We EeEevdv
N
Sent from my BlackBerry 10 smartphone.
Original Message
From: geoserver-devel-request@lists.sourceforge.net
Sent: Sunday, April 26, 2015 06:03
To: geoserver-devel@lists.sourceforge.net
Reply To: geoserver-devel@lists.sourceforge.net
Subject: Geoserver-devel Digest, Vol 107, Issue 53
Send Geoserver-devel mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
geoserver-devel-owner@lists.sourceforge.net
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Geoserver-devel digest..."
Today's Topics:
1. Re: Slow build, security setup an important portion of our
build times (Andrea Aime)
2. Re: Slow build, security setup an important portion of our
3. Blogs about new features in 2.8 (Andrea Aime)
Message: 1
Date: Sat, 25 Apr 2015 21:24:52 +0200
Subject: Re: [Geoserver-devel] Slow build, security setup an important
portion of our build times
To: Christian Mueller <christian.mueller@anonymised.com>
Cc: Geoserver-devel <geoserver-devel@lists.sourceforge.net>
Message-ID:
<CA+nxMTsPm2TvehCU9r4Xo053EeMwN=o9c9DOhEdkEfmsYmMySQ@anonymised.com>
Content-Type: text/plain; charset="utf-8"
On Sat, Apr 25, 2015 at 12:07 PM, Andrea Aime <andrea.aime@anonymised.com>
wrote:
Then replaced security.zip contents with the result, and looked at the
tests.
It looks that migrate23 is now skipped, but migrate24 does not have any
skipping logic, and just
runs at every test/startup, even if it's changing nothing.
Simple idea, can we put a version.properties/version.txt in the security
dir, containing the current
version of the security dir contents (it would be 2.5 now).
The first time we don't find it, go though the migrations, then create it,
from that point on no need
to go though the migrations at all.
For data directories that miss completely a security setup (as it happens
in some tests), wondering,
can't we just use the security.zip of the tests, unpack it, and move on?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
loro utilizzo ? consentito esclusivamente al destinatario del messaggio,
per le finalit? indicate nel messaggio stesso. Qualora riceviate questo
utilizzarlo per finalit? diverse, costituisce comportamento contrario ai
Message: 2
Date: Sun, 26 Apr 2015 11:24:25 +0200
Message-ID:
<CA+nxMTsQLWTyRaN-YEuM=a0rtunCvWpDTNQJgMLXh9y7LgURCg@anonymised.com>
On Sat, Apr 25, 2015 at 9:24 PM, Andrea Aime <andrea.aime@anonymised.com>
to go though the migrations at all.For data directories that miss completely a security setup (as it happens
I've played a bit with this idea, here is a branch that applies it and
indeed speeds up the build:
https://github.com/aaime/geoserver/tree/build_security_speedup
In particular, this commit:
https://github.com/aaime/geoserver/commit/ac4a915bfa238f7978efac3faff52eeed1267d2c
Simple partial build times comparison, only up to the wfs module.
Before:
[INFO]
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [
1.630 s]
[INFO] Core Platform Module ............................... SUCCESS [
10.997 s]
[INFO] Open Web Service Module ............................ SUCCESS [
7.582 s]
[INFO] Main Module ........................................ SUCCESS [02:16
min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:39
min]
[INFO]
[INFO] BUILD SUCCESS
[INFO]
[INFO] Total time: 04:18 min
After:
[INFO]
[INFO]
1.358 s]
10.543 s]
7.476 s]
[INFO] Main Module ........................................ SUCCESS [01:50
min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:15
min]
[INFO]
[INFO]
[INFO] Total time: 03:26 min
Overall, a significant speedup.
I've tried a full build too, but if fails in a couple of web-sec-core tests
and I'm having little
luck fixing it them: RoleListPageTest.testRemove
and ConfirmRemovalRolePanelTest.testRemoveRole
RoleListPageTest.testRemove apparently tries to remove all roles from a
list,
and in the normal version, only finds NEW_ROLE to select and delete, but
with
the patched version, the table also contains ROLE_ADMINISTRATOR, whose
removal makes a test fail (wondering, should this role be even removable?).
I haven't investigated the other failure.
Christian, do you have any clue?
Ing. Andrea Aime
@geowolf
Technical Lead
Message: 3
Date: Sun, 26 Apr 2015 12:02:53 +0200
Subject: [Geoserver-devel] Blogs about new features in 2.8
To: Geoserver-devel <geoserver-devel@lists.sourceforge.net>
Message-ID:
<CA+nxMTtmvvh0nHMb++ygOLmBzjKgvU4y+H2wieZrG3O7NnQqkg@anonymised.com>
I was looking around and believe we already piled up some nice new features
in the 2.8.x series:
* Nodata support in rasters
* New projections, gnomonic and sinusoidal, and possibly a third one coming
in
* GML encoding speedups
* Importer raster related improvements in the pipeline
and probably something else I'm missing.
I was thinking to start writing blogs about them (one for each new feature,
over time) to invite
people to test the 2.8.x series sooner rather than waiting for beta (given
all the testing we have on
the build servers, it's probably pretty stable anyways).
Opinions?
Ing. Andrea Aime
@geowolf
Technical Lead
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
End of Geoserver-devel Digest, Vol 107, Issue 53
