[Geoserver-devel] GeoServer Documentation: updating MacOSX sphinx instructions
Hi list,
I have prepared a PR to update the Sphinx instructions needed to build GeoServer documentation, since it was outdated:
  • make html ----> ant user
  • adding sphinx required >=1.7.0 due to latest -j parameter for parallel parsing not supported in older version
  • using pip install instead of easy_install
    - updated the path containing the created doc:
    doc\user\build\html → doc\en\target\user\html
https://github.com/geoserver/geoserver/pull/3583
Can anyone with MacOSX verify which changes are needed on that chapter?
I see it has both a Manual Install and an Easy Install. Wondering if the easy install can be updated to use “pip install” and I’m not sure about the jinja2 dependency in manual install. I don’t have a MacOSX to check/verify that.
Please, let me know.
Daniele
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
I can add some Mac instructions, I will add a comment to you PR.
Jody Garnett
