[Geoserver-devel] Geoserver Clustering Issue
Hi everyone,
I have problems about clustering.
I have implemented a Geoserver cluster with 3 nodes and a shared data directory. These nodes are on different VM with Win7. When I start all the nodes, warnings are output on console which say
WARN [network.DiscoveryNetworkConnector] - Could not start network bridge between: vm://08127b80-febe-4686-81ca-d57f455e24a9?async=false&network=true and: nio://127.0.0.1:50846 due to: java.net.ConnectException: Connection refused: no further information
Does it matter?
When I use Node1’s UI to publish a shapefile, I cannot see the layer on Node2 and Node3’s UI except I reload the configuration by click the button on UI. However, when I use Node1’s UI to add a user, I can see the new user on Node2 and Node3’s UI. Why? And how can I use the data published by Node1 with Node2 or Node3?
Thank you!
This is a question for the user list, post here only if you want to participate in the development of GeoServer own code.
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
