[Geoserver-devel] GeoServer Complex Datastore
Hi All,
I am trying to build the Complex Datastore branch of GeoServer. I’ve followed the instructions at http://geoserver.org/display/GEOS/Complex+Datastore but get this error when running the GeoTools build.
[ERROR] BUILD FAILURE
[INFO] Compilation failure
/users/ncs/petwa/Source/geotools/2.4.x/modules/unsupported/community-schemas/sql-datastore/src/org/geotools/data/sql/RsMd2DbMdResultSet.java:[19,7] org.geotools.data.sql.RsMd2DbMdResultSet is not abstract and does not override abstract method updateNClob(java.lang.String,java.io.Reader) in java.sql.ResultSet
I’m not a Java or Maven expert so I feel a little out of my depth here. Any suggestions gratefully received.
Pete
Rob Atkinson wrote the following reply but did not copy the list:
Hi Peter,
the branch is now deprecated, you need to build the optional modules in the
stable geotools 2.4 and geoserver 1.6 code base. ( We hope to have all these
modules incorporated in the main build in the next major version.)
instructions are here:
https://www.seegrid.csiro.au/twiki/bin/view/Infosrvices/GeoserverDevelopmentSetup
To save time, you may also access the prebuilt version there at:
https://www.seegrid.csiro.au/twiki/bin/view/Infosrvices/GeoserverCommunitySchemasDownloads
This is a work in progress, and we are supporting the international GoeSciML
testbed initially, before packaging the capability for more general purpose
use. In particular, we aim for it to be ready to implement INSPIRE data
standards as they emerge, as well as a range of scientific applications.
Please let us know what your requirements are, what schemas you are trying
to implement and consider providing a sample configuration with minimal test
data in a properties file we can use as an example or for regression
testing.
Regards
Rob Atkinson
Peter Walker wrote:
Hi All,
I am trying to build the Complex Datastore branch of GeoServer. I've
[INFO]
I'm not a Java or Maven expert so I feel a little out of my depth here.
Pete
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geoserver-devel mailing list
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Exploration and Mining
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
