[Geoserver-devel] Geoserver hibernate module
I use the binary distribution of Geoserver (2.1 rc3). I would like to use the hibernate config module. Is it already available as a downloadable jar file somewhere or works are in progress? I would not like to build it from source cause all attempts have failed.
regards,
Rémy
Hi Rémy,
You can download the module here:
http://gridlock.opengeo.org/geoserver/2.1.x/community-latest/geoserver-2.1-SNAPSHOT-dbconfig-plugin.zip
It should work with 2.1-RC3 but you may also have to upgrade to the latest 2.1.x nightly build. Also be warned that the module is a community module so unstable and experimental by nature.
-Justin
On Wed, May 11, 2011 at 7:08 AM, web <web@…1639…> wrote:
regards,
Rémy
Achieve unprecedented app performance and reliability
What every C/C++ and Fortran developer should know.
Learn how Intel has extended the reach of its next-generation tools
to help boost performance applications - inlcuding clusters.
http://p.sf.net/sfu/intel-dev2devmay
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
Thanks for the link. I unzipped these jar files into web-inf/lib and restarted Geoserver. I’ve seen that some files were created into the data dir: hibernate.properties and geoserver.db.properties.
When I restart Geoserver I got the following error. It says I should define an env. property for a class name. Do you know what is this about?
11 mai 16:49:55 INFO [config.GeoServerPropertyConfigurer] - Loading properties file from URL [file:/C:/geoserver-2.1.x-latest-bin/geoserver-2.1-SNAPSHOT/data_di
r/hibernate.properties]
11 mai 16:49:57 WARN [impl.SessionFactoryObjectFactory] - Could not bind factory to JNDI
javax.naming.NoInitialContextException: Need to specify class name in environment or system property, or as an applet parameter, or in an application resource f
ile: java.naming.factory.initial
at javax.naming.spi.NamingManager.getInitialContext(NamingManager.java:645)
at javax.naming.InitialContext.getDefaultInitCtx(Initi! alContext.java:288)
at javax.naming.InitialContext.getURLOrDefaultInitCtx(InitialContext.java:325)
at javax.naming.InitialContext.getNameParser(InitialContext.java:480)
at org.hibernate.util.NamingHelper.bind(NamingHelper.java:52)
at org.hibernate.impl.SessionFactoryObjectFactory.addInstance(SessionFactoryObjectFactory.java:90)
at org.hibernate.impl.SessionFactoryImpl.(SessionFactoryImpl.java:306)
at org.hibernate.cfg.Configuration.buildSessionFactor! y(Configuration.java:1300)
at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:814)
Yeah, I can’t actually figure out how to suppress this error, but it is not fatal. The extension should function without defining an initial context in the servlet container.
On Wed, May 11, 2011 at 8:54 AM, web <web@anonymised.com> wrote:
Hi Justin,
Justin Deoliveira
We put a method in the GeoTools class allowing you to configure the Initial context. So if you grab the value from there; and if GeoServer can pass the initial context int) it should all work.
This was used to look up JDNI DataSource for working with Oracle.
Jody Garnett
Hi Justin,
Justin Deoliveira
Hi Justin, Jody,
I’ve not been able to make this context init error disappear but as it is not fatal, Geoserver has startup with its config in DB. Thank you for your hint.
Just a remark: I noticed an error at startup saying that an exception class from antlr was missing and this was fatal. I downloaded antlr-3.3-complete.jar and put it into the web-inf/lib folder and this error disappeared. So maybe would make sense to check this issue.
Thanks for your help,
regards,
Rémy
On Thu, May 12, 2011 at 8:16 AM, web <web@anonymised.com> wrote:
Hi Justin, Jody,
Yeah actually this error is misleading… it means that there was an error compiling an hql statement and really has nothing to do with the anltr version. Can you provide the full stack trace?
regards,
Rémy
Justin Deoliveira
Hi, here is the full stacktrace:
(It only occurs if antlr jar file is not present in web-inf/lib directory)
16 mai 14:42:53 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcCatalogConfiguration’ defined in URL [jar:file:/C:/geoserver-2.1.x-la
test-bine/geoserver-2.1-SNAPSHOT/webapps/geoserver/WEB-INF/lib/gwc-2.1-SNAPSHOT.jar!/geowebcache-geoserver-context.xml]: Cannot resolve reference to bean ‘rawCa
talog’ while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘rawCatalo
g’ defined in URL [jar:file:/C:/geoserver-2.1.x-latest-bine/geoserver-2.1-SNAPSHOT/webapps/geoserver/WEB-INF/lib/main-2.1-SNAPSHOT.jar!/applicationContext.xml]:
Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: antlr/ANTLRException
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185! )
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:18)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebA! ppContext.startContext(WebAppContext.java:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)!
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
Caused by: org.! springframework.beans.factory.BeanCreationException: Error creating bean with name ‘rawCatalog’ defined in URL [jar:file:/C:/geoserver-2.1.x-late
st-bine/geoserver-2.1-SNAPSHOT/webapps/geoserver/WEB-INF/lib/main-2.1-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:480)
&n! bsp; at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractBeanFactory.! getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
… 43 more
Caused by: java.lang.NoClassDefFoundError: antlr/ANTLRException
at org.hibernate.hql.ast.ASTQueryTranslatorFactory.createQueryTranslator(ASTQueryTranslatorFactory.java:35)
at org.hibernate.engine.query.HQLQueryPlan.(! HQLQueryPlan.java:74)
at org.hibernate.engine.query.HQLQueryPlan.(HQLQueryPlan.java:56)
at org.hibernate.engine.query.QueryPlanCache.getHQLQueryPlan(QueryPlanCache.java:72)
at org.hibernate.impl.AbstractSessionImpl.getHQLQueryPlan(AbstractSessionImpl.java:133)
at org.hibernate.impl.AbstractSessionImpl.createQuery(AbstractSessionImpl.java:112)
at org.hibernate.impl.SessionImpl.createQuery(SessionImpl.java:1623)
at org.geoserver.hibernate.AbstractHibFacade.query(AbstractHibFacade.java:70)
at org.geoserver.catalog.hib.HibCatalogFacade.getStyleByName(HibCatalogFacade.java:330)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:106)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy0.getStyleByName(Unknow! n Source)
at org.geoserver.catalog.impl.CatalogImpl.getStyleByName(CatalogImpl.java:1020)
at org.geoserver.config.GeoServerLoader.initializeStyles(GeoServerLoader.java:166)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:119)
at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitialization(GeoServerLoaderProxy.java:54)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanF
actory.java:350)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
… 52 more
Caused by: java.lang.ClassNotFoundException: antlr.ANTLRException
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
&nb! sp; at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:366)
at org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:337)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320)
… 79 more
7750 [main] ERROR org.mortbay.log - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@anonymised.com{/geoserver,file:/C:/geoserver-2.1.x-latest-bine/geos
erver-2.1-SNAPSHOT/webapps/geoserver/}
at ! org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:275)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:92! 5)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
&! nbsp; at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)!
&nb! sp; at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at sun.reflec! t.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘rawCatalog’ defined in URL [jar:file:/C:/geoserver-2.1.x-late
st-bine/geoserver-2.1! -SNAPSHOT/webapps/geoserver/WEB-INF/lib/main-2.1-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanF! actory.createBean(AbstractAutowireCapableBeanFactory.java:380)
… 43 more
at org.hibernate.engine.query.HQLQueryPlan.(HQLQueryPlan.java:74)
&n! bsp; at org.hibernate.engine.query.QueryPlanCache.getHQLQueryPlan(QueryPlanCache.java:72)
at sun.reflect.N! ativeMethodAccessorImpl.invoke0(Native Method)
! ; at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at $Proxy0.getStyleByName(Unknown Source)
! at org.geoserver.config.GeoServerLoader.initializeStyles(GeoServerLoader.java:166)
actory.java:350)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableB! eanFactory.java:1330)
… 52 more
at org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader! .java:366)
… 79 more
7750 [main] WARN org.mortbay.log - Nested in org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘gwcCatalogConfiguration’ de
fined in URL [jar:file:/C:/geoserver-2.1.x-latest-bine/geoserver-2.1-SNAPSHOT/webapps/geoserver/WEB-INF/lib/gwc-2.1-SNAPSHOT.jar!/geowebcache-geoserver-context.
xml]: Cannot resolve reference to bean ‘rawCatalog’ while setting constructor argument; nested except! ion is org.springframework.beans.factory.BeanCreationExcept
ion: Error creating bean with name ‘rawCatalog’ defined in URL [jar:file:/C:/geoserver-2.1.x-latest-bine/geoserver-2.1-SNAPSHOT/webapps/geoserver/WEB-INF/lib/ma
in-2.1-SNAPSHOT.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: antlr/ANTLRException:
&! nbsp; at org.mortbay.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:366)
&nb! sp; at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
actory.java:350)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initial! izeBean(AbstractAutowireCapableBeanFactory.java:1330)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:2! 64)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueRes! olver.java:269)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean! Instance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.fac! tory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListable! BeanFactory.java:429)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLo! aderListener.java:45)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.ja! va:39)
at sun.reflect.Delegating! MethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
7766 [main] INFO org.mortbay.log - Opened C:\geoserver-2.1.x-latest-bine\geoserver-2.1-SNAPSHOT\logs\2011_05_16.request.log
7797 [main] INFO org.mortbay.log - Started SelectChannelConnector@anonymised.com:8080
Hmmm… so it appears some error occurred looking up styles. As I mentioned before community modules are unstable and not really guaranteed to work. Seems dbconfig is more unstable than I thought. I will try to look into the cause if i get some time and get a fix in you can test.
-Justin
… 43 more
actory.java:350)
… 52 more
… 79 more
… 43 more
&nbsp! ; at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
actory.java:350)
… 52 more
… 79 more
actory.java:350)
Justin Deoliveira
