I noticed a small bug when hitting "Submit" after viewing a
FeatureType in config->data->featuretypes from the geoserver config
page. It seems to apply any changes made (I was changing the style),
but throws an exception. The page I get afterwards says:
GeoServer - Exception The following exception was thrown:
java.lang.NumberFormatException: empty String
The full trace from the server is available at http://rafb.net/p/wfNJXe32.html
-Anthony Manfredi, GSoC student
Hi Anthony,
Can you be more specific about which changes you are making in the
config? Is it to one the feature types that comes out of the box with
geoserver, or one you have configured / added separately?
Also I was not able to access the full stack trace from the url you
provided. Perhaps you can reply and attach the full stack trace directly.
-Justin
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
Geoserver-devel mailing list
!DSPAM:4007,466f381a58713362379201!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
It seems to happen no matter which FeatureType I choose. I was
initially looking at tasmania_roads. It does not matter whether I
change anything or not; if I hit submit I get the error. I am running
on Mac OS X, so if this is not happening on other platforms it could
be related to java peculiarities on the mac.
The url has probably expired by now. Here is the trace:
13 Jun 01:36:51 INFO [geoserver.action] - setting session and user
ftConfig to : FeatureTypeConfig[name: tasmania_roads schemaName: null
SRS: 4326 schemaAttributes:
[org.vfny.geoserver.config.AttributeTypeInfoConfig@anonymised.com,
org.vfny.geoserver.config.AttributeTypeInfoConfig@anonymised.com] schemaBase
null]
rest based on schemaBase: null
13 Jun 01:36:56 WARN [action.RequestProcessor] - Unhandled Exception
thrown: class java.lang.NumberFormatException
2007-06-13 01:36:56.052::WARN: EXCEPTION
javax.servlet.ServletException: empty String
at org.apache.struts.action.RequestProcessor.processException(RequestProcessor.java:535)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:433)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:445)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1050)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1041)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:354)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:226)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:627)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:149)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
at org.mortbay.jetty.Server.handle(Server.java:269)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:430)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:701)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:617)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:199)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:339)
at org.mortbay.jetty.nio.HttpChannelEndPoint.run(HttpChannelEndPoint.java:270)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
2007-06-13 01:36:56.079::WARN: Nested in
javax.servlet.ServletException: empty String:
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:994)
at java.lang.Double.parseDouble(Double.java:482)
at org.vfny.geoserver.action.data.TypesEditorAction.getNativeBBox(TypesEditorAction.java:494)
at org.vfny.geoserver.action.data.TypesEditorAction.sync(TypesEditorAction.java:345)
at org.vfny.geoserver.action.data.TypesEditorAction.executeSubmit(TypesEditorAction.java:458)
at org.vfny.geoserver.action.data.TypesEditorAction.execute(TypesEditorAction.java:125)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
2007-06-13 01:36:56.102::WARN: /geoserver/config/data/typeEditorSubmit.do:
2007-06-13 01:36:56.106::WARN: /geoserver/config/data/typeEditorSubmit.do
