Another point has been the usage of commons-httpclient. This is an old, unmaintained library that today are used by gt-wms and gt-wfs in their own MultithreadedHttpClients. I was looking a bit on this, but I see no advantage of using it, so I reverted all my changes.
No advantage compared to the Java 8 client? Performs better as far as I know. I always have it on in GeoServer deploys, leaving the Java 8 client for
cases where
There are some bugs related to these two clients, so it would make sense to introduce a new unsupported plugin gt-http-commons with the MultithreadedHttpClient from gt-wms. I’m open for doing this, but maybe in a new PR when this is done.
Having a module for it would make sense indeed.
What I do want to work on is the new HttpClient in JDK 11. My initial plan has been to introduce a new plugin gt-http-ng, but that will be introduced in a new Jira / PR.
For this to work, we need to discuss switching to JDK 11 as the minimum supported version (release packages are built with Java 8, Java 11 is in the builds
to make sure projects work with it, though we have issues with modularity as no one of core devs is really using it).
Normally the discussion open when the next LTS is released, which will be Java 17 in September 2021… historically, we do a code sprint a few months later to
add support for the new LTS and drop the old one (so the switch would be from Java 8 and Java 11, to Java 11 and Java 17).
At the same time, Java 8 is supported until 2026, and Java 11 only up to 2024*, which is not ideal, a switch would actually reduce the time the servers deploying
those versions can stay up without an overhaul.
*: https://adoptopenjdk.net/support.html
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
