[Geoserver-devel] GeoServer committer cleanup, GSIP-180, and your commit rights
Dear Andrea,
I still need commits rights, especially on several community modules I am following as a maintainer.
Alessio.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
mob: +39 331 6233686
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Alessio,
please check the GSIP 180 requirements, can you confirm you are subscribed to the devel, users and build lists?
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Yeps, I confirm.
Il sab 9 nov 2019, 16:58 Andrea Aime <andrea.aime@anonymised.com> ha scritto:
Hi Alessio,
On Sat, Nov 9, 2019 at 4:02 PM Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Dear Andrea,
Alessio.
Il giorno sab 9 nov 2019 alle ore 12:14 Andrea Aime <andrea.aime@anonymised.com> ha scritto:
you’re receiving this mail as part of the GSIP-180 work.
We have determined you have been active doing GeoServer commits in the last year,
but have not answered to the mail checking whether you are subscribed to the devel, list and build lists,
sent two weeks ago on the geoserver-devel list:
http://osgeo-org.1560.x6.nabble.com/All-committer-please-notice-cleanup-in-progress-please-follow-up-with-this-mail-ASAP-GSIP-180-td5420137.html
If you don’t wish to retain your committer rights, no action is required, otherwise, please follow up on the above mentioned
thread.
As a reminder, committer rights are not required to contribute to GeoServer, pull requests can also be used.
Direct commit rights however allow direct commits, review and merge rights on pull request, and wiki access (for proposals).
If by any chance you find out that the commit rights have been removed, and it’s too late and wish to get them back, no worries, just
write a mail on geoserver-devel on that regard, showing us why you need them.
Best regards
@alfa7691
