does any one understand what this means? did geoserver.org change it’s address?
Ian
Ian Turton
I just got this same warning when publishing the 2.15.0 website updates, although the updates still showed up at http://geoserver.org
No idea why we’d be getting this error. Maybe there are multiple domains that link to the site? Anyone else have any ideas?
Torben
Ian
---------- Forwarded message ---------
Date: Fri, 22 Feb 2019 at 14:20
Subject: [geoserver/geoserver.github.io] Page build warning
To: Ian Turton <ijturton@anonymised.com>The page build completed successfully, but returned the following warning for the
master
branch:The custom domain for your GitHub Pages site is pointed at an outdated IP address. You must update your site’s DNS records if you’d like it to be available via your custom domain. For more information, see https://help.github.com/articles/using-a-custom-domain-with-github-pages/.
For information on troubleshooting Jekyll see:
https://help.github.com/articles/troubleshooting-jekyll-builds
If you have any questions you can contact us by replying to this email.
Ian Turton
Geoserver-devel mailing list
I also received the error message. Searching for it on the internet, it seems that DNS records need to be updated, but it’s not something
I can do (checked the site settings, the custom domain is just “geoserver.org” there, no IP addresses)…
See also:
https://www.reddit.com/r/webdev/comments/av9e9z/custom_domain_for_github_pages_is_pointed_at_an/
https://github.com/elm-community/builtwithelm/issues/180
https://github.com/xando/commitcoffee/issues/167
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
