[Geoserver-devel] GeoServer CITE tests - Update and Blog post
Hello,
I am putting together a blog post about the FOSS4G-NA Code Sprint last week, where I worked on CITE tests.
I had heard Justin had some CITE tests that he was adding to the build boxes, and it would be nice to provide some recognition of this work in my blog post.
Justin - Is there any update on this?
Torben Barsballe
On Fri, Mar 20, 2015 at 7:59 PM, Torben Barsballe <
tbarsballe@anonymised.com> wrote:
Hello,
blog post.
You're being a bit too optimistic here, Justin had some work in progress
for that that he would share with us,
but it's not yet ready to be put on the build box, I believe it still needs
some adjustments.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
