0584 962313 <+39%200584%20962313>
fax: +39 0584 1660272 <+39%200584%20166%200272>
mob: +39 339 8844549 <+39%20339%20884%204549>
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be confidential
or proprietary in nature or covered by the provisions of privacy act
Director
New Zealand
I’m with Ben on this - I don’t like the idea of travis and jenkins diverging, Also a +1 on a stable release of geogig going into GeoServer as we had issues on the sprint yesterday due to me not updating snapshots (since I want to use my local geotools build) not getting the latest GeoGig jars.
Ian
On 29 March 2017 at 22:45, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Erik,
Kind regards,
Ben.
PR:
Many thanks,
Erik Merkle
Software Engineer | Boundless <http://boundlessgeo.com/>
<http://d32wfbeasdaw38.cloudfront.net/img/Boundless_Logo.png>
Jody Garnett
wrote:
its own dedicated
GeoServer.
it :slight_smile:
wrote:
Erik,
this step.
Kind regards,
Director
New Zealand
Geoserver-devel@anonymised.comsourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
Director
New Zealand
Ian Turton
Ben, Ian, thanks for the feedback. I agree it would be best to not have different behaviors. I’ll close the PR.
The GeoGig builds appear to be stable again. I’ll monitor them for a few more days to make sure the problem doesn’t pop back up, as LocationTech wasn’t able to identify the cause of the issue (when they investigated, an VM was down that they restarted and were unable to reproduce the issue). If no issues pop up, I’ll submit a new PR to re-enable the GeoGig module in the communityRelease.
Many thanks,
Ian
Erik Merkle
Erik,
Kind regards,
Ben.
PR:
Many thanks,
Erik Merkle
Jody Garnett
wrote:
its own dedicated
GeoServer.
it :slight_smile:
wrote:
Erik,
this step.
Kind regards,
Director
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
Director
New Zealand
Ian Turton
Ian,
this sounds like the problem I see because I always build with "mvn -nsu" to ensure that I use artifacts from my local geotools build. Because geoscript and geogig are two snapshot dependencies that I do not build locally, the script I use to compile community modules starts with this:
# manually remove external snapshot dependencies
rm -rf ~/.m2/repository/org/geoscript
rm -rf ~/.m2/repository/org/locationtech/geogig
Crude, but effective.
Kind regards,
Ben.
On 30/03/17 20:39, Ian Turton wrote:
I'm with Ben on this - I don't like the idea of travis and jenkins
jars.
Ian
Director
New Zealand
