Hi Ben,
Thanks for your reply.
I liked your idea to go with http instead of https
Though, now I am getting 504 Gateway time out.
$ svn co http://svn.codehaus.org/geoserver/branches/1.7.x
geoserver-1.7.x
svn: Server sent unexpected return value (504 Gateway Time-out)
in response to OPTIONS request for
'http://svn.codehaus.org/geoserver/branches/1.7.x’
googling the net it said
504 errors - general
This problem is entirely due to slow IP communication between
back-end computers, possibly including the Web server. Only the people
who set up the network at the site which hosts the Web server can fix
this problem.
Does that mean I am using a wrong site while doing the svn checkout?
Please advice
Thanks
Yash
-----Original Message-----
From: Ben Caradoc-Davies [mailto:Ben.Caradoc-Davies@anonymised.com]
Sent: Wednesday, November 18, 2009 1:04 PM
To: Save, Yash
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Geoserver-devel Digest, Vol 42, Issue 40
If you only want to checkout, you can use HTTP not HTTPS:
If you later wish to commit, you will need a fresh checkout using HTTPS,
once your client issue has been resolved..
Kind regards,
Ben.
On 18/11/09 14:33, Save, Yash wrote:
Hi
We are developing a plugin for the geoserver.
For this I need to checkout the geoserver code in my development
environment
I am using the link
http://docs.geoserver.org/2.0.x/en/developer/quickstart/index.html for
the instructions.
While I checkout the 1.7.x branch using the command
svn co https://svn.codehaus.org/geoserver/branches/1.7.x
geoserver-1.7.x<https://svn.codehaus.org/geoserver/branches/1.7.x%20geos
erver-1.7.x>
I get the below error
svn: OPTIONS of 'https://svn.codehaus.org/geoserver/branches/1.7.x’:
Could not create SSL connection through proxy server: Could not
authenticate to proxy server: ignored NTLM challenge, ignoring empty
Negotiate continuation, rejected Basic challenge
(https://svn.codehaus.org/>\)
Searching on the net I understood that I need to download SSL
certificate.
Can some one please put light on the whole issue.
Thanks
Yash
Please help Logica to respect the environment by not printing this
email / Pour contribuer comme Logica au respect de l'environnement,
merci de ne pas imprimer ce mail / Bitte drucken Sie diese Nachricht
nicht aus und helfen Sie so Logica dabei, die Umwelt zu sch?tzen. / Por
favor ajude a Logica a respeitar o ambiente n?o imprimindo este correio
electr?nico. This e-mail and any attachment is for authorised use by the
intended recipient(s) only. It may contain proprietary material,
confidential information and/or be subject to legal privilege. It should
not be copied, disclosed to, retained or used by, any other party. If
you are not an intended recipient then please promptly delete this
e-mail and any attachment and all copies and inform the sender. Thank
you.
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
Please help Logica to respect the environment by not printing this email / Pour contribuer comme Logica au respect de l'environnement, merci de ne pas imprimer ce mail / Bitte drucken Sie diese Nachricht nicht aus und helfen Sie so Logica dabei, die Umwelt zu sch?tzen. / Por favor ajude a Logica a respeitar o ambiente nao imprimindo este correio electronico.
This e-mail and any attachment is for authorised use by the intended recipient(s) only. It may contain proprietary material, confidential information and/or be subject to legal privilege. It should not be copied, disclosed to, retained or used by, any other party. If you are not an intended recipient then please promptly delete this e-mail and any attachment and all copies and inform the sender. Thank you.
