Hello,
I have been pushing our customer to use an open source solution,
namely GeoServer, for a new GIS project awarded us. Right now they are
still wanting to use ESRI and their ArcGIS Server solution, which in
my opinion is a wasted resource both financially and technically
(their current software offerings appear to be bloatware and far
exceed what we really need). ArcGIS Server hardware requirements also
appear to be very high, but they only list some basic information on
their website and I've been trying to obtain answers regarding our
current hardware specs and their recommendations for upgrades if and
where necessary. It has now been almost one week since initial contact
with a salesperson at ESRI, who apparently is my only direct contact
too (my initial questions have since been passed onto their 'technical
marketing group').
With the above in mind there is still hope in convincing our customer
to use the GeoServer solution. As such I'm hoping someone here can
help me and provide guidance far quicker than ESRI can (so a small
challenge too; I'm a big advocate of open source solutions and this
form of direct and responsive support).
I'm posting my original ESRI request below, which contains some basics
regarding our expectations and current hardware specs. Please
substitute ArcGIS Server with GeoServer where necessary.
Please let me know if you require any further information. I look
forward to your response.
Stephen Bull
EDS
--- original hardware questions sent to ESRI...
As discussed we are looking to purchase and install ArcGIS Server, for
use within a production environment, on some existing hardware (which
currently houses ArcIMS 4). We will be developing a web app for
serving real-time maps to and also performing geoprocessing of both
single and multiple addresses on a daily basis. The hardware is three
years old and may require upgrades in certain areas to at least meet
minimum specs. Basic hardware specs are as follows:
Sun Sunfire 280R
Single 800MHz processor
2 Gb RAM
2 x 18 Gb HD
The server currently runs Solaris 8, and with ArcGIS Server we will be
upgrading to/installing Solaris 10. Apache 2 and Tomcat 5 will also be
installed. On the ESRI Support Center website the hardware
requirements call for a 1.0 GHz or higher processor. Would we get away
with using an 800 MHz processor in a production environment (at least
for the time being), given the other hardware specs (2 Gb of RAM
etc.), or would you strongly suggest upgrading this? If so, what would
you recommend if 1 GHz is a bare minimum and something faster would be
preferable? Will 2 Gb RAM be enough also?
Per our conversation, your website also calls for a 24-bit capable
graphics accelerator, which our box currently doesn't have. Is this a
necessity given that we are developing a web app? (Does ArcGIS server
require certain graphics processing capabilities outside of the main
CPU?) Additionally, if a graphics card isn't necessary would we need
to compensate for this by setting aside a portion of main RAM for
certain processing needs (when generating map data)?
