[Geoserver-devel] GeoServer documentation builds failing: disk quota exceeded
we have a build stuck for 17 hours, the last error message is on rsync, stating:
rsync: write failed on "/var/www/[docs.geoserver.org/htdocs/master/en/api/index.html](http://docs.geoserver.org/htdocs/master/en/api/index.html)": Disk quota exceeded (122)
en/user/_images/MasterFailed.png
Looks like the machine hosting the documentation is in need of a cleanup, or a larger quota?
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I’m looking into it, the server has indeed run out of space. Trying to see if I can get the quota enlarged.
I’ll update when this is fixed.
Torben
On Wed, Jul 11, 2018 at 1:55 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrge.net
More space has been added, and the doc build appears to be running smoothly again.
Torben
On Wed, Jul 11, 2018 at 4:18 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Awesome, thank you!
On Thu, Jul 12, 2018 at 5:52 PM, Torben Barsballe <tbarsballe@anonymised.com.> wrote:
Torben
Torben
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
