[Geoserver-devel] GeoServer CatalogPostModifyEvent not storing change state?
Hello,
Does anyone know of any technical reason why the CatalogPostModifyEvent does not store the before/after state of the CatalogInfo object (similar to the CatalogModifyEvent)?
I have run into a situation where such state would be helpful, and was looking into seeing if this was something that I could add.
Torben
Hi Torben,
I don’t know if there is a reason, but I can relate with your situation. I had to deal with it, by storing the changed values
in a thread local in the pre event to use them later in the post modify event, and it’s… well… ugly :-p
On Thu, Feb 9, 2017 at 2:19 AM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Hello,
Torben
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I decided to try out what would be involved in adding this functionality.
It looks to be a relatively safe change, as all important API changes are to internal catalog methods.
PR here, open for discussion: https://github.com/geoserver/geoserver/pull/2101
Torben
On Thu, Feb 9, 2017 at 1:41 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Torben,
Hello,
Torben
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Seems sensible. I don’t know enough about that area of the code to comment in depth but it seems like a sensible change on a high level.
Hi Torben,
On Thu, Feb 9, 2017 at 2:19 AM, Torben Barsballe <tbarsballe@anonymised.com839…> wrote:
Hello,
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
That sounds terrible Andrea / Torbien.
The only technical reason I could think of if the before state contains references to stores/resources/styles/layer that no longer exist after a delete change. Or are no longer “valid” after a post modify event. I would hate for the event to keep conflicting objects “live” at the same time (say a before and after DataStoreInfo connection parameters which are no longer valid).
On 9 February 2017 at 01:41, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Torben,
Jody Garnett
Hello,
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
Jody:
Looking at the current implementation, the Modify event stores the object before the change, and the PostModify event stores the object after the change.
In addition, the Modify event stores a list of properties that have changed.
The extent of suggestion is to also store this list of properties on the PostModify event - no conflicting objects would be involved.
Torben
On Thu, Feb 9, 2017 at 12:07 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Hi Torben,
Hello,
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
