I’ve added some data to my geoserver. For some of theese there is no problem, while for some other I’vethe following error message:
Could not find Feature Type named: nave, feature information is not in the data folder
It seems that the selected directory doesn’t exist, but I’ve followed the same procedure for all data…
Any ideas on what is wrong?
Alessandro
Dott. Ing.Alessandro Ceccotti, netXcalibur s.r.l.
Via Alamanni, 25
I-50123 Firenze
T: +39.055.285859 - F: +39.055.285760
You're going to have to send some more information - it's really hard to
diagnose problems without any sort of context. I suspect the problem is
in info.xml of nave - if you could set the LoggingLevel to FINER and send
me the full log of start up and requesting nave, and the info.xml of the
ones that are failing, then it's much easier for me to diagnose the
problems. Always try to include as much information as possible in
requests for help, as many logs and configuration files as possible, as
well as information on your installation - OS, servlet container, java
version, postgis version, ect.
Chris
On Tue, 15 Jul 2003, Alessandro Ceccotti wrote:
I've added some data to my geoserver. For some of theese there is no
problem, while for some other I'vethe following error message:
the data folder
It seems that the selected directory doesn't exist, but I've followed
the same procedure for all data..
Alessandro
Via Alamanni, 25
I-50123 Firenze
